Everything posted by dvm27
Looking great, Toni. So much more to go, though. How many years are you into her at this point?
- 1,449 replies
ancre Le Commerce de Marseille by Zbigniew
dvm27 replied to Zbigniew's topic in - Build logs for subjects built 1751 - 1800
Thats a lovely stern section Zbigniew. -
Ed, The decision to replace the knee of the head and you execution of the rebuild makes us all aspire to be better modelers. As someone who has often done these rebuilds I know that making the decision and anticipation of the work are usually far worse than the actual repair.
Echo by Maury S - FINISHED - Cross-Section
dvm27 replied to Maury S's topic in - Build logs for subjects built 1751 - 1800
I know what you mean Maury. I just finished fairing the starboard side of my Speedwell model and it took me almost five days. I actually start with 60 grit paper. Keep applying those pencil marks to show the low spots. I find that I can actually hear when she's faired.- 324 replies
Welcome back, Bill. Thanks for sharing a current photo of your beautiful model.
- 382 replies
- sovereign of the seas
- carving
USF Confederacy by Rustyj - FINISHED
dvm27 replied to Rustyj's topic in - Build logs for subjects built 1751 - 1800
Congratulations on the completion of a very difficult area, Rusty. You've done her proud!- 149 replies
- confederacy
- frigate
I'm afraid I did mine in a much simpler fashion, Maury. I simply placed a small billet of the correct sided dimension on top of the sill and traced the pattern from the adjacent toptimber. This way the bottom is guaranteed to sit flush on the sill. The accompanying photo shows the short toptimber after being cut with the scrollsaw.- 324 replies
In addition, Maury, I would use a fine x-Acto blade or better still, small holes drilled down the center of the spacer to slice it in two. That way you can easily debond each glued joint individually. If you glued the bottom of the sill to the spacers it will probably come out with them but sills are easily replaced. Just apply alcohol to the mortises and scrape out any residual glue.- 324 replies
Love the way you've fitted the well and shot locker onto the keelson and strakes. It's a difficult job to do without gaps and considering you won't see it later on, it reflects the no-compromise approach you're taking in building this model.
- 1,449 replies
ancre Le Fleuron 1729 by rekon54 - 1:24
dvm27 replied to rekon54's topic in - Build logs for subjects built 1501 - 1750
Those guns are exquisite Girogio. Each is a little work of art. Yous should send one to each member of the list! The black finish on the unadorned gun (the one without decorations) - how did you achieve it. It's a perfect black finish for a cannon. -
That depends on the era and nation of the ship, Al. If you are talking about a late 1700 era British warship the 32 pounder cannon was about 9' 6". At 1/4" scale that would be roughly 60 mm. You can purchase 55 mm cast barrels from A. Baranov which are quite exceptional but pricey. You may reach him at shipmodelscontact@yandex.ru
ROYAL CAROLINE 1749 by Doris - 1:40 - CARD
dvm27 replied to DORIS's topic in - Build logs for subjects built 1501 - 1750
Doris, I'm not usually a fan of figures on ship models but yours complement the model perfectly. May I ask how you made them (or where you purchased them)?- 883 replies
- royal caroline
- ship of the line
Beautiful job, Rusty!- 149 replies
- confederacy
- frigate
Your block and tackle certainly pass the close up muster, Remco! Just for reference, what are the dimensions on the background grid squares...1/4"?
- 1,215 replies
- sloop
- kingfisher
Echo by oneslim - cross-section
dvm27 replied to oneslim's topic in - Build logs for subjects built 1751 - 1800
Uh oh, Bob...looks like you're still paying for last weekend! -
I agree with Michiel - one can but wonder at your work. For me, your metal work and mortises are among my favorites. -
Terrific detail, Egen. Like Allan I have not built any large sections off the model but they sure would be easier to do that way.
Thanks for the photos Bob. I knew your Nikon digital SLR would take better photos than my mini Nikon. Your first frame came out terrific and your lucite jig far outdid mine. Hope to catch you at our next workshop in the fall! -
You're a gifted model maker Doris. I wonder if you also made doll houses, as your cabin rooms have that feel.- 883 replies
- royal caroline
- ship of the line
Echo by jml1083 - cross-section
dvm27 replied to jml1083's topic in - Build logs for subjects built 1751 - 1800
Terrific first frame, Jim. Others might wonder about spending a whole weekend to make one frame. But the techniques you learned will translate to all your scratch building work. If you're worried about that blemish just reverse the frame as the blemish won't be visible on the aft side. Just make sure to reverse the treenail pattern to match.
