druxey
Everything posted by druxey
  1. My guess is that the bow mystery structure is a rub strip or bumper. Also, I note that the decks aft align vertically and are not stepped back.
  2. Thanks for your recent responses on the subject, Dashi! It is interesting to note the early example of the Essex of 1741 with a mizen stepped on the lower deck, as well as Sutherland's comments. Thanks for bringing these to my attention.
  3. Looks like you are going for a high production run and into business....
  4. Unfortunately you probably made things worse by the water content of the acrylic paint that you used!
  5. Two layer of SilkSpan mean only one glueing layer, which will be less tricky than bonding three layers of material. If you are using white glue which is water-soluble, you could subsequently dampen the flat double layer and let it dry over the form, perhaps? As for the mainsail exceeding the size of the material, could you stagger the joints along different seam lines?
  6. Very nicely done, Kortes, but which version will you use?
  7. Don't cover up all those wonderful joints! Beautiful work.
  8. Do you actually need to use leather to imitate leather?
  9. He, and many others, have learned the hard way. Those old-time shipwrights knew a thing or two!
  10. You might also want to add a cross-spall on the square frame so that the top doesn't widen. Also (it might be the angle of the photo) is the square frame seated deeply enough? It looks a bit high relative to the cant aft of it.
  11. Jim and Greg: Ships that passed....
  12. Nice looking completed windmill, Marcus. Congratulations! Hope it weathers well. It was instructive to learn about the mechanism used to turn the mill.
  13. Looking very nice, Alan. Perhaps pin/treenail the feet of the cant frames to the deadwood for extra security?
  14. My condolences to you, as well as his family.
  15. The quality of your work look terrific, Antony! Hopefully you are not snowed in.
  16. Excellent sawing to the line. Practice certainly made perfect, Keith!
  17. Sometimes building frames seems like an endless task. But there has to be an end soon now, surely?
  18. Slight digression on the alignment of slot screwheads: When I was young my father, who was a mechanical and electrical engineer, taught me to always align screw heads on wall switch plates vertically. The reason? Vertical slots gather less dust than horizontal ones!
