druxey
Everything posted by druxey
  1. Love your attention to detail such as 'improving' the large washer! That is a beautiful as well as practical machine you have there.
  2. Definitely check out a planking tutorial or two. Try David Antscherl's version and see if that computes for you.
  3. To clarify Allan's sketches: the pin of the pintle is set in line with the forward edge of the rudder and the strap inset, so that the fore edge is a straight uninterrupted line. The fore edge is also bevelled off to each side (not shown) so that the rudder can rotate against the stern post. The idea is to eliminate any gap between rudder and post.
  4. Also, the surfaces should be slightly porous. If sealed (with some type of finish, for instance), then adhesion will be an issue.
  5. Ouch! High tech has its limitations. Sorry to read of the malfunction. Hope you are soon back up and running again.
  6. If it's a short length of tube, the wire will capture it and prevent the piece from flying off into the 5th dimension.
  7. Maybe the lift needs adjusting; the end of the boom looks a bit low right now. Very neat rigging work though!
  8. I applaud your optimism, Dave! If I were choosing, Winchelsea would be my hands-down favorite.
  9. I understand what you are saying Sawdust Dave. However, one can hedge one's bets by building a cutter rather than a 74 when one is 74!
  10. Both are of SilkSpan, Allan. The tasselled fringe is of treated canvas. The canopy is not shown on the lines drawing, but I found an oil painted elevation showing this, the color scheme and ensign on the Royal Museums Greenwich web site. (BHC 1117)
  11. Very nicely done indeed! The metalwork of the balustrade is outstanding.
  12. It strikes me that, with all the reconstruction and re-working that you envisage doing, whether it would be easier to start from scratch rather than try to re-shape the basic kit hull. Rather than trying to make the shoe fit by taking a scalpel to the foot, make a new shoe instead! Of course, I understand that it's your project and your decision.
  13. Could one make one die and simply back it up with a piece of lead, rather than having to machine two matching dies perfectly?
  14. Planks were probably in the range of 20' 0" to 28' 0" long.
  15. Coming along nicely, Dave. Neat work.
  16. A fine dust air cleaner on the ceiling is not a bad thing for micro-particular 'bits'.
  17. Fimo can be baked in an oven (low temperature!) to harden it. You can also add to the hardened model or carve it further, as well as paint it.
  18. Chris: Like Jaeger, Pat, Dave, Bill, Roger and Mark said! Jim's sander throws a lot of dust, so a permanent hook-up to a collection system is something you may wish to consider. A shop-vac is pretty noisy, so if it can be placed in an adjacent space for sound attenuation....
  19. From your clear descriptions the sequence is obvious anyway, Gerald. The number of jigs you make and use is quite extraordinary. Brilliant!
