About druxey
Gender
Niagara on the Lake, Ontario, Canada
Interests
Theatre, music, history, cycling, model making.
Gregory reacted to a post in a topic:
Deck planking
cotrecerf reacted to a post in a topic:
Deck planking
HMS Bellerophon 1786 by AON – scale 1:64 – 74-gun 3rd Rate Man of War - Arrogant-Class
Le Gros Ventre 1767 by woodrat - Scale 1:48 - POF - French exploration vessel
dafi reacted to a post in a topic:
Deck planking
wefalck reacted to a post in a topic:
Order of Mast Assembly
Deck planking
druxey replied to Charlie pal's topic in Building, Framing, Planking and plating a ships hull and deck
One general rule of thumb: Straight regular width lines of planking only came in once powered sawmills were in use. -
Deck planking
serikoff reacted to a post in a topic:
Le Rochefort by Some Idea - 1/24th Scale - First POF Build
dvm27 reacted to a post in a topic:
Bentley Blower by RGL - Airfix - 1/12 - PLASTIC
Bateau de Lanvéoc by JacquesCousteau - Scale 1:32 - From Ancre Plans
Mark Pearse reacted to a post in a topic:
Electroplating Britania metal at home - doable?
paul ron reacted to a post in a topic:
A beautifully rendered end result! The surgery was a bold and successful move. Well done indeed. Flexible room temperature vulcanising (RTV) rubber molds will preserve the smallest detail beautifully. One correspondent asked whether you use mills. The look of a rotary carved surface is never the same as one that is carved using edge tools. The crisp edges are never there. The whole aesthetic is quite different. As for acanthus leaves, if one studies good examples of these, one can then imitate them as well as Aleksandr has.
If you are rigging, the masts will stay put without glue. Hint: they didn't glue the masts in at full size either!
HMCSS Victoria 1855 by BANYAN - 1:72
druxey replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
Glad to see progress and that you are back at it, Pat. The model looks terrific.- 1,021 replies
- gun dispatch vessel
- victoria
If one absolutely has to use nails - which I do not for one moment recommend! - then one needs to predrill a hole just under the diameter of the nail one is using.
Very nicely done. Just catching up on your build, John. Ailing or failing parents are a huge stress, and I empathise with what you and you wife have been going through. It's tough on everyone.
- 53 replies
- William Atkin
- Sloop
