Everything posted by No Idea
tilt arbor table saw
No Idea replied to Anthony Hearne's topic in Modeling tools and Workshop Equipment
Hi Anthony - there is a fence fitted to the tilting table which I always use. Small stock I have found does not have to touch the bed as the tilting table is now the new bed. It’s hard to explain but once you’ve had a good play it all comes together. I’m sorry that I cannot be more descriptive -
I’ve got the tilting table and I find it easy to use. The reason is I actually use it and like any tool the more you use it the easier it becomes. It was a bit awkward at first but so was my first block plane. Once mastered it’s a great bit of kit and I do not regret my purchase at all. I’m just waiting on Jim to contact me so that I can upgrade the table to the larger size. -
Cheers Bruce - This is what I use here's a pack of 3 for £7.99 https://www.amazon.co.uk/Sakura-Pigma-Graphic-Pigment-Calligraphy/dp/B01M24ONH8/ref=sr_1_16?dchild=1&keywords=3mm+chisel+tip+archival+ink+pen&qid=1606586152&sr=8-16 Have a play first but I have found that my best results are by using it on both planks that meet. Good luck!
In my experience the best cut off switch is my wife - when she comes into my workshop and tells me enough is enough and dinners ready Always works for me!
Hi All Not my sale but I found this today if it helps any builders on here. I use mine quite a lot its a great little tool. https://www.ebay.co.uk/itm/Aeropiccola-Electric-Plank-Bender/324371420787?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D225076%26meid%3D9afe999851414b62ae580618277f14b5%26pid%3D100675%26rk%3D2%26rkt%3D15%26mehot%3Dnone%26sd%3D293634870779%26itm%3D324371420787%26pmt%3D0%26noa%3D1%26pg%3D2380057&_trksid=p2380057.c100675.m4236&_trkparms=pageci%3A4cfe2134-2689-11eb-8ac4-7aadce336392|parentrq%3Ac74023d21750a4d361e9136bfffa690c|iid%3A1 Mark
Glue for Templates UK
No Idea replied to No Idea's topic in Building, Framing, Planking and plating a ships hull and deck
Thats great thanks very much for your help - I'm off to buy a glue stick and get going on this build -
Hi Per thanks for the reply - do you use something like this Pritt stick? https://www.amazon.co.uk/Pritt-Original-Childproof-washable-cardboard/dp/B004QFI99Y -
Hi All Could someone please recommend a good glue that I can purchase in the UK for fixing my paper templates to the wood for cutting out and shaping? I would imagine that the templates will be in place for quite a while but I don't want to do damage to the wood underneath when I remove them. Thanks for you help Mark
Hi George - The build looks great. For stantions I used billings own 3 hole brass ones that can be purchased from Cornwall Model Boats if that helps. Here's a link to nearly 700 photo's of my build just in case it helps you. https://modelboatmayhemimages.co.uk/album/bXv Mark
- 90 replies
- fairmount alpine
- billing boats
WOW ......................WOW............Your work is just beautiful. I just find this build so inspiring - fantastic work.
- 589 replies
- le gros ventre
- cargo
I helped a friend who was struggling using silver solder. His problem turned out to be he was cleaning the joints using sand paper which was contaminating the joint. A quick swap to wire wool and the problem was solved.
Hi Bob I have to say that I've used the miniature block plane to finish off just about all of the planks on my current build. I use this and a Lie Nielson violin makers plane and although the latter can remove more in one pass I would say that they are equal in capability on my builds. It's a great little plane that genuinely does the job in both removing excess material and cutting bevels. I have sharpened it twice in 3 years and it hasn't let me down or shown any signs of wear either Mark
Hi James if you don't use these suppliers give them a try. I've just had 8 planks for Castello delivered for a very reasonable price - and they cut them to the thickness that I wanted rather than what was advertised on their website. They also ran them all through a jointer for me so that I have good edges for my table saw at no extra cost. I agree that actually the ebony you get is a good price - but it would take me two lifetimes to use that much of it so that makes it prohibitive for me.
My wood suppler sells ebony https://shop.exotichardwoods.co.uk/african-black-ebony-sawn-board-no-5.html £200 for one small plank of it. The dust from ebony is also quite toxic too. If I was in a club where 3 or 4 of us needed some it would be worth it but not for me at this price. I'll leave it to the guitar builders as lovely as it is. I too would either dye or paint the wood.
Just beautiful work I am truly amazed. It looks like you have two mills now too or have you upgraded your proxxon mill? I like mine but find the indexing is not that accurate.
- 589 replies
- le gros ventre
- cargo
I buy all of my blades from Model Machines I just tend to order quite a few at a time because its expensive to import into the UK. My view is if I buy from the original supplier it keeps them in business. I have too many friends who buy cheaper from China and then wonder why their favourite model supplier has gone out of business. I had a load of blades from Jim about 6 months ago and they will keep me going for the next year
I currently use a Paashe Talon 3.......the best airbrush I've ever owned. It's a double action with an internal mix. But the best bit is.....its easy to use, comes with 3 different size needles including a fan cap for big jobs but its also so easy to clean. Great bit of kit for the money.
- 40 replies
- best airbrush
- compressor
Kurt this is spot on - I should have said this in my post. If you tip the saw so that the fence is parallel with the floor it makes the job so much easier. When I first used my tilting table I did struggle a bit as it does take some getting used too. But when you get it sussed what a great addition to the saw. My advise to anyone using this attachment is to have a good play with it until you are happy with your use of it. Once sorted you won't look back as any angle is achievable with a clean cut that can be repeated as many times as you like.
1930 BENTLEY 4.5 LITRE by MadDogMcQ - AIRFIX 1:12th Scale
No Idea replied to MadDogMcQ's topic in Non-ship/categorised builds
Awesome!!! I remember building this kit when I was 10 years old in 1977!!!! I think your skills are top notch! -
Mill Speed to Avoid Chipping
No Idea replied to ChrisLBren's topic in Modeling tools and Workshop Equipment
Hi Pete you are right - but the main reason that I use sacrificial backing though is to stop the cutter making contact with the machine slide bed -
Removing Laser Burn?
No Idea replied to Shaft's topic in Building, Framing, Planking and plating a ships hull and deck
If the part is a tricky shape a red scotch bright pad works well to remove the char
