Knocklouder
Everything posted by Knocklouder
  1. Well the hulls are painted and they really look good to me. My only complaint is the color, I used Hull red from Tamiya ,instead of Copper Hull Red from Model Expo, Me does not ship to Canada, Pity. Lol It is a little browner then I wanted but, It will do. . The paint is excellent, it the first time I used that brand, it flows really nice. Here they areright out of the paint shop. I labeled them so you can tell the difference between the little Scientific Bluenose and the larger Billings Boat, lol. Then I put them up on the self so they could dry for several days, before touching them. Most of the deck furniture on the Billings Boat is made up, just going to repaint them, all the deck furniture has to be made for the Scientific Bluenose, plus I will start on the masts for both ships, so I have plenty to do and the longer you let the hulls dry the better. I will repaint both cap rails on both ship white, Rodney painted his Bowsprit mast white so I see how eazy it is to sand it off and stain it brown. He also painted his mast a darker brown but I will change it to a lighter wood color later. That's it for now shipmates, thanks for the likes and advice I recive here daily. Thanks so much. Knocklouder
  2. Good Morning; The ship's are back from the paint shop, so far I am really happy with the work. I thought today I would spray the copper hull red from Tamiya Color, but decided to wait till Monday to give it more time to dry. I will put the cap rails on the SB, and paint them white Rodney has the cap rail white on the stern and black on the forward one. The SB has them all white, I don't know which is right, but I will look into it and make them the same. Another difference os the Bowsprit mast, white on the BB but stain light brown on the SB. Oh well they will look good when sprayed. So I will start to put the deck furniture together, the Billings Boat needs a few grates put in and all the pieces repainted white and the Scientific Bluenose has to be made and painted ,so lots of fun stuff to do. And I can start work on the masts as well. Thanks for the likes and incouragement as I journey on. Knocklouder
  3. No Keith, sadly this was not his first offence, regrettable he's not getting out.for a long time. So painting is going full out today. Starting with the Billings, repainted the black and applied a clear coat. The Scientific is still in the paint shop waiting for second coat on the black, then clear coat, after that I going to leave it for a few days to really dry up. They is lots of deck things to make and paint. Once the black is done and the copper color is finished on both ,I think I will rig the Billings Boat frist, then the Scientific. Rodney has tray full of blocks, deadeyes, one hole blocks Up to four hole blocks . These blocks are way better than the ones in the Scientific, so I use then for it after , I am sure I will have lots left. Back to the paint shop, rudder repairs on the BB. the SM. Is good to go , this is so exciting, the spray gun is warming up, as soon as I read the instructions lol. Knocklouder
  4. Yesterday I cut all the pieces out and numbered them. Then started placing the pieces on but not glued down Soon ll the deck parts were placed then put away for later. I made and attached the stand, I figured if I attached it now then take it off ,I could repair any damages if needed , yes they were needed lol. Here is my stand waiting for the final installment. Coming together, time to get ready to paint .. A few more things to look after then I will start by painting the black first. Which brings me to, PART TWO: Rodney's Bluenose; I will repaint the black and change the hull colour to copper hull red. Most of deck furniture is installed, everything needs repainting The Billings Boat hull is finished like I say, just repainting what is there ,it is Rodney's work and I will leave it as is. Once the black is done both ships will be sprayed. Following @John Ruy Bluenose log, if I get close the that I would be a happy painter. His work is amazing, and one of the reason I chose to make Bluenoses The first time I looked at his logs I new I wanted to try that. I have a bit of a fix to do on the dreaded bow spirit mast, it starting all ready lol, at @Keith Black erging a nose guard will be made very shortly, lol, I will not breaking this one of 4 or 5 times. It is an eazy fix, once done the black on both ships.will start. I feel like a kid doing a 1968 model, this Scientific Bluenose is fun, I may look at getting others. I just wished I could buy them at 1968 prices and no---- tariffs . To the spray both we go Talk soon. Knocklouder
  5. The first coat of filler was applied last night. This morning ,I sanded it and gave it a coat of primer. I just brush on the frist primer as I know more filling then a spray coat of primer later, when she just about ready for the final coat, but lots to do before then. So letting the primer dry I will cut and number all the parts.some look pretty tiny. I find the bigger ofla knive works better than the smaller one. Lots of filling and sanding to go but loving every moment of the build. There are a lot of Bluenose logs here on MSW so I should not have any problems that's can't be solved by looking at them Thanks for looking in on my log, and for the likes and incredible support here. Knocklouder .
  6. I stained and sealed the deck, I also gave a coat of shellac to the hull. Now I can sand the hull and then apply some filler. The reason for the sealer before I filled it, is because if we filled first, the wood sucks the moisture out of the filler and it may fall out latter. Sanding just this little bit, she going to be smooth. Lol. The wood is balsa, and very soft and dry, brittle a bit but I have lots of filler. I cut the fantails out, broke one but fix able. It is going to be a slow process, but I take my time and cut slowly with many strokes , not just one cut. This wee kit is turning out to be a lot of fun. If I can I take My time , but I just want to build and build, there are ratlines to tie , sails to make, right after I learn how, lol. But the is a wealth of info here on MSW on sails, I am excited to try to make sails for this ship. It's an older model, but hopefully I can make it a little beautiful ship 🚢 ✨️. . Thanks for looking in, Knocklouder
  7. Welcome to my Bluenose log(s). Same model, two manufacturers . One is a solid hull the other is another ship that Rodney gave me before he passed away. I want them to look the same , so I will be painting both hulls together. Thats why two for one. Part One : The Scientific Bluenose. It is a solid hull kit with old lead deadeyes and dories. Both have the same history.. First up is to open the box and see what I got. The kit cost $16.95 in 1968, I paid $10.00. I put everything in separate containers, and looked at the plans . The plans say to use a utility knife and cut out the pieces. I did one and then used the scroll saw for the rest. Then I glued on the keel pieces Fitted the two decks, and glued them on. Applied some weight and let it dry. Tomorrow will be a lot of filling and sanding. After I install the forward and aft Bulwarks, the hull will be ready for painting. Then I will do a part two and get the Billings Boat ready to paint as well. Both will be copper hull red, as like @John Ruy did with his Bluenose. I don't know were PFCGP is now, apparently he got arrested for being under the influence of alcohol in Texas 🤔. He's not Canadian, come to think of it, I don't know what he is. But he is on a plane to somewhere and said find another Inspector He will be hard to replace It is glued down for the night, and meet Freddie Fisherman, my new ships inspector, my good freind @Gabek printed out this for me, he had a pipe but ,,Gabe had a bit of a problem with it and pipe never printed right, internet files not his lol. Anyway I personally like the non smoking Freddie, more on him later. wow what a frist post lol. Thanks . Knocklouder
  8. I just have to install the figurehead, then tie up the Bowsprit sail, the lines are run for it but not tied on. Anchors and flags are on and I just have to lash the ships boat down . Add a few rope coils and calling this boat done. I am starting to think of my next build so many choices, the First Mate says try and finish one that you started already ,lol, what would be the fun in that. Thanks so much for helping me along the way, its a wonderful hobby to be in. What to do next, another sailing ship, a schooner or two, a train or a Swedish war ship lol. Happy to be part of the crew, rumor has it that "Private First Class Gnomer Pile" is on his way back and should be able to start his old job of Ship Inspector. Time will tell, so let's rap this one up ,take a few final pictures and put it in our Gallery. Thanks so much. Knocklouder.
  9. All the rigging is finished, except the Bowsprit sail. Time to clean up ,next I will add a few rope coils here and there as well as tie down the ships boat. Anchors are in the mix soon as well. Sir Drake likes the rigging, but says I might have missed a few lines lol. so with that the Bowsprit is all that's left to rig, blocks are there just have to run the lines. After I get the figurehead installed. Oh yes the ships boat and a few more crew members glued ito place I am going to call it finished soon. I told myself when I was done rigging the Golden Hind I would build something first before finishing rigging on the Astrolabe 1812. I really want to get back to the rigging of the Astrolabe, so I plan to build a Bluenose Scientific an a Billings Bluenose at the same time. Up until I get them to the rigging stage, then I come back to the Astrolabe. Thanks so much for popping in, likes are appreciated lol. Didn't get her done but put a good dent in her. Extras at this point will help, well placed rope coils, crew members and Rum kegs and treasures . Knocklouder.
  10. Good luck on your journey, the Duchess of Kingston is a wonderful ship to built, the quality of the material and the great instructions are hands down the best I have ever done. One peice of advice hide the knight figurehead until the last possible second to install lol Pulling up a chair as they say hope you don't mined Bob M.
  11. Did I every mention that I am having the time of my life . Slow start to the day but hey I am loving it. This little kit is nice to put together and painting to was so much fun. However, when it comes to rigging, no blocks of any kind, I put most of this kit together by following their plan lol. I have not learnt anything in four years that plans may be WRONG lol. Oh well. One of the benefits of modeling is my reading skills have improved dramatically but my understanding is lacking. Lol. starboard side is rigged up to the Bowsprit mast, I decided to leave the Bowsprit sail until after the figurehead is installed. That and I have to add some racks for tieing the Bowsprit rigging to the ship. Speaking of rack, Keith I don't think that would be historical correct, lol. I will run it past my printer, but it's his birthday today and I don't want to bug him to much. He's at that age you know , lol. Anyway let's flip this ship and rig the portside. It would have been a lot easier if I had tie all the blocks to the mast first, shaking syndrome, and threading blocks I am at that age you know. Lol. The port side still needs six single blocks, but easy to reach. Things are looking good for Sunday, except the Bowsprit sail, small revisions are needed. Thanks for looking in, Bob M.
  12. Only 26 more lines to run then tie them all off, then anchors, ships boat, done lol. I have been looking into the figurehead, the kit come with no blocks, no figurehead no ships boat, no thimble blocks , no heart blocks. I thank my God for my friend who is a wizard at printing things. I have to be careful what I say around him because when he hears that I need something he will print it lol. Here is the figurehead he is working on. It wont be exactly like this and will be attached a bit different . I don't know where I got this picture but it is from a Golden Hind build someway. I am only using the idea not exactly as shown. plan is to file the bow flat, about half way through about. Once flat the figurehead will be pinned to it. Should work. The body is slowly healing, at 70 they say it takes longer to heal, lol I don't know about that because it seems something always hurts 😅 🙃. I got to spend a few hours today in the shipyard, the weekend looks great for time in the yard, so a push to get'er done by Sunday night, we will see. There not much to do now that the 5th season is over lol. So I should get lots done. Talk to you Sunday.my friends . Knocklouder.
  13. Nice work Bryan, I hope your new shipyard is high and dry lots of reports of Tennessee flooding, no water here yet.talk soon 😞 Bob M.
  14. I will be building this Scientific Bluenose kit, it doesn't even have any maple leafs on it. I have a Billings Bluenose to do as well, no flag with the kit, but it shows an Ensign on the Mizzen mast , no maple leaf either. Good luck on your journey, joining you soon lol Knocklouder Pulling up a chair as they say.If you don't mined.
  15. You have a lot less filler on your first hull than My first hull. Nice work. I study this link till the cows came home, and still have trouble 😐 https://thenrg.org/resources/Documents/articles/LiningOffYourHullPlankingTutorialAndFan.pdf It is in the MSW article data base, it help me lots. . Bob M. Good luck Meekes
  16. This is the place to be , lots if info in the data base, and tons of friendly people here to help . You'll See!!! Bob M.
  17. I have taken the Hind out of the display case and have her back on the bench . I have had a few set backs nothing serious, I fell awhile ago separated my shoulder, that's getting better, now I blew a knee, got a 850.00 brace for my knee that only further my pain in my wallet 🙃. I recived my order for rigging lines so now I can continue on.my journey. plan in hand, time to get all the blocks and line install, lash down the ships boat anchors and flag done. Lol Coming up to four years that I have been modeling, time flys when your having fun. And being here is the most fun one could ever have. Thanks so much for showing me how. Talk soon my shipmates.. Bob M.
  18. Nice job on the planking, you can always paint over the Shellac if you dont like the way it turns out, but I have a feeling it will look great with just the Shelac Knocklouder
  19. @Capt. Kelso I would recommend the Serv-o -Matic machine for sure. Buy it lol. Knocklouder
  20. I agree with Francois, the second picture looks more open . Two votes for number two picture. Tuff choice thought. Great work . Bob M.
