Everything posted by druxey
Beautifully neat work there, Mike.
- 452 replies
- cheerful
- Syren Ship Model Company
Impressive - as usual, Amalio!
I'm relieved that you didn't use a sledgehammer to align those frames, Gerald! It's always a delight to read about your methods and processes and see the results. And yes, I'll be patient until you reach the turnbuckles.
- 281 replies
- falls of clyde
- tanker
Beautifully executed, Michael. Using dial indicators is a spot of genius!
Prob'ly, Mark!
I don't believe that I've ever seen parcelling carried out on a model before. Groundbreaking stuff, Ed!
- 3,618 replies
- young america
- clipper
See my illustration of a fixed block. I only found this out from the extract of the draught shown a couple of years ago. It makes sense for repair when necessary. Fixed block rev.psd
- 889 replies
Good to see the hull growing, Ben, even if it is slowly. Don't forget to add the 'ears' on the fixed block later.
- 889 replies
La Santisima Trinidad 1769 by Liberto - 1805
druxey replied to Liberto's topic in - Build logs for subjects built 1751 - 1800
Delightful metal fabrication! -
ancre Chebece 1750 by Jeronimo - FINISHED
druxey replied to Jeronimo's topic in - Build logs for subjects built 1501 - 1750
Oh my, Karl! Carefully does it on this model. -
Even in extreme close-up your work looks impeccable, Amalio.
Miniature plywood
druxey replied to Kurt Johnson's topic in Building, Framing, Planking and plating a ships hull and deck
I've used Titebond without issues. Remember to to make a balanced 'sandwich' with grain alternating directions at the gluing face. The glue does re-activate with heat, but I'd be concerned about how deep into the layers heat would penetrate. Heat is great for simple veneering, though. (See John's posting, above.) I apply Titebond generously and clamp the assembly well with waxed paper or cling-wrap to contain squeeze-out. -
HMS Naiad 1797 by albert - FINISHED - 1/48
druxey replied to albert's topic in - Build logs for subjects built 1751 - 1800
Looking terrific, Albert.
