Everything posted by wefalck
  1. We probably don't know what the practice was at the end of the 17th century. On small scales I used a cow hitch as surrogate for the sewed-on eye-splice. Looking at your threads, I think it would be quite feasible to make a fake eye-splice and sew this on with a couple of turns of fly-tying thread.
  2. I think John is right. The lower yards would not normally be raised and lowered, unlike the upper yards, where both, lifts and falls may be needed to move the heavy yards up and down.
  3. I didn't realise that the chocks are wood. So, yes, you would have to have something metal and if its turning it doesn't have to be so heavy.
  4. Did they have roller-fairleads at that time and on such rather improvised vessels ?
  5. Yes, that could be. Some kind of glutin glue kept from gelling by adding salt. Or it could be a thick shellac solution, one with lots of shellac and little alcohol.
  6. Every organic solvent has a smell and some of them smell quite nicely (no, I am not a 'sniffer' ...). It depends on how big the area is to which you apply the glue. The main point is, whether the glue does the job. And: traditional hide glue does not necessarily smell very nice either.
  7. That could be. In Germany the classical polychloroprene glue is Pattex and in my youth it was sold in tins. However, it was much for 'stringy' thatn the stuff in the video.
  8. Laser-cutting results in a slight kerf, but this doesn't account for the observed gaps here. Due to the kerf, forward bulkheads should face forward with the side that that was down during the cutting process and vice versa for the rear bulkheads.
  9. As always, the answer to the original question depends on what kind of model you are thinking of (and on the scale): for a model that shows off your artesanal skills, blackening is probably the way to go, while for a model that depicts the real life appearance of the prototype, painting may be more apropriate, as this is what would have been done in real life. I agree with 'grsjax', that blackening provides a better key for paints, particularly also acrylics, than the bare brass or copper. And: if the paint chips during subsequent handling, this will not be so visible.
  10. Keith, how is the attachment lock into the T-slot of cross-slide ? I don't seem to see any screw that pulls the fixed part down onto the table, against the T-nuts.
  11. Ah, someone else, who got out the ball-turning attachment. Will be showing some results in my log soon. Would you mind showing your attachment to satisfy my curiosity ? Very nice anchors, indeed ! Will they stay in brass, or will you blacken them ? If the prototypes were galvanised, chemically tinning would also be an option.
  12. Just discovered this log - beautiful wood- and metal-work indeed. Will keep following further progress !
  13. Matching paints from different manufacturers really will be hit and miss. Not only will pigments be different, but as binders and solvents will be different, their levels of sheen will also vary. I think really the best strategy is one you already used, namely to decant a bit from the spray-can into a container. If you can find one with a tighly closing lid, then you may be able to store it for weeks or months, making the procedure less wasteful.
  14. Follow Roger's suggestion of filling up the spaces between the 'bulkheads' with some scrap wood that is a tad softer than the plywood. Many kit-builders do this and make life a lot easier ...
  15. Well, I am actually an expat from Germany, but my wife is French On a ship like that the helmsman would standing besides the tiller, not in front of it, as you may do on small sailing boat, in order to be able to steady the tiller with the whole body weight. So I would think that the tiller should be a tad longer than drawin on the plans, but not so long that it would touch the bulwark, when put over hard.
  16. I think we had this topic somewhere else before ... Anyway, there are extremely fine silk fabrics for silk-screen printing. I gather one can get them in art-supply stores, but also in the famous bay. Haven't tried them myself yet, but I believe this was the main use of the fabrics also used for covering model aircraft.
  17. Also did some googling and realised that my chemical/mineralogical knowledge crossed with what are marketed products. Today, TiO2 pigment is produced mainly from a mineral called rutile, which apart from being crystalline TiO2 can contain significant amounts of iron oxide. The iron oxide is removed by an acid leaching process, depending on how effective this process is, traces may remain, giving the pigment a slightly yellowish stain. It appears that some artists like this pale beige colour and it is marketed as such, as 'unbleached' TiO2. The purification process has actually nothing to do with 'bleaching', which is an oxidation process.
  18. This wanders a bit off-topic, but I wonder what is meant by 'bleached' vs. 'unbleached' titanium ? Titanium oxide (TiO2) is one of the whitest pigments that we have. Also, due to the production process it is very pure and then very stable as a chemical compound. So, I wonder, how it can be bleached.
  19. Hide glue is normally used warm, isn’t it ?
  20. In the video below on the assembly of SHIPYARD laser-cut blocks the guy uses a liquid, honey-like glue, that seems to set quite rapidly. What kind of glue may this be ? Wrote to the guys a week ago, but no response yet ...
  21. As I am currently working in 1/160 scale and struggling to produce blocks, I gather I know what I am talking about: you have two issues to tackle here, namely - you need sources on both ships that provide you with the necessary rigging information, such as LONGRIDGE, C.N. (1933): The Cutty Sark.- 440 p., Kings Langley/Herts. (Model and Allied Publications, reprint 1975). MARQUARDT, K.H. (1995): Captain Cook’s Endeavour.- Anatomy of the Ship Series: 136 p., London/Annapolis MD (Conway Maritime Press/United States Naval Institute Press, Annapolis). - you need to find a way to manufacture the hardware in quite large quantities. McCaffery, quoted by Allan above, works in really small scales, perhaps half the size of your scale and uses wire for the standing as well as the running rigging. He essentially simulates blocks and dead-eyes with paper discs. For blocks he uses oval punches he makes himself. I am currently experimenting with laser-cut paper, but these experiments have not yet had the desired results. Building up the blocks with styrene sheet the way other people build up them up with layers of wood strips could be an option at such small scale. Styrene has the advantage of not having any grain and texture that would make small pieces fragile and be out of scale.
  22. I can't put my hand on that immediately, but I have seen estimations of sail-cloth weights. It is not so straightforward, as they were numbered and each number refered to a cloth of a certain weight per bolt, that is the roll of fabric of a specified lenght and width. The specifications varied from navy to navy and also where they obtained the fabric, if it was not manufactured in the navy's own manufacture. As for rope, the thickness of a fabric is difficult to define, as it changes with the amount of stretching and the humidity. For this reason, today the thickness still is indirectly given by the weight per unit area (e.g. square metre or square yard). With information on the specific weight of the yarn used and the thread-count, one can make some rough 'guesstimates' of the thickness. However, I would hazard a guess that even the coarsest canvasses would not be much above 3 mm or 1/8" thick, typically less. A german colleague puts a special paper-repair fabric between two layers of silk paper that is arranged in overlapping strips. This repair-fabric is extremely thin (I think about 10 g/sqm) and impregnated with a heat-activated acrylic glue. The resulting sails have the visual appearance of the real thing and are translucent like the real thing. They sails also can be wetted to drape them and thus show them e.g. limp. However, for furled sails I would probably rather go for silkscreen as Allan suggested. Depending on the scale one may even go for paper maché or modelling putty and just make the 'dog ears' in silk-paper or painted silkscreen. What counts is the correct appearance, not what's inside
  23. Depending on how sharp the bow (and the stern here) are, the overlapping section of the lower plank would be sharpened out to near zero over a distance of several plank widths - is it that what you did ? I agree, that clinker-planking can be a bit of challenge, but if it worked, it is very satisfying.
  24. These forged items can be really a pain to fabricate - either a lot of filing/milling from some thick stock or some ingenious way to puzzle them together ... this is, I think, where the power of 3D-printing, perhaps as pattern for investment casting, comes in - but it does take away the charme of well-executed artisanal work
