Adrieke
Everything posted by Adrieke
  1. hello pete sorry I haven't been on the forum for a very long time I am still at the start of the build , so I probably wouldn't been able to help you hope you r build is going well
  2. pfffffffffff well I caught up with your build log now and you seem to be going great (as I knew it would) soon you l be on the sanding and filling stage like me , lots of joy (but I am needing a shoulder replacement )
  3. thanks all for the comments Popeye she has been neglected for awhile but she is having my full atention again Sjors when you look closer you ll see that it is not so smooth i have done some rough sanding and filling (one side only) and am hoping tonight do sand it all smooth again i have no illusion that i am going to get it completly smooth but i am goign to try
  4. hey Don i see you made some good progress looking great
  5. thank you all for the comments after a second session of filling and sanding this is how she looked : then I spray painted a few layers : this is now showing up a fair bit of errors so after the paint is completely dry I will start on fixing those up I see a fair bit of work ahead of me before I am done with the hull
  6. thank you for the comments sorry I haven't been posting for awhile but I have taking a bit of a break from the online world I have been slowly but steadily working on this build though second planking is finished I have applied a first layer of filler, mainly to seal most of the gaps between the planks and have sanded most of it smooth after that I have added the last keel part and used some more filler to seal the gaps between that part and the hull I will now finish the sanding and then check for bumps and such and apply more filler this will then finally allow me to start the painting of the hull
  7. its been awhile but I am finally have got an update second planking is almost done , just a few more planks near the keel during the sanding of the first layer I didn't notice that I sanded down the keel to a point at the front and back I decided to cut off these parts and replace with 2 new bits here they are glued on and some filler applied to cover up the gaps : I have also soaked the stern part and bended into the right shape using the form the keel came from I intend to start the tedious work of sanding and filling the second layer next weekend
  8. most of my two weeks holliday i have spend trying to get over my jetlag. going back and forth (from Australia to Belgiium) twice had seriously messed up my sleeping and bothing seemed real anymore i did manage to slowly work on the second planking. i am now pretty close to finishing but havent made to good a job of it so i ll need to do a lot of filing and sanding to get the smooth surface i was hoping for i had also opened up the hull earlier to take out some filling from the first layer that had seeped through and was ratling inside hopefuly another week or two and i can finaly start on painting the hull
  9. wow Augie you have progressed a lot since I last looked in very very nice planking
  10. as soon as I am over my jetlag I ll be working on her again this last month has been very difficult for me half December I had to go back to Belgium as my father was in hospital in the 2 weeks I had to move his belongings from the flat he lived in to a room in a nursing home as he would not be able to look after himself any more when I left him to go back home (on new years eve) he was getting a bit better and was supposed to be able to get out of hospital soon not even a week after I was back in Oz I got the message that he had taken a turn for the worse before I could fly back he had already passed away on January 7 although it was a sad time I have also renewed ties with family in my home country and will be able to stay in contact with them I now have 2 more weeks of holidays in which I hope to recover and my building time will help with this please don't leave any comments on here about this as I will remove it later on. I just want to let my friends on here know and understand why I ll be a bit quiet for awhile thank you
  11. Thanks Mick , I am about 1/3 of the way through the second planking, then I t ll take some time filling and sanding to get a nice smooth surface for painting
  12. thank you Sjors and Craig I am ok but struggling with jetlag at the moment after a very difficult month for me. I ll explain in my Gorch Fock build log I l lbe following your build Craig and you can im me anytime you need some advice
  13. hello Jason sorry but I have been away I hope you found the list with parts in the book with pictures
  14. thanks dragzz thanks Robbyn, unfortunately I wont be able to keep my time line either progress so far . the planks have been lightly sanded
  15. as usual absolutely magnificant . dont you dare to ever stop your work
  16. thanks S.Coleman, yes the masking tape is workign well, just need to be carefull when removing it as the edges of this wood are bad and littl ebits tend to break off. thanks Mick thanks Sjors, yes its 0.6 mm , not sure what kind it is but its different from the ones from AL. as i mentioned this wood is easy to sand really smooth. i ll be using the 180 sandpaper to smooth out any bumps /edges and then sand it with the 320 i have lying around
  17. thanks Augie and bug second layer is progressing well I have used some P180 sandpaper on the first few planks and I am amazed how smooth it feels quickly and so far I can see that only a minimal amount of filler will be needed to have a good surface for painting tomorrow is the first work day this year an dhow I am looking forward to it .... not the next 2 weeks I will slowly work on the planking . then I will have 2 weeks of real holidays in which I am hoping I will have plenty of time to start on painting the hull which I think after the planking will be the most difficult to get right
  18. thanks Sjors update follows as requested thank you Don thanks Bug . you don't have to wait long its already underway thanks dragzz after lots of sanding on the first layer to get most of the unevenness out I added some filler after a bit more sanding I felt I had a smooth enough base for the second layer I also made sure the bow and stern edge was the required width of 4 mm , this to ensure that the back and front bit of the keel will fit nicely I have started the second layer and added the first few planks I decided to use some cheap masking tape (useless for fine paint jobs) to hold the planks in place till they dry as I did not want to experiment with CA so far this is going well
  19. Don Edit your first post then click on full editor and you will be able to change the title and looking good on the second planking I am at the moment sanding the first layer a bit smoother before applying some filler and then finish off the sanding
