Everything posted by glbarlow
Thanks BE - I always enjoy the details of your models. Thank you, it's a great model to work with I have one of those too - I'm just passing by the greats. Thanks Dave, I appreciate the comment, not sure I am but appreciate it nonetheless. Thanks - I'm definitely looking forward to anything that isn't planking. Thank you Bob - I appreciate your saying so. It definitely is worth the effort in the end to see how it all comes out. Thank you Don, I appreciate the comment. Fun stuff this. Not sure it's that, but thanks for saying so.
- 840 replies
- winchelsea
- Syren Ship Model Company
Nice rigging work Rusty - I should get back and finish Flirt but I can't tear myself away from Winchelsea. Looks really nice!
- 201 replies
- Duchess of Kingston
- Vanguard Models
Hull Planking Complete! It’s a big day, after more than four months of doing nothing but planking the enormous Winchelsea I’ve completed planking her hull, yay! A little story on how I got there: It begins with my once again championing Chuck’s planking technique. No way I’d gotten anywhere as good a result without heat bending planks. The one shown here is next up on the bow and, like its cousins, will fit perfectly without forcing flowing with the curves. It does take time and patience, there are planks that took me 10 minutes to shape (midships), others that took two hours, and more than a few that took almost an entire day. Many took multiple attempts to finally get one to fit right, more than a few were cracked in half and flung across the room - patience yes, but come-on man, fit already. RIP. I’m sad to say, after hours and hours of use on Cheerful, Flirt, and 96% of Winchelsea my travel iron gave up and died. No matter, off to Target and $12.95 later it’s identical replacement is now in service of my shipyard. Maybe I shouldn’t leave it plugged in all day. I spent over a week fairing the frames months ago, that doesn’t mean I did it completely right. With my limited abilities I sometimes needed the plank dry-fitted in place to see how it flowed. I am not reluctant to use a shim on occasion (never more than 1/64th needed fortunately) to make an adjustment where needed. In this case the rabbet slot wasn’t as deep as I’d like, a Swan Morton mini-chisel with two very sharp blade sizes (thanks @Blue Ensign) was perfect for making it a tad deeper. In the vein of not always doing it right, the tick strips Chuck provides were a gift, saving hours of work lining the hull. However, as faithful as I tried to be I wasn’t always near faithful enough. Occasionally I got out my planking fan (also provided by Chuck, but with the Cheerful monograph) to check and often re-mark. Were I really good at cutting and adding planks maybe I wouldn’t have needed it, but this extra step payed dividends. I followed a butt shift pattern that I extrapolated from the plans (which show only above the wales) then marked it out on the frames with my red pencil. Not being a total masochist I didn’t actually cut the planks at the first line of joints nearest the bow and last line nearest the stern, it was much easier and crisper to run those planks to the next joint, fitting the resulting longer plank. I then used this flat sharp blade to notch the joint into plank at the proper location before laying the next plank. So that secret’s out. You can see in the upper right corner I’ve hand drilled one of three #4 machine screw size holes in the keel. I don’t know yet what the final display board will be or if these holes are even needed, but it’s much easier drill them now than with the model finished. So finally I came to the last plank - I had to sit for a while to appreciate how far I and this wonderful, but very large, model had come since I started it last November. With my zen moment over - it then it took me several hours to get it to fit, as for the last time broken rejects were flung across the room, and all was peaceful at last. It may be hard to believe, or wonder why, but everyone of these sanding tools were used during the course of the planking. A bit extreme I’m sure but these Soft Sanders are perfect for the job. Last two times I ordered adhesive sandpaper the manufacturer included a number of half width sanders, so naturally I had to put sandpaper on them. I used 150, 180, 220, 320, 400, 600. and 800 grit at various times, again an excessive range I’m sure. I even used 1200 on the wales after they were painted to remove a few scratches without removing the paint. In addition to the soft sanders I frequently used my little wood blocks with the same adhesive sandpaper attached (every plank was beveled using those). The flexible sticks of 400, 600, and 800 grit shown in the photo are new additions from Amazon that were also helpful. I realize that last paragraph was way more information than anyone cares about, but I feel an obligation to thank not only the plank bending process, but the tools that helped me get to this point. Speaking of people to thank I absolutely have to thank Jim Byrnes for his amazing machines. The angle of every plank at the bow and every plank joint was shaped or squared by the Byrnes Sander. Every plank used was first run through the Thickness Sander (shown with my vacuum attachment still on top. It flings a lot of dust, I’d rather than was into my shop vac and not the air. It also fits the saw and the sander. (Also note the tape on the bottom with Up and Down direction marked for those of us easily confused, though maybe it should say More and Less). Every plank was milled on the Byrnes Saw, the most essential, and likely the best tool in my shop. I shared the story in the tool forum of the saw starting to make an atypical noise. I called Jim, after troubleshooting with me he sent a replacement part and guided me on installing it. It then worked fine, but was the blade was rubbing the blade cover, so he cut a replacement with the slot moved over a milimeter or two and sent me that. There is no better example of superb workmanship coupled with incredible customer care than Byrnes Model Machines. Next up was the stern post. More complicated than you’d think but for good reason, it took several hours to fit. The laser cut post is cut large on purpose, because every hull ends up slightly different. The challenge is to both cut it to the proper length and shape the curve to fit at the counter, and of course to have a flat, squared, and leveled surface there where I’d terminated all those planks. I used practice pieces to sort out both the length and the curve. I could shorten the post, but of course I couldn’t un-shorten it, so several scraps were used to get it close with final sanding from there. It was then marked, centered, clamped (including my handy large rubber bands doubled for the length required) and attached with Titebond III. And it was done. While I didn't need wood filler in the planking itself I did use it along the seam of the stem, sternpost, and keel. I like the look. That look was made better by the use of the Winsor and Newton Pro Markers markers Chuck mentioned in his log. In my case Almond was the preferred color to add over the wood filler, I think it blended well. In these photos and the ones above the WOP is freshly applied, hence the sheen bounced by the work lights. It drys to a nice satin finish, that in turn will age and even out nicely with time. So, Chapter 2 is complete. I have my finished hull, after another coat or two of WOP on the port side I’ll finally turn her over right side up and begin the next phase. I’d like to say I’ve enjoyed planking (well, I kinda have) and wish there were more to do (I definitely don’t). Chapter 3 is about as different as it can be from Chapter 2, I’m looking forward to it as the next challenge. Thank you all for your support with your likes and comments - its nice to hear from you and is very appreciated.
- 840 replies
- winchelsea
Well done, the extra touches are nice. Sorry about the shipping, I’m sure that’s frustrating.
- 137 replies
- winchelsea
With the masts and rigging the boats are a nice touch, without those the boats, cradles, and perhaps even the skid beams overweight the top and distract from the rest of the model….in my humble opinion.
- 857 replies
- Sphinx
- Vanguard Models
In any case I think it has to come out, maybe including deck beams. I’m sure you can get replacement parts. I’d change brands of glue, if no markers that’s the only explanation sort of a roof leak. Better to demo and replace rather than attempt salvage from the looks of it. Hard to tell from photos but seems like some of the Qdeck beams aren’t set right also. I tear off stuff and replace all the time. It’s so fun😊
- 505 replies
- vanguard models
- Sphinx
The bow fillers are useful and worth the time. I’m almost done planking and don’t regret adding them, though I took the simpler approach of using balsa. I also duplicated the curved fames above the deck and the bow and added a second set. I noted later Chuck adds filler for the anchor rope hole, adding them now gave me planking support above deck level. As was mentioned the transom frames provide the needed curve by their alignment in the bulkhead slots. I too spent a lot of time working to get them right. Like the fairing every thing done right at this phase pays dividends. Don’t forget the have fun part😊
Fairing is extremely important for this single planked model, you’ve made it much more challenging with the ply with the number of bulkheads and size. It took me over a week to fair mine using Chuck’s starter pack. I like your build more but you’ll also need a firm support for it upside down. Mine hasn’t been right side up since March. I doubt you’ll be the last and there are a number of us not that far ahead. Welcome to the project, always glad to see a new builder as part of the group. We all help each other, don’t be reluctant to ask.
You’ve definitely made it your own, it looks great. I’d never seen snaking, a nice touch.
- 542 replies
- Sphinx
- Vanguard Models
(and 3 more)
Congratulations on your first model. It looks great, you’ve done a nice job. I’m sure you’ve learned a lot along the way you’ll apply to future models. I’m not a fan of display cases myself. They take up too much space and gather more dust than the model. I just dust them all off every six months one so.
- 362 replies
- Amati
- Lady Nelson
I am one of those advocates of using CA for aspects of building, like planking. However, I don’t use it for rigging for the reason Allan describes. Diluted white PVA, matte varnish, or clear acrylic paint are much better solutions. Learning to tie a figure 8 seizing will serve you well, it can be used extensively in the rigging stage. A Quad Hands (Amazon) is essential to be able to seize lines easily and effectively.
Your Duchess is featured on MSW’s Facebook post today, congratulations 🎊
- 345 replies
- Duchess Of Kingston
- Vanguard Models
Mine shows them level along with a test fit of the windows 😊
- 389 replies
- winchelsea
The sills are level with the deck (so build board) as window sills would be from inside the captain’s cabin. You’ll see it in most every build log I’d imagine.
- 389 replies
- winchelsea
Thank you for the kind words. Yes the copper plating drove a long hiatus, but as you noticed I’ve been back at it for a while now. However, I will never ever copper plate anything ever again😎
- 101 replies
- victory models
- amati
I’m looking forward to that day, I think they will too. If I get to that day😁
- 840 replies
- winchelsea
Thanks Rusty, but I’m pretty sure I’m second to a lot of our planking crowd 😊
- 840 replies
- winchelsea
