Everything posted by Rustyj
Hi Chris, I'd really be interested in something like this too. It looks like a really nice mind clearer and as you said can produce a great looking model. If you do decide to do it I'll be glad to follow along!
- 290 replies
- confederacy
- frigate
Hi Chris, I'm asked why I have 2 or 3 builds going on at once. It helps me from getting "tired" of a build especially a long term (3+ years) scratch build like the Confederacy. Mix it up, get the plans, have fun with the kids, do what makes you happy! She'll be patient and wait until you are ready to finish her. Nothing worse than forcing yourself to finish a model. Especially one that you have done such great work on.
- 290 replies
- confederacy
- frigate
Ah Bob it's so nice to stop by and view your work. Love It!
- 1,477 replies
- essex
- model shipways
Thank you very much Joe, Bob, Ben and Jim and to everyone who posted a like too! Ben, I didn't mix up the wood types but I could have as it's going to be painted. All throughout the wales I used some old pieces I had left over and cut them up. The colors varied greatly from gray/brown to light brown and grainy looking. I figured it was a good place to use up some "scrap" boxwood up. Here is the anchor lining done. On this side you will noticed I took a lazy way out. The top piece over the black strake was about a 1/64" too narrow and seeing again that it's going to be painted I just left the gap and filled it. Now the directions call for painting the wales now prior to planking the hull. My thought is I'm a rough hull planker as I put in my lap, tip it upside down ect. I usually scratch the paint all up and have to repaint it. So I'm just going to apply one thin coat just to see if any imperfections show up and then fix them. Then it's on to laying out the planking belts for the hull, mill the wood and then plank it. That will be good for 2-3 months of cussing.
Thank you Bob and Mark. Much appreciated. Well I've commenced with adding the wales. The second layer is 1/16" x 5/32" just like the first layer of planking. The black strake is 1/32" x 5/32". At the bow the black strake is sanded down to 1/64" thick while the wales well be left slightly thicker than that. The anchor lining was traced onto the wales and black strake. The lining over the wales is 1/32" thick while the portion over the black strake is 1/16". Here all but the piece over the black strake have been added.
Hi Pete, Sorry I some how missed the finish of the Eagle. As always you have produced another wonderful model. I'm sure your friends are thrilled to have it.
USF Confederacy by Rustyj - FINISHED
Rustyj replied to Rustyj's topic in - Build logs for subjects built 1751 - 1800
Hi Harley, chizelguy and Dave, Thanks for stopping by and dusting off this old log. It brought some great memories. Anyone who is going to build her won't be disappointed.- 149 replies
- confederacy
- frigate
Hi Mark. That is some really nice work on that framing as well as the repair work. It's always fun making more frames once you thought you were done huh? I also like being able to use the framing jig upside down and right side up. Did it a couple of times and thought it was great.
Hi Ben, I think it is a bit of both on my part where I didn't duplicate the run of the gun ports on both sides as close as I thought I did and then the laying of the planking may have had some minor creep to it too. We're talking 1/32" to 3/64". The good part is the run of the planks is uniform at the top of the frames. The planks all landing on the one frame were due to my error in laying the first few rows at the bow I mentioned awhile ago and instead of ripping off all the planks I only went back to the point that the run went astray. This part will be covered by the second layer of planking so I took the easiest route to correct it. Thanks Chuck. Having a lot of fun here when I can get some free time. Hi Augie, Thanks, imperceptible it's not, but acceptable it is . Once she's done 95% will be covered or blocked anyways! Thanks everyone for all the "likes" too it is appreciated.
Well the starboard side has the first layer of planking has been completed, rough sanded and a light coat of poly. The planking came out fairly well but I am disappointed both side do not mirror each other exactly. There are some slight variation in how the planking hits the gun ports. A little more sanding needed on both side and then I can start the wales planking.
Hi Bob, I just got caught up with your work and as always it is exceptional. I really like the way you planked the deck! It gives you the best of both worlds. I've always hated covering up all the work we do below decks.
- 1,477 replies
- essex
- model shipways
Hi Augie, That is a very good job on the great cabin floor and doing it with hand tools to boot. I'm glad you did it! The hour counting is interesting too. People ask me how long it took to build and all I can say is years. Now once you are done I'll have a clue. Thanks!
- 2,191 replies
- confederacy
- Model Shipways
As I sing Happy Birthday to youuuuuuuuuu dogs whine, kids cry and glass breaks. Good thing you can't hear it! Have a great Birthday Mark!
Hi Ben, I agree with Grant. It seems you are grasping the the difficult Hawse timbers very well. I also like how you are not rushing and not stettling for good enough. Nice job!
- 889 replies
Thanks Dirk and Rich everyone for all the likes. Chuck S. The wipe on poly acts as a sealer so if you want to do any staining you would need to do that first. You also want to avoid applying poly to the area where the second layer for the wales go. That's another reason it will all get another round of sanding.
Hi Dave, Thanks and once released I'm sure you won't be disappointed. I had a little more time in the shop thanks to some thunder storms! I've applied a light coat of wipe on poly. This helps me determine high and low spots that need more sanding. I will now clean up the highs and lows and then apply a last coat of poly. After that I will finish the starboard side and then on to the second layer of planking for the wales.
Very nice Augie! Isn't amazing how we create something like that and then cover most if it?
- 2,191 replies
- confederacy
- Model Shipways
Hi Bob, I had a free moment and got caught up on your progress and as to be expected your workmanship is outstanding. I too really like the way you used minimal planking so the framing and lower deck work can be seen. You made it flow very nicely and not look chopped up. Well done. Hey Sam, Bob might not want to design kits but he would be great at proofing a kit prior to release!
- 1,477 replies
- essex
- model shipways
Thanks Augie and Bob. Hi Ben, The only issues are from my failings. Everything else is spot on. Sweep ports oh I can't tell you how happy I was when Chuck said they were not on this model! Hi Chuck S. There are four strakes of wale planking. The second layer of planking will be 5/32” x 1/16” strips just like the first. The black strake will be 1/32” x 5/32”. In the instructions Chuck notes that "At the bow, the total thickness of the black strake was less than 1/64” as it butted into the stem. The wales were left only slightly thicker than that." Thanks all for you visits and all your comments and likes.
Hi All, I have been plugging away at the port side planking. I have completed most of the first l ayer of planking and given it a quick sanding with some 120 grit sandpaper. Once it is finished I'll sand it down to 400 grit and then add the second layer for the wales. Then it's over to the starboard side! It's always slow going this time of year but that's ok.
Hi Augie, very nice work there. Then it's on to more fun planning the deck.
- 2,191 replies
- confederacy
- Model Shipways
Hi Ben, I just got caught up and you seem to be making some nice progress and learning a lot too. Very nice work. Have a safe one and I'll impatiently await your return.
- 889 replies
