HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 64 donations so far out of 49,000 members - C'mon guys!) ×
HIPEXEC
Everything posted by HIPEXEC
  1. I've already bought my beeswax even though I am no where near rigging.
  2. I'm "dry" fitting the frames of the lower gunports before gluing them in place. Constructo calls for me to fit the lower and upper frames pieces before the side pieces.
  3. I'm enjoying watching your build, especially since it's a Constructo. How did you drill the hole for your bowsprit? I don't want to get too deep into finishing the hull and then drill the hole. I'd rather do it early. I'm rather clumsy when working close with power tools.
  4. Whatever you do....do it carefully! Think and plan it. Good luck.
  5. Here I go again! Having to play chess with a poorly fitting piece provided by Constructo.. The pre-cut stern is about 2mm too big in the vertical even though I built the frame exactly as it appeared in the plans. Now I have to "play chess" all the way to the last page to make sure I don't cut off too much to finish the veneer planks. If the plan called for me to finish it with full size planks...it will fit. So now I stop and think and thinks and think. I'm going to skip the stern and frame the lower gunports while I think.
  6. I used a number two pencil sharpened to a very sharp point. I sharpened the pencil between each row to make the nails and seams as tight as possible. It turned out well for my level of building skills (second build). Some of the very advanced builders go to great lengths with deck planks.
  7. I finished framing the upper gunports. Very tedious work. Now I can finish trimming the deck since the upper gunports are not fragile now.
  8. Don't breathe any wood saw dust! You can get very good masks at Ace Hardware or even Home Depot. Whatever you do, don't breathe the dust from the many exotic woods we use.
  9. Tedious framing. My new tool has given me better quality woodworking, but at a price. It is very slow, tedious, work: measure, cut on miter box, square an end, measure again, sand-it, place it, then repeat for the two remaining pieces, then glue in place carefully watching for alignment, squareness and glue drips. Wow. At least the results are very good. You can see the difference by looking at the ports to the left. I can see I'll be framing for a while.
  10. Here's my newest tool....a Sand-it. I hope it gives me the square cuts I'll need to do all the fine carpentry work needed to finish my model. I'll have to practice, though, since there is no power source to run the sander...my right hand has to do that while my left hand feeds the part? Practice will make perfect...I hope. P.S. I find that I am all thumbs trying to fit these tiny frame pieces. Also, I find that my engineering is all off. I'm trying to make perfectly square frames when I find that the gunwales are far from square and perpendicular. So, I settled on gluing the sill or base piece first, then cutting one vertical to get the exact angle at the sill to give me a perfect match. All very tedious but rewarding. I'll have to sharpen my engineering skills for future pieces.
  11. The second layer planks are very thin. On my first build, I screwed up the first planks so bad that it was a disaster. I was saved by the second, veneer planks. On my second build, I worked very hard and the first layer turned out great, Good luck.
  12. I'm building a Constructo Constitution and read the instructions to lay whole planks, then scribe the planking effect. I did that and it turned out okay.
  13. I decided to invent my own way of drilling all aspect perpendicular holes in the deck. I made a jig that lays flat on the deck and only lets the drill bit make a completely perpendicular hole. I also put some masking tape on the bit to let me know when I'm deep enough (10mm). I also put tape over the prospective hole site to prevent splintering. What do you know, it worked!!!
  14. I need to drill three holes that will be perpendicular to the deck from every aspect. Any tips as to how to do this. I'm about to build a drilling guide that will sit perfectly flat with a perpendicular hole in it. I have no idea if this will work. I would like to hear all ideas. My first build the masts had a rearward rake and it took me forever to get them parallel and aligned. The perpendicular ones should be easier?
  15. The plans call for me to add more realism to the deck planks. To make it easier, the plans called for me too lay full length planks, which is what I did. Then, I scribed cuts in the planks simulating the actual way planks are laid. Now, I just added the nails. I tried several methods and didn't like the outcome. I tried drilling with a mini drill bit, but it splintered the planks. Then I tried a very pointed awl. That method didn't give me nail-like impressions. So, I got this bright idea to sharpen several #2 pencils and try simulating the nails with them....the result was the best of everything I had tried. Today, an old model maker friend looked at them and actually thought I had hammered nails in!
  16. How in the world did you do that blond trim on your transom? It's perfect wood work! Also, how did you make the nail holes in your deck planks? I haven't found a good way to do mine yet.
  17. I framed a few of the upper gunports and they are much stronger. I'd really have to exert a lot of force to snap them. Not like before. I don't think planks held by tape would do the trick. These gunports have to be framed anyway, so I'll just do them all and feel much safer. I have to put some deck trim around the base of the gunwales on the inside. That would be tricky if I didn't support those gunports. It will be close work with my thick fingers working right against the gunwales.
  18. I started framing the upper gunports the old fashion way. A mitre box and eyeball sanding the ends. Very tedious! I just ordered a Micro-Mark "Sand-it" which looks like will give me furniture finish cuts that will fit nice and tight. Augie gave me the tip, so thank you Augie.
  19. Gunwales are complete. Now I have to carefully file and sand the excess wood and glue off. Next, I'll skip way ahead and install the frames on the upper gunports for added support so I don't break them while adding deck trim, bow stems and rudder post, aft cabin windows and stern windows. Then I'll install the top rails.
