Everything posted by yvesvidal
Implementation of the forward mast base and deck beams. Not really easy and requiring a lot of fine adjustments to position it correctly. I glued the deck beam #3to come as close as possible, before cutting the central support beam. After cutting (below): I would strongly recommend not installing any more deck beams, as you need the access with your fingers to position the base. The installation of the base must be done after filing the base of the front mast, for a correct and still tight fit: The base is now glued strongly as much as possible: According to the Monograph, the front mast is leaning by 20 degrees from the vertical (70 from horizontal). CAF Model does not provide much instructions on this subject. Pretty close to the 20 degrees. Below, both masts installed: Next is the big puzzle of the bow deck beams: Here, a lot of fine adjustments are necessary. I do one side at a time: Then the other side and the front plate, still checking with the mast and its inclination: All these beams will be covered by the deck planking. Note that the middle cross-over beam was not fitting in the original position. I re-positioned it a little bit behind. And a final verification with the mast: Now, we can proceed with installing all the remaining deck beams in the bow. Yves
I am moving along with the installation of the deck beams and the main mast base. On the picture (above), you can see that the central support has been carefully cut to allow the main mast to be installed. Before cutting, I installed on each side a few more beams to secure the central support. I did not want it to collapse or buckle in any ways. The main mast fits just right. It is 15 mm in diameter and will probably be slightly reduced when sanded to shape. After carefully eyeballing the mast to be perpendicular, the mast base can be positioned and glued (See above). Gluing more deck beams, after sanding slightly the waxed wood and using exclusively CA glue. A vertical support piece has been added next to the base, according to the Kit plan and Monograph (above). I know, it is a lot of beams.... Next, I will be doing the same with the front mast. Stay tuned. Yves
Brian, Regarding your question about the interior of the hull, I have been pondering whether I should show some of the deck beams open (not planked), since the hull will not be planked to display the numerous frames. However, I tend to go with a full planking of the deck as there are a lot of things to install and display on the deck. Leaving a section of the deck un-planked, would restrict the amount of stuff that can be installed on it. In addition, the model is fully rigged and as such there are all kinds of anchoring devices and pulleys that need to be installed on the deck for the standing and running rigging. Yves
Brian, No interior is planned in the kit. Besides, the entire deck is planked, so it will be impossible to see anything inside, even with no hull planking. The central support beam is 3 mm thick and the keel is 8 mm wide. Lining up was not so much of an issue. What is delicate is lining up the little slots for the deck beams with their corresponding hull frames. The Plan provided by CAF Model regarding that specific alignment, is slightly different than the Monograph. I am following the CAF instructions, as you may easily guess. Thank you for the compliments. Yves
I was planning to finish the stern (and the Session #1 by the same token), but it is not possible (or practical) because of the cradle. At this stage, I have no other choice than starting the installation of the deck beams. I know it is hard, but someone has to do it... 🙂 I decided to install the central beams as they are the pivot of the whole deck and it will allow me to position correctly the mast base. Lots of beams to install (about 58) plus the platforms for the bow and stern. That should be interesting. Once this is done, it may be possible to extract the assembly out of the cradle. We will see. Yves
A quick update and a major milestone completed for me: the building of the deck frames supports in the hull. The central support has been installed: To position correctly the 3x5mm deck frames support on each side of the hull, I am approaching it in two ways: 1) An approximate marking using multiple deck frames. It gives me some kind of indications. 2) Using the plan, a precise measurement from the base of the cradle: It is the line marked "4". I am using a measure every ten frames. When happy, it is time to glue, using CA glue and strong fingers pressure, since there is no easy way to position these 3 x 5 supports. Once glued, I am drilling through the beam and into each frame. A real nail (pin of electronic components - 0.8 mm diameter) is inserted after coating the "nail" with CA glue. Then some sanding, oiling and waxing. The nails are useful in places where the frames are not touching very well the beam, due to the poor fairing of the internal hull. This is mostly the case in the stern (see above). Both sides are now done...sighs. I hope it will be alright. There is no coming back. Next, I am going back to the Session #1 and will try to finish the stern: Overall, I am very happy to have this milestone behind me. It was not the most pleasant thing to do. Yves
While working and measuring multiple times for the installation of the deck frames supports (3x5 mm), I have built the ladders used by the crew to reach the lower level: These parts are funny to build, with a small triangular file. The crew must have been very agile to use this kind of ladder, that literally requires your two hands and two feet to get to the upper deck. Yves
Your efforts remind me of what some modelers have done for the Trumpeter Titanic hull. It is massive but should pay off, in the end. Yves
As indicated by the picture below (Session #2), I have installed three sets of the 2x5 planks. I am stopping there. Now, the dreaded prospect of gluing the 3x5 mm planks is coming. There are really no clear indication on how to do that, besides a little tick mark on the frames, that comes somewhat in the middle of the deck beams. It is really not precise at all. In addition, securing the deck beams supports (3x5mm - Green) is not an easy task, because of the lack of access due to the constraining cradle. Instead, I decided to move on and install the deck beams central support as well as possible, making sure that it lines up with the deck beams and from there, determine where the 3x5mm supports have to be installed. It is going to be tedious but that is the only way I see it possible. Once this assembly is in place, I hope by positioning a few deck beams, to be able to trace the exact position of the 3x5 supports, on the frames. That central assembly (3F-1 to 3F-15) is super fragile and requires a lot of care. It is first assembled flat on a bench: Then, many dry-runs are made to position it in the best possible way. One of the vertical holders is ending right in the middle of the mast base, which is not good. I will adjust this later. The mast base is not glued yet and will be glued later, when some of the major deck beams have been installed. There is a lot of conflicting information between the Monograph, one of the CAF plans and the other CAF plan (!) Not easy to figure out exactly where the main mast should sit. Finally, the central support is installed and the CA is drying.... Wish me luck.... I really have no idea if that is going to work. Yves
I just finished installing the third (and last) set of inside planks. Even though the kit calls for 5 sets, I am limiting myself at that point as these are extremely difficult to set correctly, since you have to hold the planks with your fingers while the glue does its job. There is absolutely no room to fix the planks, with perhaps the exception of drilling a small hole and placing a few microscopic wood screws. Again, all planks were tree nailed, with the tip of the nails protruding into the frames. The next part of the assembly is very complex, poorly documented by CAF and very tricky. It will drive the rest of the assembly and I hope to not screw up royally on this one. Yves
John, Thank you for the links. The 3D virtual walk is amazing and renders so well the atmosphere of the ship. I have this kit in my stash and will take advice from your build log. Yves
- 158 replies
- chaperon
- Model Shipways
