Everything posted by druxey
Pin racks gained popularity as the bulwarks became closed in. While there were open rails, it was easy to belay lines to them. Once this option was no longer available - presto! Pin racks proliferated.
HMS Tremendous 1784
druxey replied to Alexandr's topic in Building, Framing, Planking and plating a ships hull and deck
The figure is of a classical Graeco-Roman hero-warrior, as seen through 18th century eyes. You would have seen singers dressed like this in Handel operas. -
If the outside is painted or sealed, so should the inner side of the hull. That said, I once used acrylic paint instead of my usual solvent-based oil paint. I had some left-overs and thought this a great way to use up the can. Big mistake! The moisture content warped the planks and sprang several. It was hell's teeth to restore several weeks' worth of work. I had to actually replace a couple of planks as well. Lesson learned: economy is not always the best policy.
Sorry to read of the derailment being so close to you; but at least you did not have to be evacuated. The new block looks great.
- 2,215 replies
One down, and many to go.... That first frame looks very nice indeed, Ed.
- 3,618 replies
- young america
- clipper
ebonizing boxwood
druxey replied to Kurt Johnson's topic in Painting, finishing and weathering products and techniques
I would definitely cut in a demarkation line as insurance against bleeding. Masking tape alone will not prevent dye 'creep'. To do an experimental run off-model is a very good move! -
Spyglass: I think you may be mislead by the fact that some builders paint the black (first) strake above the wale, so that the upper cheek appears to land on the wale: it actually sits on the black strake.
I believe from my study of the subject that this is correct for 18th century British construction. The width of the margin on the wing transom varies depending on the size of ship, of course. It is as much as 6" for 110 gun ships and down to 3" on small ships. For frigates it could be, as Allan shows, 4 1/2" or 5".
ebonizing boxwood
I do all the shaping and bending before using shoe dye. -
Dorade Omega1234 - FINISHED - yawl
druxey replied to Omega1234's topic in - Build logs for subjects built 1901 - Present Day
Yup, that is small all right. Nice detail for the size, Omega. What is the scale, please? -
Interesting strategy for the channels, E&T. Have a fun weekend!
- 346 replies
- terror
- polar exploration
If you are referring to 18th century British ships, it's not quite as simple as that. The lower aft edge of the wing transom has a changing bevel for the bottom planking to land on. The upper 3" or so is left vertical and the junction with the bevel is called the margin line. The tuck rail is attached to the wing transom along the margin line as well as overlapping the bottom plank ends by a few inches. This rail is very tricky to make, as the rabbet on its fore face changes angle continuously along its length. The photos should explain this better than words.
Well done indeed, John. It's been an interesting journey we've watched you on (with one or two unintended side-trips!), but the result is terrific. Congratulations!
Interesting solution, Dan. I suspect that, as the quarter deck does not carry much weight, the hanging knee would have been simply omitted entirely. Only the lodging knee would be installed.
ancre Le Fleuron by cabrapente - FINISHED
druxey replied to cabrapente's topic in - Build logs for subjects built 1501 - 1750
I think this does not translate as 'lifeline' but 'preventer stay'. This is the back-up, should the main stay be shot away.- 332 replies
- le fleuron
- 64 gun
