Everything posted by druxey
Ed, You must have mixed feelings as you approach the end of your magnum opus. She looks magnificent!
- 3,618 replies
- young america
- clipper
Well done for doing the planking over again! It's a hard decision, but one I'm sure you are glad of now.
- 306 replies
- schooner
- la jacinthe
I know that the strakes of top and butt under the guns was adopted at some point in the 18th century, but exactly when is the question. Plank butts always fall on the beams, not the ledges. (Most ledges are only 3" or 4" wide, so there is insufficient landing to secure the ends on.) Also, avoid butts in the binding strakes opposite hatch openings.
I can see that one drop strake is needed, but it was the second one I was referring to. Sorry if I was not clear! See sketch below. There should be a nice easy run of strakes to the bow.
Cockbilled yards are when the yards are tilted in the vertical rather than horizontal plane. In past times, yards acockbill signified the same thing as a flag at half staff; a sign of mourning.
You might consider ending the garboard just forward of your pencil line so that it does not end at the keel/stem joint. See how many strakes will comfortably fit above that into the stem without needing a drop strake.
I agree that this style of gun was a very early one and abandoned, as Dave mentions, by the early 1600's.
- 9 replies
- swivel guns
- cannon
Nice save on that first piece, Kevin! However, if you had used PVA, rubbing alcohol would have made removal of the part easy. Was there a particular reason you decided to use epoxy?
- 1,126 replies
I'm so sorry to read of the news of your good friend. Some years ago a good friend and work colleague of mine was killed by a drunk driver, so have some idea of what you are going through as you process this senseless loss. My condolences. Please don't feel that you are 'dumping' on us, Eric.
- 599 replies
- sidewheeler
- arabia
(and 4 more)
I reread Arthur Ransome many times over when I was a child. It was a wonderful world to get lost in. "Swallows and Amazons forever!"
If you decide to try brown gummed tape, artists' suppliers stock it. It's usually used for stretching watercolor paper.
Scrape gently and repeatedly. If you apply too much pressure the cutter will chatter. Also, scrape with the grain. On a rounded corner you need to attack the curve from both directions. I hold my scraper at a slight angle rather than at 90 degrees to the workpiece. See if that solves your problem. Of course, different wood species will give different results, depending on grain structure.
- 124 replies
- longboat
- Chaloupe Armee En Guerre
