Everything posted by wefalck
There is no 'scale' for rivets, only size. So the question is how big on the prototype would these rivets be? Second question: what type of rivet? There are many ways in which rivetting and forming their heads can be performed: half round, countersunk (barely visible on a model), half countersunk, flush (which then would be invisible on the model), hollow rivets, etc. So a picture of the prototype you want to achieve would be needed to give you informed advice. I would, however, suspect that rivets in 1/200 scale on AA gun mounts would be rather small, with heads of a diameter somewhere around 20 mm max. This means, that in at a 1/200 scale we are talking of diameters of less than 0.1 mm. Assuming that we are talking of half-round heads, the only practical way would be tiny (really tiny) blobs of paint or white glue. It would be a challenge to achieve consistent sizes. In summary, I think I wouldn't bother. The tool you showed, although I don't know it, seems to be the kind used by aircraft modellers to indicate flush rivets by slightly marking the surface. This is not what you (presumably) need and the resulting marks would be grossly overscale anyway.
What I tend to do to such flat black parts is to run a soft pencil along the edges etc. to highlight them. Using a cotton stick, you can also slightly rub the graphite away from the edges. Similarly, using dark-grey pastel, you can lightly highlight areas that would normally be more illuminated to accentuate say round parts. Depending on how you want to show the model, pristine builders's model style or slightly 'weathered', you can add traces of ash or rust around the furnace of the boiler using white or brown pastels.
- 128 replies
- zulu
- sternwheeler
Just stumbled across this log, while I am waiting for something to dry in my workshop ... I think the model looks very convincing and the strategy is good in the absence of real plans. There would have been, however, sources of plans for both, commercial and naval vessels built in and around Venice, that one could have explored. Venice at this time was under Austrian rule (formally Kingdom of Lombardia-Venezia) and the arsenal built for the Austrian-Hungarian navy - miraculously the archives largely survived two evacuations: 1866 to Trieste and 1919 from there to Vienna (though I seem to heard that many boxes are still unopend in the national archives there ...). So some lines plans that could have been adapated may have been there. Depending on, where the other ships your are modelling were built, this might be still a possibility. I like unconventional approaches to construction when it serves the purpose. At small scales wood is not always the best and most convenient material. Wood can also be messy to prepare, if you don't have a suitable workspace. And at small scale, the wood-grain is usually to coarse and needs to be covered up with fillers. So acrylic, styrene, bakelite-paper etc. can be indeed better options - even when the final surfaces are supposed to bare wood, as for decks. Painting may give a much more realistic appearance at small scales. At small scales real copper indeed probably is not the best material to represent coppered ships' bottoms. Very thin paper painted is a better way - I agree with you there. However, your overlapping plate-seams appear too pronounced, I must say. To be quite harsh (apologies), I think it spoils this lovely model somewhat. If you look at images of real coppering (me and others have posted a lot of pictures here on MSW), show that the seams are not very pronounced, as the copper-sheathing in fact was quite thin. I would have probably just butted the plates against each other, as even the thinnest paper would be overscale. Looking forward to further progress 👍🏻
Scale size questions
wefalck replied to Desertanimal's topic in Building, Framing, Planking and plating a ships hull and deck
The problem will be exacerbated when you work from scanned original drawings. Every line that is not absolutely aligned to the axis of the scanner will become a fuzzy, jagged something. There are a few strategies to overcome the problems discussed above: - never ever use chain measurement. By way of example, it you have a row of identical boxes fitted to each other, don't measure each individual box, but measure the overall length and divide it by the number of boxes to give you their dimensions. - Similarly, when drawing plans for a ship, do not start from the details, but from the overall dimensions and fit the parts in. The percentage lengths mentioned by Dr PR above go this way. - Think about the practicalities of building: what materials and what tools do I have available or can obtain; dimension parts accordingly, if the deviation would not really by visible. - Think also which part would the easiest to make fit to other parts; say you have to make a flange for a pipe, in which case you may fit the inner diameter of the flange to the available wire/round stock; the inverse, could be also the case for bigger parts, where it may be easier to turn the pipe to the diameter of a flange for which you had a drill for the whole; etc. - Unless I would make a drawing for publication, I tend to make no real drawings for parts, but rather (computer) sketches to which I add the measured/calculated dimensions; I then work from the numbers, rather than taking off another set of measurements from a drawing. - Work from parts with well-known dimensions; say, you need to construct a shell-locker, then start with the dimensions of the shell, which typically are very well documented in the literature of the time, etc. -
That's kind of strange, that the the bulkheads are behind the gun-ports. Normally, such laser-cut kits are well-engineered ... I gather you will have to show the lids closed in this case, at least the ones in front of bulkheads.
- 62 replies
- belle poule
- OcCre
"I think good lighting helps more than magnifyers." ... Unfortunately, there comes a time, when this doesn't help anymore 🥲
It also depends on for what kind of work you intend to use it: if you are working with machine-tools, hand-held drill/grinder or lathe etc., it would be advisable to use safety-glasses that enclose your eyes and protect them from flying swarf etc. Reading glasses are good, but do not enclose the eyes sufficiently. To my knowledge, however, the safety-glasses are only available with a x3 magnification. I have got a cheap version of the loupes dentist use these days, but they are designed to be standing over the patient and cannot focus close enough - we like to be with our nose closer to work, when sitting at the workbench. So, I don't really use them. For lathe- or milling machine-work I also have a binocular microscope that can be screwed to the bench. The depth of field is very short, so that it is not really useful for bench-work, but it is really excellent for observing close-up what a minute drill or milling cutter does.
Well, in old days I had small pocket calculator on the bench. Now, that the iPhone is always near me, I use its calculator - that's the simplest and fastest option. For converting imperial into metric measures or vice versa, you just need to remember that 1" = 25,4 mm. Converting metric measures into fractions of an inch is not straightforward on normal calculators, while the opposite is easy. -
Some years ago, I considered making a model of her based on the Heller plastic kit, which is based on the plans published by the Association des Amis du Musèe de la Marine (as presumably the OCCRE-kit is). The project was abandoned due to the extensive changes that would have needed to be made to the plastic kit. However, in this context I took a number of photographs of the model in the museum in Paris (which, together with other sources preserved in the museum's archives, formed the basis of the plans of the AAMM). The model is in the 1839 livery, when she was painted black on the occasion of bringing back the remains of Napoleon I from St. Helena. You can have a look at the pictures here: https://www.maritima-et-mechanika.org/maritime/models/bellepoule/bellepoule.html. The model is not on display currently, after the refurbishment of the museum BTW, Odin is a Germanic god, not a Greek one 🫣
- 62 replies
- belle poule
- OcCre
She is indeed coming along nicely 👍🏻 Concerning black 'marker' pens: there are now on the market several brands of 'artists' pigmented acrylic brush pens. Being pigment, rather than dye, they should not fade, particularly the black ones, that presumably contain carbon-black as pigment.
- 2,697 replies
- heller
- soleil royal
(and 9 more)
I have been away travelling almost every second week for the past couple of months or so and barely could follow what was going on here. It seems that you are making steady progress in spite of the family health issues 👍🏻 For years I have been using magnifying (only x3) safety glasses, but together with my myopy it should give a total magnification of around x7. If I need more I use an optivisor, but found it not so comfortable for longer work, also because one has to come close to the object.
Oyster smack from which country and period? Oyster dredges do vary considerably ...
If the part is really Zinc (and not white metal as usually) than this would have been a bad advice - Zinc is not very stable in acidic environments ...
Depends on the period …
Black boot-toppings came into fashion, when warships became grey, because harbour waters were full of oil and grime and that would leave nasty traces on the grey. In many navies it was common to have have a white boot-topping above the coppering and this practice continued, when iron ships' bottoms were painted red.
I think I would view these canopies like roofs on dwellings in shanty-towns: the people put over them what they had to hand and what did the job. I don't think that a strip of cloth would be terribly wrong. It's the sort of thing ethnographers worry about, when they want to find out, what was 'authentic', while the objects of their research in most cases are much more pragmatic.
- 286 replies
"but many modelers praise the holes on both sides of the block because it does not require inspection during assembly. You take a block and attach it, and that's it (it will always be OK)." ... well I think, a modeller who opts for this kind of quality of blocks would/should take the time to look at the blocks before stropping them ... we are not making chains with beads, but each block needs to be treated carefully and individually. My practical experience (not with 3D-printed, but with blocks machined conventionally from bakelite) is that for a 0.2 mm rope, the hole/passage should be something in the order of 0.25 mm or even 0.28 mm. Even with stiffening the point with varnish or CA glue, the 'rope' always become a bit thicker when pushed through a block and hence gets stuck. This is unfortunate and I have not yet found a good way around this.
Yes, I don't understand why people drill holes or provide for them in their CAD-files at both ends of the blocks. There is no need for this and the sheave should almost touch the slot on one end. I gather there is a tendency to make the sheaves/holes wider than the textbook dimensions, because it makes it easier to fiddle the ropes through. In theory, the sheaves would only be a tad wider than the rope for which they are meant. It would make sense to make the sheaves to scale in 3D-printing and then to leave to the buyer to open up the hole with a drill or a watchmakers reamer, if needed.
I gather such parts are not (die-cast) zinc, but rather white-metal ... However, they shouldn't be black anyway, but painted in whatever the colour the ship would have been painted in, often white or green for instance. Railway or figure modellers have a lot of experience with white-metal parts and there is a lot of information on the Web, how to work with such parts.
Do things always have to have names? Sometimes people just make something that seems useful to them, without thinking that someone else wants to 'classify' it. It's an unusual rig anyway, with a lug that has boom etc.
I think in Europe we get mainly birch. Steamed beech might be actually better, because it is very malleable. I tend to hesitate to kind of disaggregate wood by squashing it, but making a sort of compound material with white glue as binder could be an idea to try out. Rather than hammering, I may try out the wire-rolling mill I recently acquired - just feeding it in over a certain length. As the distance between the rollers can be preset, it can be done in a controlled and repeatable way.
