Everything posted by Jim Lad
17th Century Shallop by ryesbeemer
Jim Lad replied to ryesbeemer's topic in - Build logs for subjects built 1501 - 1750
Welcome to the 'dark side', mate! That looks like it will make a lovely model! John -
Just catching up, Gil. She's coming along very nicely indeed! John
- 755 replies
- finished
- caldercraft
Sherry, The stuff I used is 'Pinkysil' two component silicone mould maker, and 'Procast' medium set rigid polyurethane casting resin. These are both made by an Australian company called Barnes Products Pty Ltd. Their local shop web site has a lot of interesting information on it - http://www.barnes.com.au/catalog/index.php They also have some helpful 'how to' stuff on you tube that can be accessed from the web site. Hopefully this will give you enough information to atrack down what you need over there. John
Sherry, I moulded the carronades for my Stag (1:96) from resin. I made a master from wood and copper wire and used that to make a mould - it worked extremely well. I had never tried resin casting prior to this and found the whole process slightly messy, but very simple to do. If you have 100+ cannons to make, you could probably make several moulds from your master and then go into mass production. John
Just catching up, Toni - she looks great. I go away for a week and you build half a model! John
- 1,449 replies
Ollie, The planking above the wale would normally be parallel sided, but below the wale the planking will vary considerably in width, being widest at the stern and narrowest at the bow. The run in between will not be a simple taper, but the plank width will vary depending on the hull shape. Typically, the planks will be widest at the stern, then narrow in and then become a little wider about midships and then narrow in again towards the bow, but the actual shape is very much dependant on the shape of the hull. The 'run' of the planking is simply the line of each strake of planking along the hull. In this photo of the replica of the schooner 'Enterprize' (1829) under construction in Melbourne, the 'run' or the shape of the lines of planking can clearly be seen. John
- 803 replies
- colonial cutter
- modellers shipyard
That was a nicely done fix, Ollie. Watch the run of the planking - it'll get away from you if you're not careful. John
- 803 replies
- colonial cutter
You're really making some progress on this one! John
- 49 replies
- amati
- hydroplane
(and 3 more)
Spare yards and spars stored on deck
Jim Lad replied to omarcs's topic in Masting, rigging and sails
If the spare spars are iron, then they would be painted; if wood, then most probably left natural. The lashing ropes would be hemp coloured. John -
I think I'd leave them 'as is', Ollie. Any extension would be really obvious and new parts would require life threatening surgery. John
- 803 replies
- colonial cutter
Rain? What's rain? Looking good, mate! John
- 803 replies
- colonial cutter
Back at it already, Danny! Were the spare spars laid across the gallows and the after end of the forecastle with the boats stowed on the spars, perhaps? John
Thatunloading gear is going to deserve a lot of care in building, Andy. From the look of that last photograph, it's going to really dominate the model. John
- 382 replies
- stadacona
- sylvan scale models
Absolutely delightful (as usual), Remco. John
- 1,215 replies
- sloop
- kingfisher
Crikey, Augie, you've certainly been busy while I've been away. She's looking first class! John
- 2,191 replies
- confederacy
- Model Shipways
