Everything posted by yvesvidal
Waterline markings have been set. Now, I need to clear coat the entire hull, before starting the weathering and painting the details. Yves
Thank you Katuna for all the praises and compliments. As a matter of fact, I have also been following your build log on the AMP web site and find your attention to details absolutely incredible. I am actually planning to use some of your research and Tore's publications to increase the level of detailing of this model and make it closer to the prototype. Tore, Prince, you and a couple of other guys are an incredible source of information that makes the building of this model, so much more entertaining. Keep up the good work and let's finish that Engine compartment. Yves
Congratulations. Well deserved for such a beautiful model. Yves
- 82 replies
- carl vinson
- trumpeter
A few pictures of the completed hull, in intense daylight: This is an interesting play of shadows.... And some deck views: Yves
Jonathan, To be honest, I have not thought about all these details yet. The Mounting base will be very similar to what you are seeing ow, but with longer Brass tubes. I also have to design a base that can include some electronics and switches, for the lights and motors. We will see. This is still far away. Yves
Wonderful. These are some of my favorite boats and I hope to build one at the same scale, one day. I will be watching with a lot of interest. Yves
Deck has been painted: The bow and stern platforms are painted with Tamiya Dark Grey XF-24. The rest of the deck is Tamiya XF-64 to simulate the German tar that was spread on metallic deck to prevent sailors from slipping at sea. That tar, originally darker was fading very rapidly with the sun light and the salt. Once the hull has been clear coated, I will try to add some shadings and washes in different locations. That PE deck from RCsubs really stands out. I have been watching some pictures on the web, of the same model where the Trumpeter plastic deck is painted.... and there is absolutely no comparison. It was a lot of work but worth every dollar and drop of sweat. The entire hull is now ready for the waterline decals (just received them from England) and a final mat clear coat to seal everything before the big challenge of weathering. The decals from AMP: Once set on the dark hull, they will be more visible. Yves
I have been trying to finish the deck, before painting it. Lots of small details and PE parts went on it: Then it is masking time: And a coat of automotive primer to harmonize the whole: Once, the Primer is dry, I will be in a position to start painting the deck. Some pictures: Yves
Comment ai-je pu manquer ce thread? FrenchGuy, vivant a Lexington, MA et passione de modeles de bateaux. Ce ne pouvait etre que Stephane Greppi. Comment vas tu? Je suis impressionne par tes realisations et la Barque a vapeur Alexandra (c'est aussi le nom de ma fille) est absolument superbe. Je n'ai pas fait grand chose mais j'ai un ou deux threads sur ce forum: Celui-ci etant le plus actif pour lemoment. Au plaisir de te lire. Yves
Pittman does some very nice and powerful motors, too. They are built in the states, but are more expensive. Yves
- 52 replies
- dumas
- Chris-Craft
Working from Bow to Stern, little by little.... Things are getting very delicate. This large hull must be manipulated with care. Yves
Nils, this is superb. I love the models that shows the inside intricacies and offer some educational contents. You need to replace the engine mounting screws with some mini-bolts. They look way out of scale. Yves
Still a few small updates, working on details that make a difference: 1) The anodes on the diving planes, provided by the RCSubs PE set: 2) The menacing teeth, used to cut nets and underwater cables (again pimped up by RCSubs PE set): 3) The rings to attach the crew/sailors when working on untangling the propellers or doing the maintenance of the rear diving planes (Intermountain parts in 1/48th): 4) And finally the net/cables cutter on the top of the bow (again pimped up with RCSubs PE set): Little details, very fragile, but which are slowly turning this kit into a realistic Type VIIc model. Yves
There won't be much in terms of updates. I am waiting for parts and paints. Can you believe that Trumpeter omitted to provide the Waterline markings on their (otherwise nice) decals sheet? I realized that yesterday and was really surprised by this mishap. Fortunately, I found a British company Accurate Model Parts that do sell the Waterline markings as well as a few other things for the Trumpeter kit. I also have on order some Tamiya paints and clear coats and do not know how long it will take to come here. Tamiya products are starting to be very rare if you want a color other than the Fluo and Neon Orange and Green. Yves
Glad to see you back on this lovely model. Most likely, one to become the ultimate reference! Yves
Major progress on the hull: the paint, or at least the first phase. As indicated before, I decided to go with Humbrol acrylic paints for the hull. These paints are getting a very bad rap on the Web and in the forums, because they are a far departure from the Tamiya and Vallejo paints. They are very thick, almost gooey in their appearance and require a significant amount of thinner to airbrush them. The good part is that they have the right color, that is very hard to find anywhere else. In retrospect, I should have used the enamel paints from Humbrol but decided to stay "green" as most as possible. The paints were ordered from Europe as they are not yet easy to find in the USA. The top of the hull requires the Matt 64 from Humbrol, which is one of the closest color to the Hellbrau used by the German. The bottom of the hull has been determined by a few Expert European modelers to be the following mixture: Two cans of Humbrol Matt 96, plus one can of Humbrol Matt 33 and one can of Humbrol Matt Black Green 40. Now, for the thinner, Humbrol recommend of course their own thinner. The problem is that it cannot be shipped to the USA. Therefore, I tried different mixtures before committing to the paint on the model: - Water....runs too much and makes the paint translucent almost. It would require a lot of layers which is not the easiest thing to do on such big hull. - Tamiya thinner..... Worked alright, but somehow, my airbrush clogged a lot. I suspect that the Tamiya thinner was not strong enough to thin the clumps of that very thick paint. - 70% alcohol ..... I suspect that this was too much alcohol and the paint was dry before hitting the surface. After searching the various foreign forums, I finally found the ideal thinner: Vodka! Yes, Vodka is 40% alcohol and mostly water. Some people are claiming that it works very well after a glass or two.... Not wanting to run to the local ABC store, I fortunately had a left over of 50% isopropyl alcohol and decided to use it. With about 35 PSI of pressure on my Paasche, the paint sprayed very well and did not cause many runs. Needless, to say, you need a very large bottle under your airbrush to contain 4 cans of paints and the equivalent in volume, of Vodka. The top portion of the hull was done first: A lot of masking has to take place: And finally: Now, I need to learn the skills of weathering and rust.... The Deck will be painted last, as it still needs a lot of work and details. Yves
Yes, these type of Submersibles were really tight and small. The watching of Das-Boot movie will convince you of the almost inhuman conditions these poor sailors were enduring. Yves
Kevin, Fine soldering is an art form which has been lost to the Western world with a few exceptions. I collect brass train in O scale and most of them are hand soldered in Korea and sometimes in China. Japanese used to be good at this art form, but costs have taken the production of these models to Korea and Viet-Nam. It is extremely difficult and requires precise tools: - Gloves to insulate your fingers from the heat and to avoid staining the brass. - Resistance soldering unit for most small parts. - Iron for larger parts. - Torch for very big parts. Quite often it is necessary to build jigs and special fixtures to dampen the heat. It explains why these steam engines built by hand retails for more than $2K each and prices keep going up. I have used all the above techniques with various success and sometimes, I find JB Welding the best way to solder (Epoxy Glue) parts with success. I am not sure if you can find JB Welding in the UK, but it is basically a two tubes epoxy compound, with extremely small metallic flakes in suspension. The following link explains some of the phases of building a brass model: http://www.3rdrail.com/makebrass.htm Yves
Superb work on the hull. Quite a departure from the oversized plates of the old Matchbox mold. Yves
