Everything posted by Rustyj
I've started on the main rails. As you can see there are multiple pieces and layers. The cuts were perfect and they went together very well. Once assembled the inboard side needed to be sanded from 5/32" at the timberhead to 5/64" at the forward end. The one on the left has been sanded to size and the one on the right has not been sanded yet. Here the headrail has been placed just to see how it looks.
- 642 replies
- winchelsea
- Syren Ship Model Company
Beautiful looking rudder Glenn. It also highlights the great planking job. I thought I was the only one who counted up all of the pieces, holes drilled etc. Also, a word of caution as you move the hull around while working it's really easy to bang the rudder and knock it off. Not that I know from experience. Nope not me. 😉
- 840 replies
- winchelsea
Yes Chuck one more! It's kind of a happy sad moment! Thank you Matt. They really help complete the decks look. Thanks JJ, You'll be here before you know it! Thanks to Chuck always supplying extras I've repaired the damaged deadeyes and placed the eye bolts. It's on to chapter 12 and the head rails!
- 642 replies
- winchelsea
Thank you Mike, Chuck, Glenn and Grant for the kind words. Mike your definition of fun just might differ a bit from mine. Grant I'm way more human than you think. In one form or another this is a daily occurrence! I've finished the gangways. Like Chuck I glued the long gangboards flush to the caprail prior to adding the knees. I figured that was the only way I could ensure them being flush with the caprail. Then I took the laser cut newel post, cleaned it up and added the fancy rails. I just have to fix the broken deadeyes and add the eye bolts and chapter 11 should be complete.
- 642 replies
- winchelsea
I just caught up with your log and she's looking really good!
- 587 replies
- Indefatigable
- Vanguard Models
Thanks Glenn and JJ. Still got a way to go and more updates to do. Speaking of which here is another one! I have shaped the swivel gun stocks and mounted them according to the plans. The swivel guns were also attached to the yoke and added the handle. They were coated with weathering power and the two at the bow were placed to see how they look. I'll wait a bit to add the rest or the swivel guns as I have a tendency to knock parts off a model as I work. Example to follow.🤪 Now I started to put together the gangways. The first part of the platform was assembled from laser cut parts and glued to the bulwarks and the breast beam. Now while pressing it in place someone not to be named was not aware of where they were placing one of their fingers and while applying pressure said finger pressure snapped off two deadeyes. Oh well I didn't get enough of the deadeye work so now I can do two over again.
- 642 replies
- winchelsea
Great job Glenn. That's how I make them too. And don't worry you'll get more opportunities to make even more later on!
- 840 replies
- winchelsea
Hi all, Been a bit since my last post. Busy time of the year for me. I've moved on to the boarding ladders. I cut them on the table saw then used files and sanding sticks to finish the shape. The top step is wrapped in the frieze before placing on the hull. To determine the positions of the steps I cut some scraps to the desired width and tested the fit. I also clamped a strip to the hull to keep them in a straight line while testing the fit. And here they are glued in place. I've also weathered the swivel guns and started shaping the swivel gun stocks. More to come soon!
- 642 replies
- winchelsea
Beautiful pictures, just like your model work.
- 840 replies
- winchelsea
That's an excellent model and diorama Ron. Very well done!
- 542 replies
- Sphinx
- Vanguard Models
(and 3 more)
I just caught up on your wonderful work Kevin. Well done! I'm trying to figure out how to work her into my modeling schedule. You are not making the wait easy!
- 443 replies
- Indefatigable
- Vanguard Models
Oh this will be lots of fun to watch!
- 648 replies
- Indefatigable
- Vanguard Models
Everyone has used all the good words to describe your decking. I'll just say well done!
- 840 replies
- winchelsea
Congratulations on finishing Mike. You have completed one fine model. Your build log will be a superb guide for all who follow!
- 607 replies
- winchelsea
Yes, those planks really do stand out. Remember there as a lot of stuff added to the deck that would obscure some of the planks. If I were going to do it I would use a sharp xacto or scalpel blade and cut just inside the seam/joint. Take the center portion out and then carefully work my way out to the seam/joint. Hopefully that would help minimize the damage to adjoining planks. A metal straight edge would help too. Good luck if you decide to do it!
Thanks Chuck. Fiddley yes but still fun!
- 642 replies
- winchelsea
