Everything posted by yvesvidal
For a first attempt, it is lovely. Fantastic job. Yves
- 8 replies
- BlueJacket Shipcrafters
- Swampscott Dory
So, Christian, what is the next project on your list? Another vessel designed by Chuck P. or something else? Yves
- 550 replies
- confederacy
- model shipways
Popeye, No decals on this kit as the original prop from the movie did not have any. For more exterior "contrast", the AZTEC set provides some masks that add "camouflage like" patterns to the vessel. I am not a big fan of these and like the Stanley Kubrick's purist lines of the Discovery. I will paint some panels as in the movie, but will stop there. No weathering either, as there is no air, and very little dust to attach to this kind of machine in Space. Yves
Superbe realisation Christian. Bonne Annee et bonne sante a vous. Yves
- 550 replies
- confederacy
- model shipways
Propulsion block more or less completed. The only things remaining to be done are the exhaust plates with the PE grills. In the meantime, I have sprayed the sub-base using Tamiya German Grey: Hopefully, this color will provide some depth and delineate the various panels, when spraying the light gray and white on top. Yves
Moving along with the completion of the propulsion block. Lots of parts, but the fitting is exceptional. This kit is very well engineered. This is the anchor which will be used to hold the model from the rear and to feed the negative side of 12 VDC. It is a 3 mm special nut. I will try to show a picture of the part, later on. Yves
Rafale by CDW - FINISHED - Hobby Boss - 1:48 Scale
yvesvidal replied to CDW's topic in Non-ship/categorised builds
Thank you for the very clear explanations about your technique. This craft looks stupendous. Those French have a way to decorate their planes that is quite unorthodox. Blame it on the sun and blue sky of Provence..... Yves -
The thrusters are almost complete. Inside each one of them, there is a flickering yellow LED. After trying these LEDs on my bench, I realize that the current drawn by each one of them, varies constantly because of the flickering. Therefore, they cannot be serialized or daisy chained. They operate at around 3 volts, under 10 mA each. Since the whole enchilada will be powered with a source of 12 Volts DC, it is necessary to drop about 10 Volts in a resistor. 1 KOhms is perfect for that purpose. First, the lower shell of the rockets are glued on the rear bulkhead: The main rod is being opened in three places: Ground wire, Plus wire and the two tiny wires leading to the central LED. The holes are done with a round file, then semi-round and finally a bit of 2 mm, to provide a less sharp opening for the wires. The rear bulkhead has been reworked: pins on each side, have been shortened and drilled to allow wires to go through. The inside of the thrusters is painted black, to simulate the intense heat and combustion taking place in them. Wiring is neatly arranged, as much as possible. None of the plastic parts are glued yet....the wires are holding everything together. The lug on the top of the picture (right side of the engine block) will be the negative side of the holder. The green wire brings the - to the front module, through the rod. The yellow wire feeds the rear engine block with the + side, coming from the holder that will be located near the front sphere or living quarters of Discovery. Verification of the diodes: It flickers well and provides a sense of these atomic reactors being ignited by HAL 9000, to complete his precious mission....with or without anybody alive.... Yves
Could you elaborate on how you did that treatment? Thanks Yves -
This paint job is superb. We all know how glossy paints can be difficult to spray correctly and regularly. Yves -
Moving "rearward", with the atomic engine thrusters and the rear spine: The rear rod/tube needs to be cut off exactly 11 mm, to rest on the internal rib of the central thruster. inside that long spine, we will have to pass two wires for the various lights as will be explained later on. You could avoid cutting it and it will be alright. In my case, an LED and its wiring will be installed to the right of the tube, in that little cavity. This will simulate the reactors firing to propel the vessel during its long journey to Jupiter. The picture below shows the antennae unit (left), the four rear bay holders and the atomic engines block (before gluing). The rear tube is now glued to the antennae unit (coupler) with Cyanoacrylate glue. Don't put too much glue, be sure about what you do or use a slow curing glue. I had just enough time to push it to the mark on the rod, before the glue took over... It was a close call. Below picture shows after gluing: Perfect alignment must be obtained to have an antennae vertical with the engine block. I used a small bubble level as well as my eyes for making sure it is correctly aligned: There is a tiny bit of rotational flexibility in the spine but not much actually. Finally, a coat of Vallejo primer is applied on the rear spine: Yves
Katuna, I thought about placing it in the Ship Model Kits section.... after all, it is a space Vessel, very comparable to a submarine. But then, I wanted to be a good citizen on this forum and not risk the wrath of the Forum police. In the meantime, I count on you for picking up the pace on the Trumpeter Submarine build and keeping our audience entertained with underwater topics..... 😉 Yves
I have added still another aluminum tube around the brass tube. Over killing? probably, but now the rods are very secure and perfectly straight. I suspect that the main spine will not sag at all, when the vessel is supported on each end. Tubes are glued with epoxy two components glue: And here is our spine assembly with the first two bay holders: Yves
As I mentioned in the introduction of the Blog, I will be using the model as part of a celestial art piece. As such I will not be using the traditional way offered by Moebius, to display the kit. Moebius offers three stands under the living area (sphere), Earth antennae module and the propulsion block. The long model rests on these three rather flimsy stands to be displayed horizontally on a flat surface. My model is going to be "suspended" on the side and I wish to only have stands on the propulsion module and near the living quarters. In addition, I wish to provide some kind of illumination on the thrusters and on the main deck. Therefore, we have to rethink a little bit the kit and stiffen it considerably. In the Moebius kit, the two spines (realized by two metallic tubes of 4 mm) are connected inside the Earth antennae module: The piece of tube in charge of the coupling (as provided in the kit), is way too short and not tight enough. As a result, the two rods are sagging and not straight. It is okay if you go with the three stands approach of the kit. However, if you plan to have support only on both ends of the vessel, the spine will sag and look more like an arch. So, we need to stiffen it up. The following picture shows what I have in mind: The top piece of tube is what Moebius provides in the kit. Then we have the two rods of 4 mm each. The brass tube I decided to use offers an additional inch of support on both sides and fits very tightly on the 4 mm rods. When lining up everything, the spine is straight and sturdy. The brass tube is #129 3/16 x 0.014 made by K&S Engineering and can be found in almost all Hobby Shops. The two adjacent modules have to be gently enlarged to accommodate the extra diameter of the brass tube. This is done first with a bit of 4.5 mm and then fine-tuned with a round file (I do not have a 4.8 mm bit which would have been perfect. The coupling is very tight and will hopefully provide us with a "straight" vessel. Yves
Folks, I have narrowed my decision to the following build, for the time being: Thank you all for the many "likes" and wonderful support, all along the building of that massive and complex submarine. Yves
Folks, This is the beginning of another project I have been trying to realize for a while. I recently got the kit from Free-Time Hobbies in Georgia, as they were having a very interesting sale. Like many of you, I watched the 2001 A Space Odyssey movie, in 1969 when it came out, fresh from the genius of Stanley Kubrick. I was just 10 years old and that movie created a life lasting impression on me. For many years, only resin kits of the various space crafts were available. Then Moebius decided to create a series of 1/144 based kits to satisfy the 2001 enthusiasts. XD-1 Discovery is the latest kit produced in 1/144 scale, not counting the enormous EVA 1/8 Pod kit that was recently released: The enormous Deep Space Exploration vessel driven by a psychotic HAL 9000 en route to the vicinity of Jupiter, has always attracted me and when the opportunity to build that magnificent model presented itself, I jumped on it. There are multiple videos and Blogs on the Internet of very talented modelers who have completed this beautiful model. I am not planning to even come closer to their talents. Instead, I will use the model in a different way to produce a piece of art made of mixed-medias as they call it in the artistic realms. I will provide more details when we get to that stage. In the meantime, let's take a look at the kit: The box is very dense and literally crammed with parts: Lots of the parts are the same as we have to build multiple bays arranged along the spine of the vessel. The instructions booklet is simple but carefully written and clearly organized: On the Photo-Etched side, a few additional kits are available: one for the PODs bay and one for the main control deck. Not planning to represent the POD bay opened, I only purchased the Main Deck set from Para Grafix. Notice that even though the focus of the set is on the living area, it also provides the thrusters grills on the Propulsion Block Yves
What a precious jewel of a model. Great job. Yves
- 29 replies
- Dinghy
- Midwest Products
Beautifully built. Congratulations. Yves
- 29 replies
- Dinghy
- Midwest Products
Merry Christmas to all and my Best wishes of Health, Love, Friendship and modeling passion for the New Year. A few updates on that Christmas day. The Diesel engine compartment is now completed and the pressure hull has been installed. The two pieces of pipes for the exhaust as well as the fresh air ingress pipe have been glued and sanded flush with the bulkheads. I have added an extra air tank on the pressure hull, tanks that were used to crank up the diesel engines. The electrical wiring has been completed and verified. We have four white LEDs in series, requiring close to 11 Volts to illuminate. With an adjustable resistor, I will be able to harmonize the intensity of the light, with the other compartments. The current is about 3 mA. The LED above the wood desk is a micro-LED and provides a more classic and yellowish color than the ceiling lights. It is now time to insert the module into the hull. Again, at this point, it is difficult and delicate to go back. The existing wires are carefully inserted in the slots provided by Trumpeter, on each bulkhead. The module inserts in the rear compartment, through the torpedo recess and two large pins, hidden by some apparatus. The module is only glued on the front bulkhead. Closing the starboard hull, this is what we will be able to see: You see the importance of creating the side tanks openings: And a couple of pictures for the claustrophobic's: Folks, I have reached a point where I have two modules to build and countless details to finish on the deck, conning tower, guns and on top of each module, when visible. Some electrical work needs to be completed, as well as some paint touch-ups and light weathering in multiple places. I will finish this model but have decided to take a little break from it and tackle instead one of the two projects I have at heart. One of them (there are many...) could go in this forum as it is boat related. The other one, not being something that floats on water would have to be developed in the "Shore Leave" section. Whatever is being done, I will provide a link to keep you updated. The Type VIIc will be placed back in its box (yes, the fully assembled hull fits) and stored for a few weeks or months. I wish you all Happy and Relaxing Holidays, and passion, fire and energy for many projects. Yves
