Everything posted by Glen McGuire
Sails are the last thing to make before she's ready to hit the bottle. The Kenoshi sails are similar to Chinese junk ship sails with the usage of numerous horizontal battens. When I first made those type of sails for my Zheng-he Treasure Fleet project 3 years ago, I just glued the battens to the back of a single square of fabric for each sail. In studying my reference picture for the Kenoshi, I realized that the sail is not a single piece of material. The sail actually consists of small, horizontal panels connected to and separated by the battens. That certainly added a new level of complexity to the build just when I thought I had things under control. But what the heck, we're all here for a challenge aren't we! So I started by penciling the outline of the sail on some light tan shirt cloth, drawing lines for the individual panels, and gluing a bolt rope on each of the vertical sides. I also made a small jig to help line up the panels and battens for assembly. Here are the cut panels and battens ready for assembly. To assemble the sail, I put the first batten down and just touched it in a few spots with a tiny amount of CA glue. Then I slid the cloth panel into place ensuring it made contact with each spot of glue. Rinse and repeat. Even though I was using the tiniest amount of glue that you could imagine, the bond seemed to be holding up ok. I had to be very sparing with the glue usage because of how much it darkened to cloth. In the pic below, it is quite obvious where I used a tad too much glue and it bled. But that was ok because I had a plan to cover up most of the bleeding. And here was the plan. I went on the inside of each batten and used fabric glue to lay down another line of thread that would sort of look like a bolt rope for the horizontal sides of each panel. This had the dual benefits of hiding most of the glue bleeding as well as offering more adhesion of the panel to the batten. Here's the completed fore and main sails secured to their respective masts. There are a few spots where the CA glue bleed was a little too much to cover up, but for the most part it worked out well. The main objective was for the sail to look pretty much the same (i.e. battens showing equally) whether you are looking at it from the front or back. Here's a couple of shots with all the deck stuff dry-fit in place along with the reference picture for comparison. The ship is pretty much ready for insertion into the bottle. However, I have not quite figured out the rigging yet. So I'm going to go back to work on the Constitution now while I try to figure out the rigging portion here.
- 106 replies
- Kentoshi-Sen
- bottle
Welcome aboard!
Dang, I had to look that one up, Keith! Never heard of a Yokai before. Interesting, but unlikely that one of those will cross paths with this Kentoshi. At least I hope not!
- 106 replies
- Kentoshi-Sen
- bottle
The title of a George Strait song comes to mind... 😃 https://www.youtube.com/watch?v=Trosuoi172s
- 90 replies
- Friendship Sloop
- bluejacket shipcrafters
Slight change of plans. I got back from Connecticut earlier in the week and decided to get a little more work done here before running back over to the Constitution. With the hull finished and split, it was time to go to work on the deck fittings which mostly consist of 3 houses and a tiller. Nothing too complicated. Once again, the biggest challenge for me was soldering the tiny rails on top of 2 of the houses. Here's the tiller in process. And all 4 items complete with the exception of a little touch-up painting that I need to do. I also put together the large ornamental carving on the bow along the the windlass and anchor. I deviated a bit from the pictures. The pictures have the windlass situated beyond the bow and the anchor resting on the deck just inside the bow's bulwark. I decided to reverse things and have the windlass inside the bow and the anchor hanging just over it. I did this because this whole sub-assembly will be installed after the ship is in the bottle and I'm using the windlass as another guide to help me get the whole thing in the exact location. The ends of it will rest against the top of the bulwark. And here she is with all those things dry-fitted including the oars and 2 masts.
- 106 replies
- Kentoshi-Sen
- bottle
Dang, Bob! I show up less than 2 weeks late and you're almost done with the thing! Warp speed. Looks great. Your paint job is fantastic.
- 46 replies
- Golden Hind
- airfix
Those are good guesses, but here's what's really going on, Keith. Husband, wife, and teenage daughter were on a road trip. They got lost, took a wrong turn, and ended up on this floating, wooden contraption because the husband refused to stop and ask for directions. Wife got mad and ran up the stairs looking for help while husband stayed with the car and started talking to a couple of deckhands about how the Lions did in the NFL draft. Daughter yelled at the parents to stop arguing and look her way so she could take a picture and post on her Instagram account.
- 732 replies
- Lula
- sternwheeler
Nice work on the 2-piece metal ring. Looks great and anyone looking at it would think it's a single piece.
- 312 replies
- Chile
- Latin America
(and 6 more)
Superb work, Mike! Particularly the finish on the interior planks. great choice on the stains.
- 47 replies
- Annapolis Wherry
- Chesapeake Light Craft
Glad to hear your hand is better and you're back in the shipyard, Mark. The planking is looking very nice.
- 257 replies
Thanks for the comment, Roel. That's an interesting idea to do a vertical Z-cut. I may play around with that before my next split-hull SIB. I've always used tapered locating pins (toothpicks) to help guide things in place when joining the hull inside the bottle. That Yi Soon Shin series looks like it would be worth watching. Thanks for reminding me why I live in Texas, Bob! Good analogy, Keith! And on that note, I'm going to jump out of this Kentoshi-sen airplane for a few weeks. I'm heading up to New London, CT for the Northeast Ship Modelers Show and when I get back, I'm going to dive back into the Constitution and see if I can finish her up.
- 106 replies
- Kentoshi-Sen
- bottle
For the first coat of primer, I think she looks great, Gary. Nice work. Can't wait to see tomorrow's post! 😃
- 90 replies
- Friendship Sloop
Happy Easter to everyone! An early update from the shipyard here before the day's real activities get going. Yesterday's chore was to make the ship's railings. I used 1/64" (.3mm) music wire for scale and also because it needed to be flexible enough to bend with the upward sweep of the bow and stern. The stanchions would be silver soldered in place. The challenge for me with soldering tiny right angle connections like that is holding everything in place because the slightest move will kill the 90 degree angle. For soldering, I use a technique I found watching an Olga Batcherov video. I cut the silver solder into tiny flecks, use a small paint brush and apply flux to the joint, grab a fleck of solder with the sharp tip of the iron, and then lightly touch it to the joint. I'm not great at the technique, but it's passable work. After installing the railing, it was time to split the hull. Ugh. I really don't like the idea of taking a saw and hacking on this thing I've invested so many hours in! It makes me nervous. I've done a few split hulls before and always struggled with making a clean cut right down the centerline. Kind of like the soldering above, the challenge is holding the hull stable while making the cut. I came up with a new idea that I thought might work. I drilled holes halfway thru the bottom on the ship and inserted 4 toothpick dowels, 2 on each side of the centerline. I drilled matching holes in the block of wood, inserted glue, and dropped the ship in place. I didn't drop it all the way down though. I inserted 3 planks of 2mm thick wood between the bottom of the ship and the block of wood but did not glue the small planks in place. The idea was to remove the planks after cutting the hull. The gap from the removed planks would allow me to use the saw to cut the hull from the block. Right after I took the picture below, I thought, "why did you put that keel on the bow when you knew you were going to cut the hull down the middle??" So much for my improved thinking things thru and planning things in advance. And yes, Keith, It has stopped snowing now. But actually, having the keel in place helped line things up visually and also gave me a challenge. My fine-kerf saw is just barely thinner than the 1mm wide keel. If I was good enough with the saw, I should be able to split the keel with the saw, right? Challenge accepted! I put the block of wood in my workbench vise and hit it with the fine-kerf saw. Here's how she came out.
- 106 replies
- Kentoshi-Sen
- bottle
You are quite the matchmaker, Keith! I'm sure it was love at first sight! A masterful job on both Lula and the pile driver. I will miss your updates, but I pray that the scan results are favorable and you are back to finish up Lula and the Tennessee very soon.
- 732 replies
- Lula
- sternwheeler
Thanks for posting these, Clare. That ship is remarkably similar to my Kentoshi-sen. The upsweeps on the bow and stern are more pronounced than mine, but your ship looks like it's got the same footprint and it certainly has the same deck for oarsmen. The 3 deck houses are almost identical and even oriented the same way. There are some differences, like the onboard windlass vs mine where it's suspended beyond the bow. Very intriguing! Thanks again for sharing.
- 106 replies
- Kentoshi-Sen
- bottle
Time to put some lipstick and perfume on this pig! There's a lot of narrow, red trim on the outside of the hull as well as some thin, perpendicular slats that support the inside of the bulwarks (I'm making those white). For the long piece of trim that travels underneath the oarsmen plank, I used the 1/64" birch plywood and cut a 1mm wide sliver. For the red trim above the oarsmen plank, I cut < 1mm slivers of super thin maple veneer that's measure 1/128" in thickness. Here's an in process pic with the stern carving painted and in place as well as the trim beneath the oarsmen plank. The vertical trim pieces above the plank are glued in place but not yet cut down to size. You can see the keel in place on the square bow. It looks a bit strange to me, but that's what the picture shows (at least one of them anyway)! I also added a two-step poop deck. Here she is with all the trim in place. The large, ornamental carving at the bow is only taped on for the photo shoot.
- 106 replies
- Kentoshi-Sen
- bottle
I thought it was always hockey season up there in Canada! Who knew that the ancient Japanese had an influence on Canadian hockey?
- 106 replies
- Kentoshi-Sen
- bottle
Thanks for the comment, Clare. I agree that there is not a lot of info about Japanese ocean going vessels for the earlier periods. When I started this project, I had a difficult time finding a historical Japanese sailing ship that was of interest. I just went thru your Kitamaebune build log. Very impressive work on an equally interesting ship! Yes, please attach the pics of the model from the Sea Folk museum. I would love to see them.
- 106 replies
- Kentoshi-Sen
- bottle
Thanks, Pat! But I'm thinking it might be time for a visit to the ol' eye doctor! 😃
- 301 replies
- Constitution
- Bluejacket Shipcrafters
Hey Mark! I'm late to the party, but got here just in time to read about your injury. You have made very nice progress so far on this build and I look forward to seeing you back in action! Get well soon!
- 257 replies
