Everything posted by druxey
Steamboats and other rivercraft - general discussion
druxey replied to Cathead's topic in Nautical/Naval History
Unfortunately the images, as interesting as they are, do not solve the issue.- 281 replies
- Steamboats
- riverboats
(and 3 more)
My (limited) understanding is that, as the paddlewheel turns, it creates some pressure in the paddlebox. The large space provided inside the box would ameliorate this effect, as did the later fancy perforated boxes seen on side paddle steamers. Can someone confirm or correct me?
Post script: The book on this model and making other open boats, both clinker and carvel, is now on the press! Look for an announcement from SeaWatchBooks soon. Thank you again everyone, for your encouragement and support on this log.
- 641 replies
- greenwich hospital
- barge
If you continue to be as meticulous in your cross-measurements as you have been, all should work out well, Maurys. I find re-measurung and checking constantly the only way to avoid reaching for the isopropanol!
- 525 replies
- anchor hoy
- hoy
Exquisite work, Gerald. Is the multi-arm soldering station your own creation or a commercially available unit?
- 281 replies
- falls of clyde
- tanker
Drilling with a pin chuck is very time consuming - been there, done that! I hope you can mini-mechanize the process. Look forward to seeing your home-made drill for small spaces.
- 969 replies
- hahn
- oliver cromwell
Lovely detail work on the door/hatch there.
- 184 replies
- ruby & arthur reed
- lifeboat
I've just discovered your log: what fascinating 'inside-out' way to construct a model! I've never seen this done before and it looks like an excellent method. However, it would require a lot of very careful planning and extremely accurate craftsmanship. Obviously you possess both skills, Amalio.
If you have more time on your hands, Chuck, why not put in the rest of the 'nails'? Seriously, that looks very nice indeed.
- 269 replies
- Queen Anne Barge
- Syren Ship Model Company
The swivel mounts (generally) were vertical, or nearly so. The portion of hull forward above the knuckle should be vertical, so that the mount ought to automatically be positioned this way. Hope this helps.
- 1,449 replies
Those bluff bows make life interesting, don't they? Looks like you've mastered it, Maurys.
- 525 replies
- anchor hoy
- hoy
Echo by davec - FINISHED - cross-section
druxey replied to davec's topic in - Build logs for subjects built 1751 - 1800
Slow and steady wins, you know! Looking good, Dave.- 127 replies
Lovely, Toni. However, has that top piece of moulding been knocked out of line? Should be an easy fix.
- 1,449 replies
34ft Danish Cutter by adamdt
druxey replied to adamdt's topic in - Build logs for subjects built 1901 - Present Day
Welcome back, Adam! I've just come across your log. Those are pretty impressive freehand curves but, as someone else mentioned, a flexible curve may ease your job. -
Thanks for your thoughtful rebuttal of my argument, Mark. I agree that the shell carving over the quarter badge is less than sophisticated, but I was looking at the framework of the lights. Also, I absolutely agree that some of the deck furniture looked paint-chipped and knocked about: I mentioned the examples of windlass and capstan, but the quarter deck breastwork also falls into that category. My 'take' is that more than one hand worked on the model and one was far more skilled than the other(s). Still, unless another example of ship with chequerboard deck coverings turns up, I remain a little sceptical! Regardless, this is - to me - a fascinating thread.
The latest post by Doreltomin made me go back and look at the photographs again. On more careful inspection there are too many anomalies that are making me suspicious. I've no doubt that the hull is genuine and old. Look at the condition of the paintwork and surfaces. Now look at the various rails along the topsides. Nice, unchipped and with unmarked paint. Check the quality of the quarter badge. Now compare the quality of work with that of the stern ornamentation. No comparison. Also, doesn't that chequerboard look just a little too neat and clean? Now, convince me that all that weather deck work is the same vintage as the hull. (OK, some of the deck fittings such as the capstan and windlass look 'right', but....)
Looks good, Mark. What do you mean by 'the stern looks different on the drawing than it does looking into the hull'?
Thanks for the explanation, Chuck.
- 269 replies
- Queen Anne Barge
If SilkSpan is unavailable, try Esaki Plyspan, also from SIG. Correctly handled, I've found it to be highly satisfactory for both sails and flags - see my scratch build log of the Greenwich Hospital barge. I've tried to use drafting linen but, unless you are working at very large scales, it is too bulky and doesn't drape nicely.
Silly question: could those height marks be laser engraved into the sides of the frames? Also, those for the risings?
- 269 replies
- Queen Anne Barge
