Everything posted by wefalck
  1. A 'gasket' would be a braided, flat rope, either three or four braids, like little girl's braids. On square sails these are attached to the jackstay and drop down the front of the sail and have a kind of eye the hangs down on the back. The gasket has a toggle in the end that is tugged through the eye. It can also be the other way around, that the toggle is close to the jack-stay and the eye is in the end of the gasket. Arrangement can also vary, depending on whether the sail is furled in front of the yard or above it - different navies and different ship owners/masters had different preferences. For main gaff-sails there may be different configurations depending on the time and the geographical area. However, gaskets or ropes were not used with loose-footed sails, but rather the lowest reef-points would be used to tie the sail to itself and to the gaff. It would/could not be tied to the boom. If the foot of the sail was laced to the boom, the reef-points would need to go around the gaff and the boom, unless a wooden jack-stay was used (as seems to have been more common in the USA), then the reef-points would be tied around it and the gaff. If the boom is rested on a crutch, when the sail is furled, one can also use the main sheet to lace together boom, gaff and sail, which is something commonly done on small boats. I am not sure about the procedure for the loose-footed fore-sail. The gaff would be certainly lowered (remember 'standing' doesn't mean, that it cannot be lowered!) to furl the sail towards the gaff, but the reef-points could not be tied to gaff probably. However, the reef-points can be used to tie the sail to the hoops. For the hoops above the highest reef, ropes or gaskets could be attached to the hoops for this purpose. On would presumably first furl the sail to the gaff and then proceed top-down along the hoops, while the gaff is being hoisted again.
  2. It would be good to have a catalogue of fabric names (in different languages) and either their (commercial) use or (generic, not store names) potential sources. There may be many different types of potentially suitable fabrics, but they may be difficult to get (in small quantities) for the average person, unless one has connections to professional users. There are two factors that will be of particular importance, the thread count or density of weave and the thickness of the fabric. I am well aware that 'thickness' means little for the professionals dealing with fabrics, as it cannot really be determined due to the compressibility of the material (thread and weave). However, one can measure say sail-cloth of different weight as it comes of the bale and then divide it by the scale factor of your respective model. This gives you an indication for what you have to look for in terms of fabric 'thickness'. If, for example, a sail-cloth had a thickness of 2 mm, you would need to have a thickness of about 0.02 mm (or 0.0008") in your case. There are lots of fabrics that are very thin, but have a loose weave or vice versa. What we need would be a fabric of very high thread count while being very thin - sounds expensive ... Another factor to consider is the stiffness of the material. Real silk threads can be made extremely thin and very flexible, but silk is problematic material from the conservation point of view. Man-made fibres still tend to thicker and generally much stiffer. The stiffness is not very important, when you are aiming for sails bellowing in the wind, but on a real ship only certain sails would be set under given conditions, while others would be brailed up or stored. So the material will have to look convincing in this state. There are lots of different materials that run under the denomination of 'silk-span' (isn't it even a brand-name originally?). As such the material tends to have a too loose weave, which is why me and others have impregnated it with varnish or paint. The objective is to have a material that is reasonably tear-resistant and shows just a hint of texture. Such tissue cannot be sewn, because it is too loose and there are no needles fine enough anyway. Seams, doublings etc. need to be applied using glue or varnish. An alternative to silk-span may be screen-printing fabrics, but I have no practical experience with them. They are available in a wide variety of thread-counts, but also have a loose weave because it is the 'holes' that are important for the original application. I have the suspicion that silk-span is a secondary application of these fabrics. A colleagues of mine some time ago came up with a technique by which a very fine and long-fibred Japanese tissue paper is sandwiched between two layers of paper restoration tissue. The latter is impregnated with a heat-setting acrylic resin. When ironed-on it is almost invisible on the 'repaired' paper. Using this technique, one can produce quite realistic seams and doublings, while retaining the translucent quality of the 'sail', which was his objective. I have acquired the materials, but have not tried this out for myself yet.
  3. It would also depend on where you are located. Sherline is more expensive over here in Europe and Proxxon outside Europe. Sieg and under whatever other names they are sold over the world vary considerably in price. Prepare to basically get some 'castings in advanced state of machining', when you go for a bargain offer. Lots of finishing and adjustment work needed it seems. Adjustment will be needed for any machine after delivery, so don't expect it to work perfectly out of the box. And I agree, it would be nice to have an Aciera or a Sixis ...
  4. At 1:96 scale I would rather not use any cloth for sails, it is far too coarse, even the finest ones you can find. Have look around the forum there are several threads on using silk paper or 'silkspan'. Dito for rolled hammocks. For netting at this it is not so easy, as most commercial netting or screen is likely to have too fine mesh and/or too thick threads. Printing silk-screen could be an option or recycled silk teabags. There is also wire- or sieve-mesh, but it may have the same problem. Drawing every second thread in both direction could be an option.
  5. It seems that this officer in the 'Ottonian' Navy was British then. In this case I would assume that his terminology was reasonably good. However, as I said the use of terminology may not have been as strict, as we would expect from today's perspective. Re-reading the passage, perhaps Mr. Hastings did not actually see the gun himself, but was relying on what the schooner owner told him?
  6. Well, first of all is the original text in Greek or in English? Perhaps these are just translation errors. Today, we seem to be obsessed with 'correct' terminology (sometime perhaps to show-off, I gather ...), while in the old days tended to you terms much more casually (which arguably now causes problems for historians, of course). Perhaps, for the author in question the distinctive feature of a 'carronade' was that it was slide-mounted and not so much what the barrel looked like. Up to first quarter of the 19th century, indeed, a slide-mounted gun was virtually always a carronade and not a long gun. It was about that time that people realised that guns above 32 pounds on 'free-wheeling' carriages are difficult to control and can be quite dangerous. In addition, small numbers of big guns on small ships are better deployed on slides, firing from the centre-lin of the ship, than moving them around to different gun-ports.
  7. This is definitely not a carronade. However, it may be that the photograph was distorted by the book-producers to fit the available space. The carriage looks rather low. Early carronades were mounted on normal trucked carriages. Also half-trucked carriages were used sometimes, I think in particular in France. But then quickly the slide carriages became common for them.
  8. On the sheaves vs. blocks question: I have the feeling that the sheaves went out of fashion in the later 19th and were replaced by blocks bolted to the deck. The idea is turn the run of the rope by 90°, so that more men could work on it. If you pull straight down on a rope you can use your whole weight, but you could have only two men working the rope. Blocks were commercial items by then that would be mass-produced, while a bitt with sheaves would have to be made by the shipyard and would have been more expensive. Also, the sheave-holes weaken the bitts.
  9. Mostly, carronades were used as broad-side guns, whose carriage was pivoted at the front. However, the sliding carriage could also be designed with a pivot in the centre, so that it could be rotated through a full circle, when mounted on the centre-line of a ship. I gather that this what is meant. However, I doubt that using a carronade is a good proposition for this. Carronades are short-range guns and as such would have a considerable muzzle blast, which could blow away bulwarks and damage the deck-planking. Normally, long guns were used in such positions.
  10. I am not sure, whether she would have had a coppered bottom during her professional life. Today, due to the penetration of terredo navalis through the Channel into the North Sea, she certainly will need protection though her berth is in brackish water, in the Elbe estuary.
  11. I didn't realise that this would be a clinker-built. Nice job ! Did you chase the upper edges of the lower planks to allow the following strake to run into the stem rabbets?
  12. The company that makes them is called Small Stuff: https://www.smallstuffmodels.com/p/products.html#!/1-72-Detail-Sets/c/4286864. However, I just realised that there may be supply disruption due to the war ... Most of the engines are of the radial type, but they also have a couple of others: That's a Mercedes 200 hp one.
  13. I think I have seen this strange fore-and-aft arrangement for a steering wheel on some naval launches too. Surely needs a bit of time to get used too - can lead to fatal errors (the pilot-schooner ELBE Nils is building here on the forum was run over by a freighter a few years ago because the amateur helms-man confused putting the helm to starboard with putting the rudder over to starboard ...). Since I saw these beautiful 3D-printed WWI aero-engines available in 1:72 and 1:48 scale I am tempted to make a (free-lance) runabout with one of those - post WWI a lot of these became surplus and were used in speedboats.
  14. If have been to the yard, where they built (S.M.S.) GRAF GOETZEN for the lake ... Coming back to the problem in hand: an option would be to roughly cut the disc from 0.5 mm brass sheet and then use what the watchmakers would call a wax- or a cement-chuck - You take a piece of round bar, doesn't matter what metal, chuck up in your three-jaw chuck and then face it off flat; to this you cement your roughly cut brass disc using CA or shellac and turn the outside and the grooves ...
  15. As you have a lathe, why don't you simply turn them from brass or acrylic stock. They will have to be painted black anyway, I suppose. They look varied a bit, but they often had shallow concentric grooves as an anti-slip feature and typically to sunk-in handles give a fulcrum to turn them - they were locked with a sort fo bayonett-lock into a circular cast-iron frame in the deck.
  16. I was quoting from memory and my memory sometimes is not the best anymore ... so obviously I only scored a near hit. As to the violin: these were used, inter alia, as 'party boats', so not surprising that there would be also some musical entertainment.
  17. A 'standing' gaff does not mean that it cannot be lowered. It means it is not normally lowered to make fast the sail. Standing gaff sails were typically fitted with three brails that allows it to be gathered up towards the gaff and the mast. Of course, when reefing, you would lower the gaff. Towards the end of commercial sail and on some steamers there were real 'standing' gaffs and the sails were attached to them with a rail and runners, very much like our curtains, so that they could be gathered up to the mast. It seems that on the British Islands the luff was mostly hooped to the mast, while on the continent and on the other side of the Big Pond lacing was more common, particularly also for smaller boats. Similarly, in Britain gaff sails were only fixed with their clew to the boom, while in the USA they were mostly laced. In the last decades of sail, lacing became more common everywhere. When reefing a loose-footed gaff sail it is not tied down onto the boom, but to itself, in the same way as you would reef a stay-sail or a boom-less gaff fore-sail. If you want to read-up on handling gaff-sails, I would recommend John Leather's 'Gaff Rig', though he is a bit biased towards yachting practice.
  18. Didn’t Ab Hoving built a model after this drawing?
  19. Hhm, I don't think that this was such a good idea to put the sanding filler onto the wood before glueing - in this way the contact cement cannot key into the wood very well anymore and the solvent from the cement has nowhere to go to ... hope your copper sheathing will stick in the longer term
  20. That's what I would have thought. It's quite fascinating to see such a schooner being operated by a well-trained crew - around 2000 I was sailing in the British Virgin Islands, when in one of the little ports we stayed one of them arrived at dusk under sail, bearing up to the jetty with precision and taking down the canvass in a matter of seconds literally and making fast. Unfortunately, the next morning, when I wanted to check-up on her, she was already gone again. I finally got around to really read John Leather's 'Gaff Rig' and he write quite a bit about the crews of these pre-1930s yachts, their professional crews and captains, many if not most of which in Europe were fishermen from SE England. They fished in the winter and manned the yachts for racing in the summer.
  21. ... takes up a lot of space! I wonder how it would affect the sailing, as it is probably quite a deck-load.
  22. And no one imagines how much work goes even into such mundane pieces of equipment ... The launch is quite big, where is it actually stowed on board?
  23. I just had a look at the images that I had collected for my series of articles in our quarterly DAS LOGBUCH and there are one or two photographs taken by Gutstav Caillebotte's brother that show a Clipper reasonably close and it looks indeed that they used small deadeyes ...
  24. Thanks, gentlemen! @Keith Black I don't have a time-plan, it takes as long as it takes. Making and in particular installing the boat will be another challenge ahead, as this arrangement will be very flimsy. @starlight to your questions: - sorry for loose use of terminology, yes they are the same - sometimes my mother-tongue confuses me also, as it is 'Vordeck' in German ... - as said in an earlier post, the idea behind the planking pattern seems to have been to arrange the seams in the direction of the gun-blast to reduce the risk of damage; the muzzle is quite low above the deck. - I do have information what kind of decking material was used by the Navy in principle, but I don't know what was used on this particular class of boats; teak was expensive, but makes sense on this exposed deck; perhaps I should have changed the decking in the barbette to this improved paint scheme, but I don't want to rip it out again and repainting in the confined space will also result in a lot of collateral damage - I tacitly assume that it may have been another species of wood; once the gun has been installed, it will also be much less visible.
