Everything posted by Jim Lad
Take your time, Andy, we'll still be waiting patiently (well, most of us will be patient! ). John
- 1,148 replies
Jay, Pig iron billets in the bottom would definitely help! As the Revenue cutters were only supposed to come into port for stores or repairs, their crews would certainly get a lot of sailing practice. The square sails were rigged so that they could be brought down very quickly! John
Augie, Keeping her in the water was probably pretty easy, but I still don't know how they kept he upright! I found a newspaper report that said that Stag had won the annual cutter race again. The tone of the report sounded a bit like - well, what else would you expect! For those who didn't see it in the original log, here's a re post of the painting of Stag under sail and chasing what looks to be a French lugger. John
Very realistic ratlines, Ilhan. I tried using the 'card behind the shroud' method for the ratlines on my Stag model and found it works like a charm! John
Hey, Mobbsie, I forgot to tell you - in more refined circles we don't say, "Bob's your uncle," we say, "Robert's your parent's sibling." John
- 1,279 replies
- agamemnon
- caldercraft
Hello guy, and a very warm welcome to the forum from 'Down Under'. Sounds like you're a big fan of JRR Tolkien! If your hull is sound and the planking hasn't opened up, why not continue your Bluenose from where you left off? John
So do we assume that the next one will be 1:96 Ed? I'm looking forward to seeing you going into full frame production. John
- 3,618 replies
- young america
- clipper
Hamilton, Bit of a pain to do, but you probably will need to make a grommet (continuous loop like a quoit) considerably larger than the diameter of the bowsprit and then seize the four eyes into it. If you form each eye in turn with your fingers and then clamp the eye while you seize it, it should be doable. John
Jay, Stag was built in a private yard at Cowes on the Isle of Wight for the Revenue Service. She was the fastest cutter of her day and in 1839 the Royal Navy took her into Portsmouth Dock and drew up a set of plans for her - I'm guessing they wanted one the same because of her speed. It was just a happy accident that the cutter that they drew up such detailed plans for was the one I wanted to build. John
Jay, The plans are in at the museum at the moment, so I can't take a picture of them, but on the lines drawings there's a detailed cross section amidships that shows the planking. Very unusual to find that sort of detail on an admiralty plan, but there it is, and I'm grateful. John
Mobbsie - yeah, I've been leaning towards pedestals - we'll see Popeye - The museum currently want to display her in the Members' Lounge Sherry and Bob - Thanks very much for your support! John
Excellent précis of the extreme clippers, Ed. John
- 3,618 replies
- young america
- clipper
Best if the ratlines are left until the standing rigging is finally tensioned. I know that this leaves a lot of ratlines to do in one hit, but you have a better chance of ending up with better looking rigging. John
Harvey, Cotton isn't as liable to slipping as some synthetic fibres, however I think the trick is to leave a reasonable length on the end after temporarily securing the line. That way the knot isn't so liable to give way and you also have something to play with if you need to adjust the tension. John
Elia - I'm still tossing up between pedestals and a stand. I hope to get the base organised before my next trip to the museum, so that might finally settle it for me. Druxey - I really regret my reprehensible rigging (w)reckage! Augie - Thanks for the good word, mate! John
Harvey, Your planned rigging is exactly the way I rig my models. The trick is to get as much rigging as possible already fitted on each yard before they go aloft. As for rigging tautness, don't finally fix any of your standing rigging until the entire ship is rigged - i.e., tie everything off, but leave the 'tails on the lines and don't glue anything. That way you'll be able to make any final adjustments that might be necessary. John
Well, Stag progresses (more or less). The spreader has been completed and the topmast shrouds and forestay rigged. I have also just about got all the rigging on the upper square yard ready for sending it aloft. Oh, and the boom topping lift is also rigged and secured. I made a stupid boo boo just before leaving the museum - trying to rush to get things done, I suppose. I was checking the lower square yard brace pennants and realised that the starboard after pennant was way too long. Thinking, "Why did you do that?", I cut it off ready to make a new one next time I'm in at the work bench and only then realised that the starboard forward pennant was way too short!! You guessed it - when I'd fitted them I'd put them on the wrong way round, so all I had needed to do was to soften the glue, turn both pennants through 180 degrees and re-glue them. Oh, well, a bit of pennant making practice won't hurt. Here are a few photos of her as of yesterday afternoon. I realise that the close up of the mast is pretty blurry - I'll try to remember to get a better one next time in. Overall views of the model A blurry mast! The deck showing an ever more crowded area around the foot of the mast. The upper yard almost ready to go aloft John
Mick, The photo below shows the windlass on the replica endeavour. You can see the handspike holes quite clearly. In this photo you can see the square handspike holes at the outboard ends of the windlass on my Palmerin model. The square holes were made by first drilling the holes to size and then squaring them off with the tip of a very small square file. John
Looks like most of this happened while I was away on holidays. Lovely job, Allan! John
- 86 replies
- schooner
- effie m morrisey
