Posts posted by wefalck
  1. The binnacle discussion almost makes me going back to my 30 year old model ...
    It seems to me that the Flinder's Bar is still there. One can vaiguely discern the brass capping in front of the wooden body.
    These fancy skylight were not necessarily permanent installations, but could be removed and stowed before rough sea-passages. There would be the coamings left and a simple cap that could be made watertight with a canvass cover like any other hatch. It looks, as if there was a removable section in the deck planking. I quite like these Victorian or perhaps one should say here Wilhelmenian structures with the panelling and brass bars.
  2. It is tempting to show this, because we are used to see this on modern windlasses/capstans, but the hawsers would only be taken around it, when heaving-in the anchor. For letting go, the hawser would be arranged in long bights on the deck, with the end secured appropriately (you don't want to loose the hawser ...). The bights would be tied together at intveralls with light rope. The hawser would break these ropes, which would reduce the speed of running out. Depending on wind, sea and space around 3 to 5 times the water depth would be payed out. The hawser would be stopped appropriately by taking it around bitts. Alternatively and as noted by others, the anchor can be rowed out and dropped a the desired location. In any case, the ship has to be let drift for the anchor to securely bite.
    It is always wise to have two anchors out, particularly when anchoring over night. An anchor can come adrift easily. Normally, the two anchors should not prevent the ship from swinging with the wind or tide, if there is enough space. The two anchor cables would be tied together with a lashing just in front of the bow to prevent their uncontrolled crossing. I think there is picture of this Lever's book.
    If there is not enough space for the ship to swing freely with wind and tide because there are other ships in the anchorage, because of nearby reeves etc., one will have to put out one or more stern anchors. This is a less desirable situation, as the ship will ride harder on its anchors, putting more strain on the cables and risking to break loose an anchor.
    Only when taking in the anchor(s), their cables would be taken around the windlass/capstan (or a messenger be use). Neither on the old-time windlasses nor on the more modern 'patent' windlasses there is a way to hold the pawls in a disengaged position. On patent windlasses the pawls on the levers aren't even easily accessible.
    On (sub-)modern hand-cranked or power-driven windlasses the motive power is applied to a lay-shaft that can be disengaged from the shaft with the drum(s) through a coupling. Such windlasses have band-brakes on the main shaft to control the running-out of the chain that is permanently taken around the drum. Their pawls can be arrested in a disengaged position, if they act on the main- rather than on the lay-shaft.
  3. Putting it into the checked-in luggage will you get around this, but beware that customs can open any luggage they find suspicious. I did bring back piles of Sherline equipment (including drive units) from USA trips that way.
    You will have a maximum worth of goods that you can import as a tourist coming back that depends on your country of residence. Beyond that you will have to go through the 'red' channel and declare your purchases. How your goods are assessed can be a bit of a hit and miss - customs officers are not always sure how to categorise 'exotic' articles. In most cases you will have to just pay the VAT though. It is a good idea to keep invoices and also documentation material, e.g. catalogues, to show customs (and security) what the strange equipment is being used for.
    The main culprit for the exorbitant shipping costs from the USA is the US Post Office, who decided around 2004 to abandon 'surface' shipping as an economical option. You may have had to wait for your parcel two to three mounths, but it was way cheaper. Mr. T. would do the US retailers and customers in the rest of the World probably a favour, if this was re-introduced ...
  4. Good points by Jaager. One needs to understand the mechanism of bonding of glues/cements and different types of surfaces.
    There are two fundamental types of fitting:
    - the parts are held together by interlocking; an example are screws, where the male and female thread interlock; this is usually the strongest joint.
    - the parts are held together by a force exerted on them: an example are nails, where the friction from the compressed wood fibres keeps the nail in.
    If the surfaces are sufficiently rough for the PVA to key-in, the glue will form an interlocking joint.
    Cementing metal to metal or other surfaces with CA, mean to largely rely on physico-chemical interactions with certain parts of the CA molecules and the atmospheric pressure that pushes the CA onto the surface. Particularly with shear-forces, it is easy to peal off the cement.
    For this reason it is always a good idea to provide for some interlocking. Wooden dowels combine all the different actions. Glued carpenters' joints are another example of combining the different types of actions.
  5. This looks like an elaborate procedure ! The idea of milling both brackets of the regulation spheres in one piece sound like a good idea - makes the whole thing more solid. I gather you will have to slot the binnacle then for this. I remember me struggling with this part in the days before I had mill ...
  6. Oops, have to check this out. The binnacle was made in about 1990, when such detail research possibilities and my library of period books were more limited. I would have thought that these compensation balls were in use from around the mid-1860s or so, when iron ships became common. Indeed, in earlier days they put the binnacles on long 'masts' above the deck.
    I cannot change this anymore, so we assume the tug was still in operation in the 1880s ;)  In fact, the design is from the mid-1860s, but the lines etc. were published as a worked-through example in the first German textbook on iron shipbuilding of 1869.
  7. Keith, the 'appendage' is the lamp to illuminate the compass. It is obviously an electrical lamp on the modern version, as otherwise the binnacle cover would have had a short 'funnel' on top, to release the hot air from the petroleum lamp.
    For starting a drill hole at an angle, I use an end-mill that cuts over the centre. In this way the drill doesn't wander off.
    Nice job, btw.
    This is a specimen I did some 30 years ago (diameter about 6 mm):
  8. Forty layers seems to be a bit exaggerated. If one needs so many coats, it means the wood was not properly pepared (by modern standards). In the old days only shellac and pumice was used, but today good sanding fillers on nitrocellulose basis are available that cut down the effort. It also depends on the kind of wood, the larger the pores, the more work. Dense wood works faster. There is also the risk, if one does not work fast enough or too wet, to dissolve too much from the underlying layers and then you have to begin again. In practice, I found a couple of coats of sanding sealer and two to three coats of shellac are sufficient, if you don't want a mirror-like surface (which I don't like anyway).
  9. The brand-name is Rohacell and it is made by Evionik Industries, formerly Röhm GmbH in Germany, who are the inventors and producers of PLEXIGLAS: https://www.rohacell.com/product/rohacell/en/
    To be honest, I don't know exactly, how Rohacell is made, but to my knowledge it does not contain cenospheres, but is just the co-polymerised acrylic and acrylimide resin. It is seem that the monomers are heated to 170°C, whereby they begin to foam an polymerise. It is a true foam, not sponge, meaning that the bubbles are not connected and, hence, the uptake of humidity is limited.
    I would know, where to buy the stuff in the UK. I was lucky that my late father worked for a the pharmaceutical daughter company of Röhm GmbH and that at that time I had easy access to everything related to PLEXIGLAS. In Germany PLEXIGLAS and Rohacell are sold in small quantities by shops catering for the builders of architectural models. I didn't check the prices, but it certainly is more expensive than the common 'styrofoam'.
    The pores of Rohacell are very fine and the surface of the sheets or blocks is quite smooth. It can be easily and cleanly cut with a knive or any saw. I can be cleanly sanded with sharp edges. The dust is a bit messy, at it is very light-weight. The sheets are somewhat brittle and thin sheets can be easily broken into pieces.
    Unlike 'styrofoam' it is not dissolved by the common contact cements. To the contrary it can be glued very well with these, CA cements, or cements for acrylic glasses.
    Once I have the current project finished, I am planning a somewhat innovative approach for a small-scale model, where I will cut the frames from PLEXIGLAS, fill the spaces with Rohacell to aid fairing and incease stability. The hull will then be planked with either strips of styrene sheet or of phenolic resin sheet. I am not such great fan of styrene, but it can be quasi welded to the PLEXIGLAS frames using ordinary styrene cement or dichloromethane.
  10. They are certainly not a brand, but probably a watchmaking supply house. We had a similar discussion in another thread a few days ago. Watchmaking threads do not fit neither into the metric nor Imperial threading systems. So you will not find easily any hardware, screws or nuts, to go with them.
    Personally, I would not use such threading plates for two reasons: if one frequently thread-size becomes worn, you have to replace the whole plate and they are more unwieldy to use than individual dies. These plates were primarily designed to work-over damaged screw-threads - you just screwed down the screw into the plate, not to cut completely new threads. Another application was to cut a short new thread onto a piece of brass wire held in a pin-vice, e.g. when repairing the hinges in pocket-watch cases.
  11. You will never know what will happen to a model in the future, but as was noted above, any structure made from wood is not very forgiving with respect to dramatic changes in humidity. That's a fact of nature and there will be other parts of the model than the hull that are likely to suffer. So, as long as you are in control of it, try to keep it in the same kind of environment.
    Plywood is made to counteract exactly that problem by having layers of grain running cross-wise. Hence, you could use pieces of plywood as fillers. Not so easy to work, however, Otherwise, a fine-grained not too hard tropical wood will do as well. Making the filler pieces just as thick as needed and running the grain along the ship, as noted before, will minimise the force the filler pieces can excert on the framing.
    In general, it is a good idea to use a wood that is a hard or softer than the plywood bulkheads, but not much softer. If the wood is too soft, such as balsa, fairing becomes more difficult and you kill the effect that you are trying to achieve - to make fairing easier. If the wood is too soft you will get a sort rippling effect, the harder bulkheads protruding. If the wood is harder than the plywood, you are going to have a tough time working it down.
    Many years ago I built a steamer-model with bulk-heads sawn from brass sheet and filled the space between them with an acrylic foam. This is essentially foamed-up acrylic glass and made by the manufacturers of PLEXIGLAS. This foam is very stable and doesn't shrink. It is used e.g. in aircraft construction.
  12. Traditional French Polish by rubbing-in pumice with shellac is a bit outdated for a project like this. A cellulose-based wood filler does the same job. However, rubbing down gently a varnish coating with pumice powder and e.g. a humid cotton ball takes out any traces of wiping- or brushing-on the varnish. It leaves a matte to satin finish that then can be polished to a gloss using polishing wool (as you would use for a car, for instance). This procedure reduces the thickness of the varnish to a minimum and gives a very even surface.
  13. Well, my Canadian friends roll out the barbecue, when the temperature rises above freezing  :stunned:. We central and northern Europeans are used to well-heated places in winter - strangely enough the southern Europeans don't seem to mind the cold in their houses, although it can get pretty cold during winter nights - uncomfortably cold actually. Chacun a son gout ...
  14. Isn't 12°C a bit on the low side ? I would be freezing to death in such conditions and most varnishes and lacquers seem to be set for a tempature range between 15°C and 25°C.
    Apart from that, the hull is looking just gorgeous  👍👍👍   Wouldn't want to keep it as a kind of sculpture and make another one for the real boat ? 😏
    Otherwise, I think she will also look very elegant in white above the waterline ...
