Everything posted by druxey
The other possibility is to reduce the gas flow on the torch (if you can) so that the flame does not blow away the silver solder paillon.
I guess that the windlass won't wind, alas! It's interesting the things one discovers on the journey of a build. Either "They can't possibly have done that like that," or "Aha! So that what that's for!".
Interesting procedure. Does the set silicon stone have any slight flex or is it perfectly rigid like conventional dental stone?
- 3,560 replies
- clipper
- hull model
Swan-Class Sloop by Stuglo - FINISHED - 1:48
druxey replied to stuglo's topic in - Build logs for subjects built 1751 - 1800
That cross-chock is one of the trickiest bits to do. Looks like you are beating it into submission!- 475 replies
An interesting assortment! Many of the models seem to be sailor-made.
Of course, one could also wrap them to protect them from damage or be a little more careful! Just sayin'....- 475 replies
I'll rise to the bait -again. My limited understanding is that conservators' wax (Renaissance) is pH neutral so should not deteriorate line like beeswax (acidic) will do in time.
Perseverance also helps. On my first framed model, the cant frames were torn out and replaced four times! After that experience, I was successful every first time. It's simply the learning curve - a steep one in this case.- 475 replies
The aesthetic may have changed, but also the height and protrusion of the knee of the head. Presumably the curve of the rails followed....
Nice carved statue, but I doubt whether it was ever a figurehead. It stands nicely on its pedestal.
Here's what I think happened with Victory. Originally the beakhead platform was flush with, and an extension of, the upper deck. The original head rails had a greater curve or 'bag', so the lowest part of the main rail was in line with the upper deck. At some point the headwork was replaced. The new head rails had a flatter curve. To make the gratings of the head flush and level with the rail, a platform was constructed over the fore end of the upper deck. The two plans shown above demonstrate my point.
Interesting catalog, Bruce! Unfortunately Nereus of 1821 is nothing like the model shown. See: https://collections.rmg.co.uk/collections/objects/81806.html The style of the model in the catalog looks later 18th century, not 19th. The 1821 ship had 38 guns and was considerably less sleek! The model appears to look similar to Speedy of 1781, but the tiny ports make me suspect that this was a merchant vessel, not a naval one. See: https://collections.rmg.co.uk/collections/objects/84422.html
I agree that hand-stitched French rasps are amazing. I've had two Auriou rasps for many years. They are expensive but far out-perform any commercial mass-produced tool.
There is a dimensioned drawing on page 3 of the instructions, SkiBee.
- 54 replies
- norwegian sailing pram
- model shipways
Dating 18th-century map from ship drawings
druxey replied to Stephen Gadd's topic in Nautical/Naval History
With all due respect, the image looks more like a typical Revenue cutter of c.1800. However, as there is little hull detail, it's hard to say. I believe that Deal built cutters, heavy and clinker built, were the most common at this time.- 17 replies
- flag
- 18th century
(and 3 more)
Just catching up with your work. Looks like a promising start, Rob.
- 3,560 replies
- clipper
- hull model
How to narrow planks?
druxey replied to Brewerpaul's topic in Building, Framing, Planking and plating a ships hull and deck
As most planks for a particular model are the same thickness, make a jig with two pieces the thickness of the plank apart and add a stop at one end. Slip in the plank , which is then held vertically, and use the small plane or sanding stick.
