Posts posted by wefalck
One could also argue, that the advantage of PVA-glue is that it penetrates deeper and therefore keys better into the wood, while epoxy cements stay more on the surface. The latter are stronger as a material, but do not key into wood so well.
At the shipyard outside the actual museum there is a little building, where they show the tanning process. Somewhere I have a picture, but I didn't put it onto my Web-site.
I you look into the above reference book on sail-making from 1843, it talks in detail about the process and that greasing sails was expressedly forbidden in the Royal Navy.
- mtaylor and thibaultron
2
Well, I wouldn't necessesarily trust painting - artistic license and ideas about colouration. Artists are not interested normally in the 'true' colour of things, but in how they appear under given conditions of weather and light. Ship portrays, usually painted by semi-trained or self-taught 'commercial artist' may be a bit more reliable, because those commissioning these paintings where not so much interested in artistic rendering, but rather in a representation of how they see their ship. Then they may have also preferred an idealised appearance, while in reality ships and sails may have looked more tatty and ragbag.
- mtaylor, thibaultron, druxey and 1 other
4
Jan, I believe there is, for instance, somewhere in the Zuiderzeemuseum an explanation of this process. Boiling the sails in the solution is but one step, but smearing them with a tallow-ochre mixture makes them water-repellent and covers them against UV-radiation. See also: https://books.google.fr/books?id=XvgDAAAAQAAJ
- thibaultron, mtaylor and jud
3
First of all, thanks to all of your for friendly comments
John, there are a couple of reasons in general for using plastics and not wood:
- I think metal in models is best represented in models by, well, metal, of course, and by plastics, because they don't have any surface texture that needs to be covered up
- similarly, at this small scale any wood grain, whether painted or left plain (varnished) would be grossly out of scale.
- while I appreciate that some people manage to get very clean and sharp edges out of wood, this is much easier for small parts in plastics or metal; turning and milling leaves a surface that requires little further manipulation.
- plastics are homogeneous and don't split or rip along any grain, though bakelite as such is rather brittle, particularly the thin sheets.
- styrene and acrylics can be glued, or rather welded, nearly without any trace using dicholormethane
- it is extremely difficult (for me at least) to get really high quality hard-wood and then confection it to sizes that are useful
- plastics don't dust when worked
Each of the plastics has different properties, making them suitable for different parts or applications:
- Plexiglas and bakelite (hard paper) are so called duro-plastics, meaning they do not contain plasticisers and are very stable over decades, if not centuries. They are also very stable against UV light.
- Styrene is a thermo-plastic and contains plasticisers that will slowly diffuse out, making the material brittle over decades. It is also less UV stable.
- Plexiglas is easy to machine and you get very clean and sharp edges; it files and sands well; it is of medium hardness; unfortunately, it is not normally available in sheets of less than 0,8 mm thickness; otherwise one can get sheets, blocks, rods etc.; the best quality is the one cast from monomer, not the extruded one.
- bakelite is the hardest and stiffest of them, but brittle in thin sheets; owing to this it is more difficult to machine, but it sands well; it can be obtained in sheets down to 0.1 mm thickness and sheets up to several cm thickness; other formats are generally not available; rods that are on the market are reenforced with fabric (e.g. Novotex), rather than the one with paper, I am using.
- styrene is the softest of them and dents easily; it is difficult to machine cleanly and does not sand very well; it is commercially available in a wide variety of dimensions, very thin sheets, rods, strips, and other profiles.
I hope this sufficiently explains my materials choices.
Indeed, 'tanning' sails was only a practice on small(er) fishing boats that rarely had the opportunity to dry their sails properly, because they were worked every day. The process involved soaking them in a solution made from bark and then smearing them with a mixture of red ochre (hence the 'rust' colour) and tallow or oil. This made the sails rathre stiff and messy to handle. They would not furl very nicely and indeed furly will to some extent damage the 'tanning'.
In some parts of Europe, notably around the Mediterranean, it was also practice to paint the sails of smaller craft with all sorts of designs of apotropaic character, wishing good luck to the vessel, or as a signature of the owner.
It seems to have become fashionable among some modern 'tall-ships' to sport coloured sails, but this was not common in the 19th century.
Not sure, whether at this time they had already cotton sails in the USA, but from some point in time on US American ships tended to whiter sails than their European colleagues, that had sails made from hemp.
- druxey, thibaultron, mtaylor and 1 other
4
Not sure, which part you are talking about, the filler piece behind the stem ?
In real terms these Viking ships were build in a rather different way, namely 'shell first', i.e. without any internal structure, which was added afterwards, after the planking had proceeded to some extent. The stem was in fact a complicated carving with a stepped rabbet into which the individual planks fit.
I would suggest that you trawl the Internet for photographs of the preserved prototype and of replicas to help you understand, how it should look like from the outside. You then can decide how to reproduce this best with the material available in the kit. You will have to somehow reproduce the stem with the rabbet as landing for the planks.
As someone said above: predictably good
- popeye the sailor, Valeriy V, hexnut and 1 other
4
Personally, I also prefer 'real' books and have a library with some quite rare period books. However, some books have never been reprinted and, therefore, are largely unknown to the modelling community. There is also a space issue for some of us. There is a good paperback reprint of Biddlecombe by Dover and there are several reprints of the 'Lever' - I have an US American, hard-bound one from around 35 years ago.
When you do Google searches on the title/author, it usually turns up the holdings in GoogleBooks, Abebooks.com, as well as the ones in archive.org. There is a bias towards English titles though. When you look for French titles, you better go to the site of the French Bibliotheque Nationale.
Did you buy them already ? Always check out the Internet first, there are now many historic books available for free as eBooks.
I don't have any of Peterson's books, but seem to have heard that there are quite a few mistakes in them and he generalises from Swedish practices as represented in the models in the Sjöfartmuseum in Stockholm. Perhaps some other Members can comment on the reliability of the books ?
From the selection of books, I assume that you are mainly interested in the first half of the 19th century ? That's important to remember as rigging practices evolved considerably.
Good advice from Jaager. As you work, you will feel the need for certain types of tools, say to hold something, to cut something, etc., because your toolbox doesn't have right stuff. That's the point to buy - or to make yourself, btw. Analyse carefully what operations you try to perform and how your existing tools don't do, that gives you ideas of what to look for.
There are a lot of useless 'modelling' tools on the market. Sometimes the idea is good, but their make is poor, sometimes they are outright useless. It is also worthwhile to browse jewellery and watchmaking supply houses, fine tool supply houses, dentists and dental technician suppliers, medical suppliers, manicure/pedicure suppliers, etc. Their market is usually much bigger than ours and they often have the same stuff in better quality (and sometimes at lower prices) than 'modelling' suppliers. Ebay is your friend too.
I noticed that you didn't use a stem-post with rabbet to run the planks into. I suppose you will 'fake' (I hesitate to use this word these days ...) it by putting a false stem in front of it ?
Good find ! Such catalogues are invaluable to see what parts actually looked like in their days. If only the scan was better ...
- bruce d, mtaylor and Keith Black
3
Nacioffi, perhaps you could precise in what period you are interested in ? The term 'hermaphrodite brig' or 'brigantine' tended to be used from the second quarter of the 19th century on for a vessel with a full-rigged foremast and a fore-and-aft rigged main mast. It was a popular rig in European waters up the to end of the sailing ship period, more popular than the brig (or snow). In continental Europe it was also preferred over the tops-sail schooner, which seems to have been more popular around the British Isles.
Thanks, gentlemen
There are two jacob-ladders on each side of the hull, a wider one underneath a door in the bulwark and a narrower one a bit forward. The steps probably were made from wood and had slots towards the hull to prevent the water from collecting there and to prevent the wood from rotting.
Milling of the steps for the jacobs-ladders
The steps are made from 0.8 mm thick Plexiglas® and the slots milled in. The sheet then was sanded down to the width of the steps and the ends rounded. Then individual steps of the right thickness were cut off on the lathe set-up with a mini saw-table.
Steps ready for fittingUnfortunately, the steps could only be cemented to the hull using cyanoacrylate glue, there being no positive locking. A bit of cellotape provided a guide for alignment. Nevertheless, the procedure was a bit nerve-racking.
Jacob-ladder on portJacob-ladder on starbord
Further, fairleads for the aft mooring hawser were installed. These were made from oval rings of copper-wire. The rings were formed over two 1 mm-drills taped together, cut off and closed by silver-soldering. The rings were sanded down to half their thickness and one each of these rings cemented to the inside and outside of the hull. The hole was drilled out and filed to shape.
Fairlead for aft mooring hawsers
To be continued soon ...
- druxey, GrandpaPhil, vaddoc and 16 others
19
One should perhaps also mention that the included angle should always be more or less 90° (as per your sketch A above). However, the angle by which this corner intersects with the keel/false keel changes (as mentioned by others already) along the keel-stem/stern assemply as the angle by which the planks intersect with these changes.
The best thing would be to take a 'spline', i.e. a thin straight plank with clean sides at right angles and have it aligned to the outside line of the rabbet as per your drawings. This allows you to estimate how much wood you need to cut away for the inside line so that the spline butts nicely against the rabbet.
Not sure, I understand your question right. However, on the point how masts are secured to the hull, one needs to distinguish between model and full-size practice.
In full-size practice, a mast is fixed to the hull at three points: 1) the mast-spur, which is a square or rectangular short part at the bottom end of the mast that is inserted into a matching hole in the keel, false keel, or an extra piece of wood bolted onto the same, 2) by wedges around the mast, driven into a frame that forms part of the upper deck structure, 3) at its top by the system of stays and shrouds.
On models, point (2) above is usually omitted or not functional. It depends also on the construction, namely whether PoF, PoB, bread-and-butter, etc. Sometimes, people provide a pipe section into which the mast is inserted.
Equidistant steps are more important for effcient use then their position in our out. Remember that they would be used mainly at sea, when the ship is rolling and pitching. Almost every person using these steps would have had some practice at sea, including running up the rigging and negotiating the overhung ratlines underneath mast-tops. So a protruding step would not really be a challenge, particularly, when you are pulling yourself up on the (knotted) rope that runs alongside the steps.
It is safer to mirror-image the drawing in your program and sent them two files. If you have any surface-etched details, you will have two images/files anyway.
- thibaultron and mtaylor
2
There are two main challenges in doing this at home:
- getting the masks with sufficient density of the black parts; neither ink-jet printers nor laser-printers do a job good enough for the purpose; you can fiddle a bit with the direction of printing, as the cross-direction usually gives better densities and you can orient your parts accordingly; there are also 'toner-enhancers', used by the PCB fraternity, that intend to fuse the toner into a more uniform layer, but this is still not good enough for most of the intricate etching we do; I think the way to go is to find a commercial reprographer who can print directly from your file to reprographics film.
- small frets, say up to credit-card format can be etched to an acceptable standard in a tray, for larger formats you need an uniformely agitated (vetical) tank; the reason is the velocity distribution when you agitate, it is not uniform across the fret, so that some areas are ready, while others are not yet.
As a (geo-)chemist with years of experience in a lab environment, I am very hesitant to mess around with large quantities of corrosive chemicals in the home environment. So I restricted myself to the credit-card format with say a maximum of 50 ml solution at any one time. This has also the advantage that I am using fresh solutions for nearly each fret.
- thibaultron and bruce d
2
Seems that you solved your problem, but just a couple of comments for those, who have a similar challenge:
- PDF is a storage format, but there are different ways to generate PDF-files and they may change the scale compared to printing from the original file; I experienced this when comparing the direct print-outs from my 2D-CAD software with print-out made from PDFs generated with the 2D-CAD software; if you buy commercial plans, the publishers should have accounted for this and adjusted the scale when the PDF was generated
- when generating PDFs in theory there should be no distortion between the x- and y-axes, i.e. the scale should be the same in both directions.
- when printing hard-copies there may well be a slight distortion due to the physics of the printer, e.g. stretching of paper, so it is better to check on trial-prints
- when printing at home on a laser- or ink-jet-printer you may be able, depending on the software, to adjust the scale independently in x- and y-direction to correct for such distortions
- photocopiers normally do not allow to adjust the scale independently in x- and y-direction, dito when you go to commercial printers to have something laser-printed - unless they have the same software as you and can do the corrections in there (likely to be costly due to the time involved).
- if you are on a Mac, the program Preview allows you to open and edit (to some degree) PDFs
2
Just to note: primers and sanding sealers are two different animals. I pays to reflect upon why one uses what and what the function respectively is.
Primers have the function to act as intermediate between the surface and the chosen paint. The surface and the paint may not be compatible from a physicochemical or surface chemistry point of view. For instance, brass or copper are slightly water repellant due to an oxide layer forming on them quickly. Acrylics would not stick on these metals very well. Hence, a primer that reacts with the surface and leaves behind a new surface that is compatible with the acrylic paint.
A sanding sealer (including 'filled' shellac) has the purpose to fill the pores of wood, harden the wood and thus to aid in sanding. Traditionally, furniture surfaces are build up from multiple applications of shellac of dfferent dilution, moving from pumice-filled to pure shellac. If you will be using a paint that dries as hard as e.g. shellac, you may forego the sanding sealer and build up the surface with that paint. Modern acrylics, however, can take month or even a year to reach a state of polymerisation and hardness that allows you to sand in the same efficient way as shellac. So, applying a sanding sealer first and then the paint is a more efficient process.
- Bob Cleek, Roger Pellett, mtaylor and 2 others
5
War of 1812 Sail Color
in Masting, rigging and sails
Sails are more or less white/grey, i.e. have essentially 'non-colours' in a physical sense. This means that they would attain a certain hue that depends the on the surrounding lighting, reflecting the light that falls onto them. Artists would try to represent this, if they were reasonably good artists. Beginners or 'naive' painters would tend to represent the actual body colour.
This applies in theory to any coloured surface. Its appearance would be different from the true body colour and it has been the objective of artists for century to represent the appearance as well as possible, rather than the true body colour. The lighter the body colour the more pronounced this effect is going to be.
As colour photographers (before the age of automatic electronic white balancing) knew, there are certain hours of day, where these effects are more pronounced, namely early in the morning or before sun-set, you have a warm, yellow-reddish light, while at noon everything appears to be more blueish. This atmosphere the painter may have tried to evoke by giving everything a certain tint.
So, from a painting you can probably deduct, whether a part say was blue, red, or yellow, but what the actual hue may have been one cannot be too sure. A blue may have been in fact something greenish blue, a red may have been actually a reddish brown, or a yellow an orange, etc.
And, indeed, it is know that painters have embellished the subject, say by giving the impression that decorations where gilded, while in fact they were painted in yellow ochre on the real ship, etc.
