glbarlow
Everything posted by glbarlow
  1. Ha. We’re going on an Alaskan cruise starting from Vancouver in September, let me know how it goes. I hope you both have a great trip! Don’t forget the hard shell golf bag carrier to fill with the Alaskan Yellow Cedar 😂
  2. It your expansive build board is an indication you’re off to a great build. Welcome to the project.
  3. Precision here pays big dividends when you plank the counter and later and the transom piece. Test fitting Chapter 3 parts where you can really helps as does cut out copies of the friezes. it’s all looking great, nice work.
  4. Thank you. It’s such an important part of the model. Thanks. Just trying to do well with all that wonderful AYC.
  5. Thanks for the comment. I think it takes time because we know what we’re doing😊
  6. An Upright Hull at Last Thought I’d share a few photos of my Winchelsea hull upright. I thought about what would be easier to do now than later in the build, following the always good practice of reading ahead. I drilled out the rudder port. To line it up I cut out a copy of the counter frieze and loosely taped it to the counter (I’ll get a better fit, only concerned about the rudder port) after cutting out the black area representing the port, drew a pencil line, drilled a hole, and worked my way out with a #11 blade and sanding sticks. I pulled out the rudder pieces from Chapter 5 and held the two parts together that pass through the port (the dark line shown in the photo is the rudder) to confirm the hole was big enough. I stopped well short of the black line, I’ll adjust later as needed. The still unassembled rudder went back in the bag. I used the jig from Chapter 10 to determine the height of the stern frames and cut them down about 1/8th higher than the jig to allow for future adjustments. Why not paint them black, as they eventually must be, while I’m at it. I will admit I broke one during the hull planking, fortunately it was a clean break and easily glued back together. I waited until the planking was complete, it has bothered me looking at it all that time. Now it’s fixed. Finally I painted the stem. It was always going to be black, I’d rather deal with occasional touch up and get it done now while it’s relatively easy to do. With that the hull is prepped and ready for the next steps, the transom, upper counter, and quarter galleries - can’t wait. Once again, excuse the rushed iPhone photos with their work light glare. As always thank you for stopping by with your likes and your comments. I really appreciate it.
  7. Thank you. I just finished 4 months single planking HMS Winchelsea, a 1/48 frigate considerably larger than Vanguard. Though it took a long time it was and is much more enjoyable than those copper plates. Everyone should do it once 🤣Best of luck with yours, my anti-copper position shouldn’t deter anyone. It’s builders choice.
  8. The AVS was my first model. I learned a lot from it and enjoy the result to this day.
  9. Thanks Rusty, I do think imay have taken every plan a project to the extreme in some cases🤣
  10. It was a challenge for sure, but as Chuck says a slow process from the center out. Sorry you have to restart with the frames. I still vividly remember my Cheerful frame, nearly done, falling to the floor and shattering. That hurt, starting over is all I could do.
  11. The best alignment tool is that pattern cut out of the plans with everything cut but the frames, then double-side tape to middle two and use that to space the frames. then the window sills which in addition to length have a beveled angle to sort out. It’s a fun challenge.
  12. As I'm sure you noted the transom is curved, the outer frames are closer to the hull than the two middle ones, and that you'll be able to account for that curve once its "in air" on the frame. The bottom outside of those doubled up outer frames get carved quite a bit to follow the curve of the wales. When you get to that point I found a cutout of the transom frieze a good tool to match up that curve with the wales and the frieze. The frieze design allows a little room to be small, but no room to be big on that shaping.
  13. Your precision will pay dividends later. The hull is so big that small errors in geometry are magnified, very thorough approach to keeping that from happening. Surprisingly for me I found the fairing (and later planking) between bulkheads S and U a bigger challenge than what I would have guessed would have been U and W. Getting the correct angle/bevel is key.
  14. I checked, I don’t have any scrap steel. Your garage must be a haven for all things modeling 😳😊 As always you set the standard for rigging. Anyone needing any help with any model should consult your Speedy and Duchess builds for techniques, methods, and how to achieve them.
  15. Just being silly; using the blade in the photo to fake the joint closest to the bow. Really not a secret.
  16. Thanks Bob, I have to admit I do like those top (or bottom up) views, the lines are very nice. Thank you Derek. It's not without its flaws, it did turn out pretty well though - lot of time invested in many many strips of ¼" wood strips. Thank you. Chapter 3 will certainly be different, I'm looking forward to starting it after another coat or two of WOP. Plus I'm in the process of converting the build board. Looking forward to the next steps.
  17. Thank you Chuck, I appreciate your saying so. AYC is such beautiful wood. I'm really not sure how I planked seven models in some other way, for sure whatever that way was I'm never going back to it. On the other hand it will be nice doing something besides planking finally - at least until I get to the deck...
  18. Thanks BE - I always enjoy the details of your models. Thank you, it's a great model to work with I have one of those too - I'm just passing by the greats. Thanks Dave, I appreciate the comment, not sure I am but appreciate it nonetheless. Thanks - I'm definitely looking forward to anything that isn't planking. Thank you Bob - I appreciate your saying so. It definitely is worth the effort in the end to see how it all comes out. Thank you Don, I appreciate the comment. Fun stuff this. Not sure it's that, but thanks for saying so.
  19. And, can probably Google it all. I can’t imagine buying 800 books at any price, what would I do with them. Good luck not being willing to break up the collection. The best option is donating to a library, but finding one that would take that many books would be a chore.
