Everything posted by druxey
Nice progress, Mike. Michael: the type of hand-vise shown is a jeweler's and watchmaker's vise Check eBay for similar items.
- 968 replies
- hahn
- oliver cromwell
If the crack is open a little, a touch of Bondo will fix it.... Good luck with all those ports and pins!
- 749 replies
- albertic
- ocean liner
I agree that turning in deadeyes and seizing them is a chore, Chuck. Have you tried setting things up temporarily, figuring out where on the shroud the deadeye turns in, mark it, remove the shroud and do the turning in and seizing off-model? I find it makes life much easier doing this on the bench rather than operating 'in air'.
- 1,051 replies
- cheerful
- Syren Ship Model Company
Fascinating information and pictures of the Whitemill! Thanks you, Roger, for bringing this to our attention.
- 525 replies
- anchor hoy
- hoy
Those photos give a good impression of how compact (read cramped) things were aboard a 14-gun sixth rate. Nice progress, Toni!
- 1,449 replies
I was also thinking that the old-time shipwrights didn't have the luxury of CNC controlled (or any other kind of) mills!
- 102 replies
In cases of this nature, when earlier and poorer work becomes apparent, consultation with the owner can clarify one's direction. Some prefer earlier work left 'as is', others want a better rework of the dodgy bits. Either way, photo records are essential along with condition and treatment reports. Is the old damage such that you could make an educated guess as to what might have happened to the model? Remember I mentioned that often stuff turns up that one didn't see earlier? There it is! Seriously, it looks like you are doing a fine job, Michael.
- 749 replies
- albertic
- ocean liner
Just stumbled across your log, Keith. Late to the party, but what a party! Lovely work indeed.
I don't think that dye is an issue if applied off-model. The problem would be even a tiny droplet landing where you don't want it on your model! I dye my wales as the first planks hung on the model, taking extra care with masking at the stem. However, it's all a matter of personal preference.
- 968 replies
- hahn
- oliver cromwell
Yes, I know - it is counter-intuitive. But I found wood dye not particularly good. I see you have competition in the workshop now. That should keep you on your toes, Dad!
- 968 replies
- hahn
- oliver cromwell
How to deal with badly drawn plans?
druxey replied to Redshirt's topic in CAD and 3D Modelling/Drafting Plans with Software
Whether manually drafting or on computer, never completely trust anyone else's draughts! There is always at least some re-fairing required, I've found. That example thlbaultron has posted is not that unusual. A proof diagonal is an excellent way to check fairness. -
I didn't know that holly is very expensive in Europe. That's unfortunate. By the way, I've been using shoe dye (alcohol based) which seems to have good penetration. Wood dye doesn't work so well (for me, at any rate).
- 968 replies
- hahn
- oliver cromwell
I've had generally good luck dyeing holly black. Seems to accept the dye well. Try that and compare the results with the pear.
- 968 replies
- hahn
- oliver cromwell
Good to see you back, Glenn. Hope you are feeling A1 again. Nice to see your update as well. Too bad that lovely decking will all be covered.
Coming along there! Hopefully everything aligns as it should.
- 525 replies
- anchor hoy
- hoy
Terrific result, Montanes. But how did you get the first piece of the plug out of the model?
Just looking in as I do from time to time, Kevin. The modified Proxxon heads will do a very nice job. Hope you get a small royalty on each one sold! You seem to be making good progress on Thorn. Good stuff!
- 1,124 replies
Hopefully equanimity and peace will return to your studio after lunch, Michael. I trust that the cat was not too traumatized. Several light passes with the airbrush rather than a heavy coat will help, methinks!
- 749 replies
- albertic
- ocean liner
The use of shellac to both seal the mast and secure the bands is a stroke of genius, Ed!
- 3,618 replies
- young america
- clipper
