Everything posted by druxey
Patrick: Vaddoc didn't actually say that he wasn't out womanizing and drinking as well. Vaddoc (now that I've sullied your reputation): it's good to see you actually get to cutting wood.
There used to be a program on the BBC many decades ago called "Music While You Work". I guess this is the pre-radio version! I had that cartoon image of a drum being used to coordinate the rowers. Is this completely erroneous? Those are incredibly small figures that you are carving, Steven!
Tools and Supplies for My "Shipyard"
druxey replied to daveward's topic in Modeling tools and Workshop Equipment
The ring style of light has limited usefulness in model making, in my opinion. Many times it is more useful to have directional light that casts a shadow. This is particularly so when carving. I agree with Gaetan's observations about the Optivisor. -
Mechanical Solar System by jim_smits - Eaglemoss
druxey replied to jim_smits's topic in Non-ship/categorised builds
That orrery looks brilliant, Jim. I hope you will add a case to protect the mechanism. -
You don't make things easy for yourself, do you? What reason was there for adding the protective strip after raising the knee of the head? It's so much easier to do this before tapering the knee and attaching it! Well, you'll know for the next model.... At any rate, you are making good progress, Alan.
Best wishes also for getting through the weekend and your dental appointment, Chuck.
- 1,051 replies
- cheerful
- Syren Ship Model Company
Glad you like mica. It takes a little getting used to; peeling it and cutting it without chipping along the edges. Lovely progress again, Glenn. I had another thought about the paddle box covers. The height and diameter of the cover gives the impression of a much larger wheel beneath, therefore implying greater motive power. Think of 'blisters' on hoods of muscle cars!
I'm also waiting to see how the hull turns out when you remove the mold! With this particular hull, do the angles at the upper and lower limits of maximum breadth stay there?
We wait for the wakening in the Fall! Meanwhile, I hope that the model - and you, Gaetan - get a well-earned rest.
- 728 replies
- le fleuron
- 64 gun
ancre La Salamandre by tadheus - 1:24
druxey replied to tadheus's topic in - Build logs for subjects built 1751 - 1800
Lovely progress, Pawel. What a nice selection of small planes you have! -
scarf joints
druxey replied to dennistestagrossa's topic in Building, Framing, Planking and plating a ships hull and deck
Nice and easy - if you happen to have a mill and know how to set it up properly , Mike! -
scarf joints
Accurate mark-out with a very sharp, hard lead point and very well sharpened tools are the keys to a tight-fitting joint. -
The emigrants bunked nearest the loo doors must have had an even rawer deal than the others! I'll never complain if I'm seated close to the lavatories on a plane again....
- 649 replies
- dunbrody
- famine ship
- 452 replies
- cheerful
Good call! Now, about them cats....
- 10 replies
Then I suppose the only solution is to unrig and replace the mast. Unfortunate, but....
- 10 replies
Rough enough, but looks too clean! Nice millwork, Frank.
- 649 replies
- dunbrody
- famine ship
Solution? Replace the cats. Seriously, could you consolidate the problem area by realigning the mast and infiltrating with either CA or epoxy?
- 10 replies
Your comment on the quantity of plank required must be a reflection on the availability of lumber and the lumber industry in those days. Lovely progress, Glenn.
Thanks for the response: I realized that the lower xylocastra would be open: it was the upper parts that were higher and would be affected by wind. Now, if the protective coverings were leather and only rigged over lattice when going into battle, that would make good sense to me.
Exceptional!
