druxey
Everything posted by druxey
  1. The result will depend on your thread size. You will need to make up a trial length of line and measure its diameter. This (at scale size), x 3.1416 will give you the line size.
  2. Now, that is a novel way of drilling out the hawseholes! You mill-men!
  3. A very happy holiday season to you, Kevin. You are nearly there with the framing!
  4. Thanks for all the pleasant moments you've given me this year each time you've posted progress, Ed. The latest on the top is great: I had no idea that there were so many fairleads through one of these. Lovely, simply lovely work.
  5. Lovely work, Roger!
  6. When there are an odd number of shrouds, the first has a cont spllce in it over the mast head so one leg goes to port and the other to the starboard side. The Burton pendants have to go on first (also cont spliced) or how can one haul up that first heavy shroud to the mast head?
  7. Be aware that there are two editions of this book. The second edition is expanded and has even more fascinating stuff in it. Second edition is available at SeaWatchBooks, linked on this site.
  8. You'll find that, after a year or two, the plank seams will 'read' a little through the paint. She's looking lovely.
  9. If the wood is well seasoned, it should not warp. I let my foursquare sticks sit a few days after sawing them, just to be sure. If a blank develops a slight curve, it is taken care of when I mark out the centerline and the tapers before forming the foursquare taper.
  10. First, the lines of the frames are my guide. Also, I use a paper strip as a straightedge to run light pencil lines where needed.
  11. Lovely work, Mark. When bending the beading with heat, did you try dampening the wood first? That might solve the brittleness issue.
  12. Very impressive rigging work at that scale, Dafi!
  13. Mark out first, then prick the spots with a sharp point. That way the drill point won't 'wander' off the marks.
  14. Beautifully done, Ed! The half-laps in particular are excellent.
  15. It takes a while to finesse things so they look good from all angles. It's worth taking the time to do it right.
  16. I think that's the way this was usually done, Maury. Take a look at Ed's Young America. I know it's a different era, but is similar.
  17. Nice find!!!! Well spotted.
  18. I believe that Spencers were usually stepped in a block of wood on deck.
  19. The problem here is that the slope continuously varies - it's not constant like 1:30 or whatever. So one can't really quantify it in degrees. Usually sheer is a line that is a circular arc of large radius; or of two different arcs, one forward and another aft.
  20. 'Turning in' refers to wrapping the shroud around the deadeye and making the throat seizing to hold it in place before adding the middle and end seizings.
  21. You'll latch on to it after a while, then wonder what all the fuss was about! With the bulkheads so far apart, very stiff card will work best for you.
  22. The time and effort you took to make those hooks has paid off well! Very nice and neat, Mike.
  23. I seem to recall a contemporary drawing or print of such an arrangement, but can't recall where I saw it. Presumably the logic is that the foremost port and hawsehole don't cut through this wale. And, as you say, Mr. Watton does his homework.
