druxey
Everything posted by druxey
  1. Nice lapstrake model you have there, Vaddoc! What is she?
  2. Nice to see you back and progressing, E&T. Try laminating the wales in two or three layers. Don't attempt to bend them in one! You will certainly need to spile the lower hull planking, especially at the bow. Looking very nice so far.
  3. Duff's advice is as good as any.
  4. Oh. I'm sorry to read of the reason for your hiatus. Wishing you restored and continuing good health, John.
  5. Is it possible that what you are seeing in the photograph is thin wood sheathing painted over?
  6. If you use Ed Tosti's coloring method (liver of sulphur), it doesn't affect wood, but the regular chemical colorants will stain. So, like so many things, it all depends!
  7. Please, please do NOT use Gorilla glue!!! It's horrible stuff and expands like foam, so you will get seep-out no matter how careful you are. Use a little epoxy and clean off any smear with isopropanol before it sets. You'll be much happier. Also, should you plan on coloring the metal chemically, do this before you add it to the model.
  8. Would alignment pins before/during assembly have prevented that problem? Looks good now!
  9. What wood and what finish have you used?
  10. Mark has described the style well. Hahn also used ebony (yech!) for his false keel and wales. This is not the best specie of wood for the job for a variety of reasons (discussed elsewhere), but avoids painting or staining.
  11. Would running the scanner along some sort of track/gantry near the object being scanned and parallel to its long axis improve tracking?
  12. Presumably the plug is in pieces and once a central 'keystone' is extracted the other parts will come out easily - provided nothing has been glued to them!
  13. You've made a lot of progress in a few weeks, Albert. Looking fabulous.
  14. Every scratch-built framed model is frightening when you look at the huge overall project. Just focus on one piece at a time in bite-sizes and, after a while, you will have eaten the whole elephant.
  15. Dan: every best wish with your health issues and for 'normality' again.
  16. That hull form should not be too hard to plank, when you get to the real thing. Nice start, Sal!
  17. Dental tools are also useful. A small elevator (looks like a tiny chisel with a bent end) is useful for scraping corners clean of any glue build-up.
  18. Treenail end grain would absorb moisture and promote rot.
  19. Certainly there are plans of deck planking in such volumes as the plates in Steel's Naval Architecture. One can see that the outboard strakes are laid either top and butt or anchor stock where the gun carriages run across. Inboard are strakes that are laid either with three or four planks between butts on the same beam. Strakes are also tapered and curve, rather than the modern parallel and joggled style. A few strakes are laid short with a hook instead. If you are interested, a less expensive volume is the facsimile Rees' Naval Architecture, published in the 1970's. The plates are copied directly from Steel, but at 1:96 scale instead of 1:48. Copies of this useful reference can be found on such sites as abeboooks.com
  20. Thanks for your thoughts on this discovery, E&T. I'm looking forward to more pictures and information on the find. The fact that the hatches were battened down and the ship relatively intact is interesting. Does this imply that the ship was abandoned in an orderly manner? Were there plans to return to her? So many unanswered questions - for the moment.
