Rustyj
Everything posted by Rustyj
  1. Thank you Glenn. I chose each plank carefully trying to get ones close to the same color, sanded them and thought they were very close. I applied the WOP and boom the absorption as different for various planks causing both light and darker planks. Oh well I tried. Also thanks all for the likes.
  2. That is really great Chuck. I always have trouble trying to get those angles correct. Usually failing miserably.
  3. Hi all, Well the trip was wonderful, it's over and back to work. Progress has continued on chapter 10 with the quarter deck hatches placed and the deck planked. Pretty much a repeat of the fcastle. A lot of dust to clean up and paint to touch up though.
  4. At least you are dropping something into the hull never to been seen again intentionally unlike some of us! Looking forward to seeing the deck work commence.
  5. They say pain is good and in this case I agree! This is really going to be so good. I have the books and have wanted to build the Speedwell for some time now! Thanks Chuck!
  6. Wonderful job on chapter 3. You'll enjoy You moving inboard and I look forward to seeing it progress.
  7. Great to see you get the frames finished. I'm looking forward to the raising. 😁
  8. Thanks Matt and Glenn! Thanks bdgiantman2 we are on our way there today!
  9. Thanks Vlad! This will be the last post for about two weeks. We leave tomorrow for a vacation in the San Diego area. I've added the eye bolts, spanshackles and chimney cover boards. With chapter 9 completed now I've started chapter 10. As I'm leaving very soon I figured I do the hatches instead of starting on the planking. I'll see you all in a couple of weeks. Behave while I'm away! 😂
  10. For me, if I did it Navy board style you could keep the un-needed parts without altering the price. I just hate to have material go to waste. Anxiously waiting!
  11. My best wishes to you Bob for a smooth procedure and a speedy recovery!
  12. Thank you Don, Bob, Glenn and Joe and all the likes too. Much appreciated. I'm working on the eye bolts, spanshackles and cover boards for the stove stack and chapter 9 will be complete!
  13. Hi Mike and welcome aboard. I enjoyed looking through your Agamemnon build. Beautiful workmanship! You're off to a great start and I look forward to seeing your work on the Winnie.
  14. I moved on to the fcastle rail and knightheads. The knight heads are laser cut but the tops needed to be shaped on all four sides. The laser cut rail needed to be sanded smooth and the edges softened. This is where I ran into another oops moment. I hooked the end of the rail snapping off the end two slots. I broke out some sheet stock and remade the first three slots. Why three you ask? This way the joint would be over the cathead and covered by the cat block. Just in case the seam was visible plus added strength when glued in place. The fun part of the cat block was it needed to be sanded to the curvature of the rail. Not difficult but I needed to go slow to make sure I didn't over sand! Once everything was test fitted it was painted and glued in place.
  15. That was my though too. Just wanted the group opinion before I adjust them. Thanks!
  16. Congratulations on a great model and a build log that was enjoyable to follow and will be a tremendous help to others who follow.
  17. Well, I went back and rounded off the 1/32' X 1/32" strip to make the waterways. They were added as well as the breasthook. Next I assembled the catheads. Like the belfry take your time and they come out looking nice. I then cut out the notches for the catheads. They are placed but not glued. I'm trying to determine if the angle they are at is correct. The cathead sits flush on the margin plank but they look a little high to me. Hmmmmm.
