Posts posted by druxey
If the edge is sharp, a 15 degree angle should be sufficient. As mentioned, many light strokes are far more effective then pressing down. If you do that the tool will either chatter or dig in. Also. be aware of grain direction: sometimes pushing the tool rather than pulling is more effective.
- thibaultron, lmagna, el cid and 2 others
5
Would the original masts and spars have been assembled in serial fashion over a mandrel to back up the rivets?
Leaf, whether gold, silver or copper, is incredibly thin. It will show every tiny flaw underneath the surface it is applied to. It is also very tricky to handle. Read any instructional on gilding (gold leafing) and you will see that it requires a lot of practice and skill to apply successfully.
You could always make your own, you know....
- lmagna, thibaultron, Gregory and 2 others
5
Not ugly, Javier; let us call her 'idiosyncratic'. And it's a very nice model indeed! Well done.
- thibaultron and mtaylor
2
Thank you, Roger. This book fills a void, it seems.
- mtaylor, Roger Pellett and thibaultron
3
A very instructive series on metal rigging work! Thank you for sharing your techniques, Frank.
Rather than packing tape, try 3M Magic tape. It is slightly frosted and takes pencil well. Even better is the 'temporary' version with re-positionable adhesive.
Congratulations on completing a long and painstaking restoration, Michael! You've done a beautiful job on Albertic. I can only hope that your client is truly appreciative of the craftsmanship that has gone into the model.
P.S. In the second photo (starboard companionway grating), is that bilge keel slightly loose?
Congratulations on completing your fine model, Albert! Now what is next, I wonder?
- aviaamator, mtaylor and albert
3
Manual handling is far less risky than a fork lift or other mechanized method!!!! Unless you want to do the restoration all over again....
Heavy duty castors might be a better alternative.
- Jack12477, thibaultron, mtaylor and 2 others
5
Yup, that looks like a serious crate. How far does the model have to move?
- cog, popeye the sailor, mtaylor and 2 others
5
Beautifully done, Patrick. I hope that the shingle pieces are glued in place!
- cog, mtaylor and aviaamator
3
Sail design for 18th-century longboat?
in Masting, rigging and sails
Two more cents' worth: In a contemporary model of a hoy, there is no bobstay. However, a block was hooked in the same position as your longboat sheave for the jib traveller outhaul line. Might I suggest that what you see on the plan of c1800 is similar, but for the jibstay?
