Everything posted by glbarlow
Great work as usual on the no rush planking. I like how you demonstrated the bending and taper points. Enjoy your holiday. Ours was supposed to have been a trip to Spain and Portugal, we would have left next week. 😕
- 261 replies
- muirneag
- vanguard models
The same but different hull planking. Looks like a lot of fun. Thanks for the detailed explanations.
- 261 replies
- muirneag
- vanguard models
Great work! Nice to see a little heads up on what I have coming next, just being half done with bulwarks planking. Those scarf joints are scaring me a bit. Glad to see you got through that step. I'm sure I'll make a half dozen before getting one I like.
- 54 replies
- cheerful
- Syren Ship Model Company
Not at all, I'm envious of having the skills it must take to build a musical instrument. We build boats, but don't rely on the quality of our builds to create music... Chris' designs are such you should not need a drop plank, provided you begin tapering early at the bow. I've not started my Flirt yet, a long way to go with Cheerful, I'd be surprised if stealers are needed, but they are relatively common and not a big deal - especially as the hull will be painted to the waterline so they won't be visible anyway. I do think perhaps your taper at the stern may be a bit too much. The tick marks there should go all the way to the keel, not just around the bulkhead. You end up sanding that down for the sternpost to fit, but the measurement should include the length of the stern. The number of planks at the stern should equal the length from the gunport pattern to the keel including curves - which makes paper tick strips essential to do the measuring. I do all my plank bending with a board, clamps, and a travel iron. You'll see in my Cheerful log I bend any direction including some severe twists at the stern. Cheerful is single planked so I had to be precise with the measuring, cutting, tapering, and bending. It had no tapers at the stern, so there's that. Just to be contrarian, I don't think either bottom plank is too high, especially for the first planking and especially if you already think you need stealers. A KEY point is this is your first planking - all you really need is for it to look like a ship when its done. Fill it however it takes as long as you can sand it smooth to the shape it needs to be, including the abundant use of wood filler as needed. The tick marks and the use of a planking fan might better guide the second planking to reduce the number of stealers, but as the hull will be painted using stealers on the second planking is fine. I hope this helps and doesn't just confuse you more - I do explain a bit how I do it in my Cheerful build, linked in my signature line below.
The tick strips and planking fan method works great to build a tight hull. It's a good practice to recheck those tick strips every few planks just to make sure you're still on track. Beveling the top inside edge of the plank is also good practice for ensuring a tight fit, something even us non-guitar makers know to do. Your knowledge of musical instruments is of great benefit, you're starting way ahead of most first-timers. As you'll see from the Chuck videos for the planks to curve up and in at the bow they need to be bent "the wrong way" bent down. Your monster plank bender might make the edge (vs. flat side) bending a bit of a challenge but I assume its a tool for your instrument making you're comfortable with, I'm sure you'll sort it all out. Nice work, the first planking looks tight and well tapered.
Thanks for the kind comments guys, they are appreciated! I really like the print. It's quite amazing to see how detailed they are for something done over 200 years ago and more amazing that from it a ship was built. At any given moment my Cheerful might become Surly - I'm trying hard to prevent that from happening 🙂
- 778 replies
- cheerful
All those work for me. Surely they are in the dictionary. I hesitate to note I just ordered that book🤪
- 725 replies
- vanguard models
- speedy
- 725 replies
- vanguard models
- speedy
You guys have a lot of time on your hands 😄 I have very limited nautical knowledge as Derek will attest. I've always know this as that long skinny thingy with holes in it that the rope loops through back to the holes in the mast top thingy. No dictionary used 😄 I may have to get the one Derek listed, I admit am frustrated sometimes not knowing what stuff is called - though thingy covers a lot of ground.
- 725 replies
- vanguard models
- speedy
In my defense autocorrect doesn’t know what a rabbet is and apparently doesn’t care if a rabbit’s bottom is sanded😳
- 725 replies
- vanguard models
- speedy
It seems you have good information to share, you should start a log. I enjoy passing on my trials and tribulations in the hope of helping others. I’ve actually worked out a process for the moulding and have a few practice runs that I’ll share in a future post. Thanks for sharing.
- 778 replies
- cheerful
I don't think I avoided all of them, but you're right. That's the fun on this semi-scratch build, not bailed out by laser cut kit parts. But then again, not limited by them either. Fun stuff...
- 778 replies
- cheerful
Before I get into starting the deck work I wanted to share the latest addition to my workshop, my framed print of HM Cheerful, a true copy from the UK NMM of the original plans. Note the matte color was selected to match my paint choice on the model. Cheerful joins a NMM print of the Pegasus on a different wall. It’s a bit high to get above the ceiling speaker volume control, but I’m out of other wall space. It looks really cool hanging there. Thinning the stern frames was the first frightful task, that one I avoided the Dremel sanding drum with the use of a jewelers saw (described earlier in the log). No such luck with the second frightful thing, thinning the bulkhead extensions and the port sills to a very thin 1/16th. So after convincing myself 1/8th wasn’t good enough I let the Dremel do its thing. However, the near magical step I did first was to line the bulwarks with 1/16th basswood strip between and below the ports. Aside from providing some needed strength these strips marked exactly how far and and how much to take out from the neighboring bulkheads and port sills with the Dremel. This worked great in keeping me and the sanding drum where it was supposed to be and not go where it wasn’t. I’m not sure how I’d have gotten an even 1/16 without a whole lot more trouble, not to mention not gouging my way through the hull planks. After getting the majority done with the Dremel I finished off with my chisels at the base where the Dremel couldn’t reach and then sanded it all out even with my various sanding tools. I used 180 grit to get the last little bit of the 1/16th thickness and 220 to finish it out. Did I mention 1/16th is very thin. My 1/16th thickness gauge came in handy to constantly cross check what was left of the once thick port sills. A lot has to happen right along the way for this build come together. The port sills were installed very early using reference lines on the bulkheads, later an outer plank was run beneath them following the sheer of the deck. That had to be done with a 1/64th clearance for the rabbet (and I thought 1/16 was thin). I actually did ok with that. I erred on the high side with the original port sills (no more than 1/32) because I knew, and did on a couple, I could file them down to the 1/64th rabbet height. Despite that I knew I had one port to address when I got to this stage. I filed this too low port sill completely flat to the hull, added a 1/64th strip, cut that flush, and painted it. You’d never know it was too low now. Improvise, adapt, overcome. I faired the top of the bulkheads and frame to provide a smooth surface for the false deck. Skipping this step would have resulted in a bump near the stern frames and a rough spot here and there along the frame former. It looks kinda pretty maybe I should just stop here. PS: I probably shouldn't have gotten carried away when I painted the counter and not painted the interior of the stern yet, kind of wasted work now. My process for cutting the false deck was to cut out the deck drawing from the plans, cut out the locations of the deck furniture and rubber cement it firmly to 1/16 basswood, and extended the center line through the openings. I cut it out with a #11 blade, the basswood was easy to cut, including the stern frame slots, skylight, and mast openings. It’s a tad confusing, you do cut out the paper to show the hatches and opening, but just on the paper (so I obviously did that before gluing it onto the basswood). Only the skylight and mast hole are cut through the false deck, the rest are place markers for other deck furniture. It was easy to peal off the paper, rub off the rubber cement residue with my finger and my false deck was ready to mount. I did have to do a little work to ensure it was centered, in addition to the dowel for the mast hole I jigged up a plug to fit into the skylight opening. Still not satisfied I cut little squares in the hatch openings (which I will cover or fill later). With the top faired there is a clear line down the center of the frame from the plywood lamination - the dark middle layer was perfectly centered, so I had only to match it up with the line I’d marked down the basswood. Now I won’t later be looking at off-centered deck furniture, at least not due to the false deck. So on went the Tite Bond III, a coulple of weights to hold down the center, and plastic clothes pins to push the edges down onto the bulkheads, and not mark the outside of the hull in the doing. A lot of tools got me to this point. Here are just a few of them. I’m on to planking the bulkheads followed by the moulding strips, I’ll save those for the next post. Thanks for stopping by.
- 778 replies
- cheerful
I'm building Cheerful, a 1806 cutter, just as Chuck describes. It's fun to get all caught up in how it was done on a real ship, but there is the practicality of building a model that achieves the look, "faked" or not. I think your most recent drawing is consistent with what Chuck describes, and recognizing it is a block drawing, properly shows how it is done on a model. I built the Lady Nelson before knowing this and unfortunately without some of these features. I'd encourage you to look at https://syrenshipmodelcompany.com and Chuck's monograph on Cheerful. The middle chapters address how to represent the deck of a cutter from a modeler's perspective.
I’m trying to think what it means that you have or even know about a book with this title🤣😂
- 725 replies
- vanguard models
- speedy
Personally I like fine brush strokes made from good paint with quality brushes. I enjoy the painting part of model building, plus I’m pretty good at it. I admit painting spars with an airbrush may be appealing and I’ve always used a cheap one for painting cannon barrels.
- 725 replies
- vanguard models
- speedy
Thank you for these comments and likes. I’d do a few things different now (especially that winch), but I enjoyed this little kit. A quick and fun build.
- 55 replies
- lady nelson
- victory models
