druxey
Everything posted by druxey
  1. Well done, Erik! You managed that last strake beautifully. Take a bow.
  2. Thank you for my Saturday smile, Frank. Beautifully done.
  3. You don't necessarily need an insert: simply make a ply over-table clamped or screwed to the existing table and raise the saw blade through it. Voila! Zero-clearance. All you need do is to re-arrange the fence to slide over this, or glue a wood fence on a the required spacing from the blade.
  4. There are many ways of solving the problem, and many have already been given. However, another method is by adhering the veneer (or other thin stock) to a backing piece of sacrificial wood. I use rubber cement and basswood for the purpose. I use a slitting blade on the saw, so no clean-up of the strips is necessary.
  5. Certainly she's already a long way from her 'as received' appearance! This is looking very good, Michael.
  6. Looking good, Frank. And thank you for your disclosure on the slot issue. We won't ever tell!
  7. Just received this news from Model Motorcars as well. This is great to know for many of us! Perhaps this thread should now be re-named "Scale Hardware re-opening"!
  8. Nicely done. Was there a reason not to cast the trunnions integrally with the barrel?
  9. This is only my opinion, but.... I never plank a hull as in full-size practice, where you end up with a 'whiskey strake' in the middle of the bottom planking. Installing this, as you anticipate, is awkward to do. However, you need to do this now. I suggest that the edges of the planks be bevelled in such a way as to (lightly) wedge them home. I would not make them a force fit. Hopefully this will go well for you. Next model, consider starting at the garboard and working up to the wale. As long as you keep to your mark out (which you are now expert at!), it will go much more easily.
  10. Congratulations on yet another fine model, John. The 'pings' of color on the sidelight boxes really set the model off.
  11. Very impressive mass blockmaking work!
  12. Whose rigging illustration is this, or where is it from?
  13. Thanks for the link to your site, Gerald. Perhaps you could expound on scale turnbuckles when you have time - please!
  14. Once the center of gravity is no longer over the base.... However, as the great comedian Spike Milligan once observed, "The ground. Very useful that. Stops one falling..."
  15. Lovely subject, Frank. Looking forward to the episodes as they are posted.
  16. The underside is what we were talking about, Jud. We all agree on that point!
  17. I think that you've nailed it, Michael! Will you seal the underside, though?
  18. I agree that those stanchions are very tricky to make. I found trying to solder two eyes on the two stanchions that required them the worst part of the job. However, you've achieved an excellent end result, Toni.
  19. A fascinating observation and detail! I'm sure I would have missed that, Dick.
  20. A good inexpensive cleaner for airbrushes is isopropanol (rubbing alcohol). I've used Aztek airbrushes. These have small interchangeable screw-on nozzles with integral needles and are easy to change color and to clean. With all due respect to Badger, Iwata and Paache users (and I've had all these makes in the past - they are all good) I still prefer my Aztek. There are no more bent or damaged needles. But, each to their own.
  21. I might suggest leaving at least one 'original' boat's thwarts for posterity? Perhaps there is one boat where the warpage is not objectionably severe? Also, you might want to see if the curvature can be flattened by dampening the underside of the card with a wet brush. If this works, consider sealing the underside so that the card does not change dimension with atmospheric humidity.
