Posts posted by druxey
Not a perfect match? That nav light looks nicer than the original, Michael!
- davyboy, hexnut, popeye the sailor and 2 others
5
Interesting log, so far. Is it possible to find primary sources for information? What source did Chapelle use to draft his version? Again, Bruzelius is a secondary source, unless he is quoting a primary one. I'm not sure either of those sets of mast rakes is correct! One seems too little, the other too extreme.
Or the book gone astray in the mail.
- ccoyle, mtaylor, Ryland Craze and 2 others
5
- paulsutcliffe, mtaylor, keelhauled and 4 others
7
Don't forget the myriad deadeyes, the various hearts, euphroes, and other assorted odds and ends! I always use the 'just in time' approach as I go: it's much less boring than turning out dozens and dozens of blocks all at one time. I use the same approach for spinning up cordage.
Nice to see the boat deck being re-populated, Michael!
- popeye the sailor, thibaultron, cog and 1 other
4
Beautiful! I was anxious seeing the earlier photos, as a horseman leans forward as the horse jumps, and the Vale painting shows him upright. However - whew! - I see you corrected that in the final photos. Bravo!
Well, I guess I learned a thing or two today as well!
Well stayed, Michael! What remains to be done now?
- cog, thibaultron, mtaylor and 2 others
5
Sometimes the stem curve is made of two different radii, which complicates things! If you are lucky, you can see the prick-mark left by the draftsman's compass when he drew the arcs for the stem and rabbet. Take a line vertically up from the point where the straight part of the rabbet begins to curve and look carefully.
The other method is to make an arc of the specified radius (13' 7 1/2" in your example) and put the center at different points along the curve and strike several arcs. The intersection of those arcs will locate the center of the curve.
If the planks are rough-sawn, probably a powered planer is easiest if you have access to one. You really only need to face one side and one edge before re-sawing.
- John Allen, mtaylor and Canute
3
If it's any help, try to control your breathing while painting small detail. That will steady your hands. Nevertheless, your painted decoration looks beautiful.
- prutser, Jack12477, Mirabell61 and 1 other
4
Your work at such small scale is very impressive, Javier!
- thibaultron and mtaylor
2
Albertic by michael mott - FINISHED - Scale 1:100 - RESTORATION - Bassett-Lowke Model
I've used a mechanical pencil for many years for drafting and for marking out. One can keep an extremely fine point on them, and hence a very thin line. This minimizes error, particularly when fitting joints. I generally use 4H leads. The pencils are still available at places like Michael's (U.S. and Canada) and one can still find boxes of harder grade leads on eBay.
