Everything posted by Gregory
Artesenia Latina Printed Instructions Needed
Gregory replied to Aj73's topic in Modeling tools and Workshop Equipment
Downloadable instructions here: https://artesanialatina.net/en/ships-elite/486-wooden-model-ship-kit-hms-bounty-frigate-8421426228106.html -
Have you ever worked with copper leaf? The link above starts off talking about gold, but makes it clear it is copper if you choose it from the various options. It might make a good covering for your existing work. My experience is that it goes on almost like paint and is seamless. I used it to cover the the cupola of the companionway on my Resolution. It goes on as very shiny copper, but a patina can be created in various ways.
Copper plates
Gregory replied to Barbara's topic in Building, Framing, Planking and plating a ships hull and deck
Might be a little hard to find if one doesn't know their way around the site.. You have to go to the NRG home page and look at Resources, then find your way to "ARTICLES AND HOW TOS", then find the article by Gene. https://thenrg.org/resources/Documents/articles/CopperSheathingaHull.pdf -
MAKING EYE'S AND HOOKS
Gregory replied to Peter6172's topic in Modeling tools and Workshop Equipment
I've found the twisted end can be twisted into a hole like a screw and require no glue.. -
That looks real good! As long as you let the headstock move you shouldn't have to worry about breakage.. If it gets too tight it will start to kink..
Need help making eyes, loops, etc.
Gregory replied to Michael Scarborough's topic in Masting, rigging and sails
For those who want to be more challenged, here is a fine example by Johann . -
Goodwin shows a mouse on Alert in his AOTS.. He references a rigged model, Hawke, but I can't tell from the images if the mouse is on the model..
Don't forget, Chris is a member here and always quick to answer any questions...
You might consider one of the smaller boats from Vanguard like Erycina, Nisha Fifie ‘Lady Eleanor’, Zulu ‘Lady Isabella’.. You can download the manual for free for some if not all of these at the Vanguard site. The vanguard manuals are like practicums, and there are many logs here at MSW.. If you want to order in North America, another of our sponsors Crafty Sailor has many of these kits..
Back when I was building my first kit almost 30 years ago, and there was no internet, I came across the idea of beeswax dissolved in turpentine. I think it may have been Longridge's Anatomy of Nelson's Ships, or an article in Seaways. This allowed it to really soak the line, and the turpentine would evaporate after a while. I still had to use an alcohol lamp to get rid of the fuzzies. I still have that ship ( in pieces ) and the rigging line, I believe it is cotton, is quite stiff. It looks OK.. I believe the beeswax helps it from being affected by moisture, which is not a problem with polyester.. The fuzzies are not as much of a problem with polyester, depending on the thread. Seems to be minimal with the Gutterman I use for making my own rope..
I have experimented with bees wax but did not find it to be a solution to the fuzzies.. The flame ( alcohol lamp ) is the best way , but takes practice and care. For the UK, I have heard Amati sells pretty good rope. Available at Cornwall Model Boats.. Most kit supplied rope leaves a lot to be desired, If you are planning on building more boats, kits or otherwise, you might look into making your own rope..
Less costly rigging rope for Pride of Baltimore II?
Gregory replied to Brewerpaul's topic in Masting, rigging and sails
If you don't want to make your own then one of the sources already provided would be the way to go.. -
Why do you feel this is important at this point? Small variations can be taken care of with shims or fairing to get a smooth run of the planking. The only legitimate way to get symmetry is to have templates that you use to compare to both sides.. Did the kit come with bulkhead drawings.. These could have been used before assembly to make corrections. At this point they could be used to make templates.
'Knot' is also a verb..🙂
Interesting perspective. What is your basis for saying that? Every book I have about knots includes the clove hitch.. If I Google " clove hitch ", I get 2 million hits, an at least the first two pages all talk about knots..
If you don't count a couple thousand clove hitches for the ratlines..😃
This kit is on my soon to do list, and seeing where others go astray and how they overcame it, is a great learning experience. Not everyone is willing to share their 'mistakes' in a meaningful way. You have a great build going.
- 155 replies
- Medway Longboat
- Syren Ship Model Company
Short of replacing a plank, I would fill with a sliver of wood and sand flush.. Will not be visible on the upright model.
- 155 replies
- Medway Longboat
Just in case you didn't notice, the Cheerful kit only includes the bulkheads, keel parts and framework, including the full set of plans. It requires a lot of scratch work or additional mini kits for cannon, windless, gratings and such. It requires additional wood for decking, planking and masting. It is a great project when you are ready to do a lot of scratch work.
