Everything posted by Gregory
Tell Me Why This Is A Bad Idea ( If it is )
Gregory replied to Gregory's topic in Modeling tools and Workshop Equipment
I did that with my Microlux. Was easy to make with my laser.. But, one day I needed a new insert and thought I would try the tape as a stop-gap before taking the time to make one, it seemed to work OK, so I thought " Why go to the trouble to make one? ".. -
I always do.. Haven't had a problem so far with this.. What do you see as a problem, if any, with the tape as a zero clearance insert? -
Just a random picture.. I adjust the blade based on the height of the billet being cut.. What do you see as a problem with the tape as a zero clearance insert? -
There is a definite need for Zero clearance inserts for our table saws. Replacements are not that expensive, and it's good to have one for different blades. I've been doing this: I put a strip of masking or duct tape over the opening ( over default insert with about 1/4 clearance insert underneath ).. Hasn't caused any problems I'm aware of. Why might it be a bad idea?
Strange looking collet.. With no more information I would think it is upside down.. The collets I am familiar with look like this: The collet and retainer appear to be upside down. Looking at the manual I'm even more convinced.. If you continue un-screwing, the whole thing should come off if you can find some way to lock the shaft..
I just noticed the belaying pins in the image above.. Did those come in the kit, and are they wood? They look a lot better than most kit provided pins..
- 725 replies
- vanguard models
- speedy
Topsail schooner sail plans and rigging
Gregory replied to Dr PR's topic in Masting, rigging and sails
Have you seen this one? The Schooner: Its Design and Development from 1600 to the Present Paperback – March 1, 2001 It looks like it may be fairly comprehensive as well..- 104 replies
- schooner rigging
- Topsail schooner
My log explains that 'Resolution" is a name chosen by Corel with no resemblance to any actual ' Resolution ' on record. Also explained in my log, the lines are a close match to drawings found at the NMM for Ferret 1711. The drawings say it is " ... a cutter-rigged Sloop. " ... I try not to struggle too much with rope sizes based on tables or establishments.. I look at contemporary and other well made models and try to get a look that is well proportioned.
Don't remember exactly, but came across it somewhere. Think " rotten egg smell "... Has to do with outgassing sulfur compounds. If I were going to patina a ( model ) ship's bottom, I would enclose it in an upside down box or something similar, the more airtight the better, and have several chopped boiled eggs in there with it. Just a few hours should do it. Not as messy as having to brush something on, then wipe it off.
Le Coureur by PC52 - Mamoli - 1:54
Gregory replied to PC52's topic in - Kit build logs for subjects built from 1751 - 1800
I really like the look of the wood on the hull! -
Once the copper is all done, assuming it doesn't have some kind of coating on it, just clean it real good with acetone and it will develop a nice patina in a few months. If you want something a little faster, put it in an enclosed space with a few chopped boiled eggs.. Check every few hours untill it looks like you want. This is copper leaf that I put in a bag with a chopped boiled egg overnight..
This one? Masting and Rigging Spreadsheet Thanks for getting me there.
Do you by chance have a link for that? Searching for stuff here is not as intuitive ( for me anyway ) as you think it might be..
Isn't it really great when someone takes the time to explain something rather than telling us to go look in " $200 Book " .. This epitomizes the true worth of these forums..
I have to 2nd Blue Ensign on this. The reason most wood ship kits are never finished is because even the most simple ones are not simple. Take a look at the index of build logs. Note how many are " Finished " Note how many haven't been updated in 5 or more years.. Few people have the patience to see these kits through to the end..
This came up when I was working on my Mary.. Similar boats have double vangs..
I'm surprised you didn't get more any replies.. This must have slipped off the radar. There is an excellent topic regarding topsail schooner rigging. Here is the post that has some info regarding vangs.
James, what is the software you use for creating the manual? It looks very robust?
- 355 replies
- vanguard models
- Sphinx
Mantua "blue painted" photo-etched brass
Gregory replied to Alexisgm97's topic in Metal Work, Soldering and Metal Fittings
It's only too abrasive when it's too abrasive... The grit on these start at 1500 and is used for polishing. Grit 1500 2000 2500 3000 5000 7000 High Precision Polishing Sanding Wet/dry Abrasive Sandpaper Sheets - Germany, Pack of 12
