Everything posted by Gregory
I don't see Bligh going anomalous on us...😀
Nice Bounty Tim I was reluctant to open up a can of worms by suggesting the block tackles on the bob stays are wrong for the period. Hopefully John will find there is a lot of help available here..
This is the basic run of a single/double tackle.. The hooks might not be present for your purposes. The stropping of the blocks might be simplified for the purpose of a model. The noose is a simplified version of how it is tied to the stem.. Actual practice would have been some type of splice and seizings.. A book like Historic Ship Models would be a lot of help with some basic rigging.. During a specific time period, how things were seized and tied off would not have changed a lot.. For the purpose of modeling, just making it look neat is a good place to start. Not sure what you are referring to, unless it is the running end of the tackle.. It would be handled similar to the lanyard on a deadeye arrangement..
Looking for a good "starter" pin vise set
Gregory replied to Capella's topic in Modeling tools and Workshop Equipment
That should work.. Just a matter of getting it threaded.. The chuck on this pin vise is about the same size.. I agree the jaws should be steel.. Just as a test I was able to ding the jaws on mine with a diamond tip scribe, but it didn't seem to penetrate as much as I would expect for aluminum.. These on amazon say they are carbon steel.. Good deal at 2 for $10.49 I would like to acknowledge at this point, that a possible downside to the chuck, is that it would be a little more crowding in tight spaces than a traditional pin vise. -
I'm a little challenged when it comes to small diameters, in that I just have to eye ball it after .5 mm or so. I see that #80 should be .0135. This little 3 jaw chuck closes essentially to .000, so the #80 shouldn't be a problem.. Here is some copper wire that is about .01, and it's not going anywhere unless it comes out smaller than it went in. I think you would be surprised at the quality of these. Chances are a lot of different 'Brands' are coming from the same factory, the one I have doesn't seem to be available at Amazon right now, but any similar one should do as well. PS Just noticed the specs say this is made of aluminum, so I guess long term durability could be an issue. I don't see any noticeable wear after over a year, but I mostly use the 1/8 shank micro bits.. -
Is there some reason why you feel I am not competent to judge the quality of this tool I am holding in my hand? I need a good reason to spend $100 for a tool that is not as versatile or any better made than a $20 tool. I judge a tool by it's ability to do the work I want to do, and a quality that means I don't expect to have to replace it any time soon. I would have been real disappointed if I had spent $100 on a set of Starretts and subsequently found this tool for $20. -
I don't see where the Starretts come with different size collets . Do you have to buy at least four of them to get the .04 to .187 pin range? I'm sure they are well made, but doesn't ease of use count for something? I used to have two of the double ended ones so I could have four different bits available without changing bits. I threw them away after I acquired this: It will hold anything from a cat hair up to 1/8 ".. The 1/8 is really convenient for holding a lot of different Dremel type accessories & milling tools if the need arises. Since I haven't had the opportunity to use some of the " higher quality " suggestions, I don't know how this compares in that regard, but it has some kind of baked or anodized finish that appears to be very well done. -
I really like this one. The 3 jaw chuck is really useful for a wide range of sizes without changing collets like a lot of traditional pin vise'.. 36 Pieces Vise Hand Drill for Jewelry Making Set If you get something like this, be aware those burrs at the top are brittle and break easily, but it is easy to get replacements. -
I have read a lot of different sources regarding Bligh and the aftermath of the mutiny, and I don't recall any mention of the launch after the landing in Kupang.. Considering the times, there would have been nothing special about the boat.
Less costly rigging rope for Pride of Baltimore II?
Gregory replied to Brewerpaul's topic in Masting, rigging and sails
Lot of rope making info here: Discussions about Rope Making Did you check out Ropes of Scale? Another MSW sponsor. Another sponsor is Crafty Sailor Until you start making your own, stuff like Syren rope is still a bargain at $50. -
For whatever reason, I was able to get a color change on 100% polyester rope with Fiebing's leather dye. It seemed to be permanent and resisted wiping off after it was dry.. It was just an experiment, as I have no reason to change the color of the rope I make beyond changing the color of thread I use..
Any dying option you use may be subject to changing over time, and you won't know how long until it happens.. Have you looked at BenD's rope?
Old Montgomery Ward Model Kit worth building?
Gregory replied to kwaheltrut's topic in Wood ship model kits
That's never stopped anyone before..😄 -
I need help repairing an Artesania Latina Dallas 1:50 model
Gregory replied to Zeus-cat's topic in Wood ship model kits
Sorry I didn't get back sooner, but didn't find what I thought I might have.. -
Untangling and rerigging or start from scratch?
Gregory replied to Rgpracer's topic in Masting, rigging and sails
Keith, I came across this when browsing through the drawings at Wiki Commons, and thought I remembered someone commenting in this regard. Whoever drew this didn't get the word..😁 Link to Wiki. -
The counter looks like an excellent preview of your usual planking prowess.. It's almost a pity the that the fancy stuff will hide your fine work in that area..
- 840 replies
- winchelsea
- Syren Ship Model Company
I will look in my stuff and get back to you later... -
The Master Korabel boats are similar to the Falkonet, and you can find them at our sponsor Crafty Sailor.
Waterways
Gregory replied to Ron B's topic in Building, Framing, Planking and plating a ships hull and deck
