druxey
Everything posted by druxey
  1. For a complete beginner, I'd recommend the dory first. It introduces basic concepts that are needed to successfully go on to the Norwegian pram and lobster smack.
  2. Can you also give us some idea of your experience in any kind of model work. That would also help us suggest an appropriate project.
  3. I echo James' comments. Lovely job on the wheels.
  4. But you know that the wheel and tiller work! At 1/64 that is quite an achievement. Well done, Steve.
  5. The first version posted, #1, was a little misleading as it is obviously a modern near-copy (although a nice one) of the original Pocock, post #11. The lower peak of the sail in the original proves that it is, indeed, the staysail. This is a good demonstration of how secondary sources can mislead!
  6. That is an impressive model for someone to complete, Rick. I hope it goes to a good home/workshop. My own plate is more than full, I'm glad to say!
  7. Certainly looks like a headsail, Martes. The ship is being warped along and, to take advantage of the very slight breeze almost abeam, perhaps this is taking advantage of it. The main and fore yards cannot be slewed around far enough to take advantage of this. The mizzen topsail appears to be able to, but the crossjack yard must have been let loose from its parrel and is controlled by the slings. Possibly it is even lashed to the mizzen shrouds as well? Where is this image from?
  8. I agree that the most likely cause is that the fence is not parallel to the blade ahead of the blade. The fence is relieved past the blade by Jim at the factory to allow clearance, so check for parallel. Oh, and always tighten the fence close to you before tightening the screw on the far side of the saw!
  9. I've seen examples of a physically flatter cypher that was given definition after the piece was blackened by a dusting of lighter grey powder to give just a little visual emphasis to it. Very effective.
  10. Quad hands? I count five of them.
  11. Very useful techniques and advice - particularly the last bit! Owch. Thanks, Paul.
  12. As for lighting, if you are doing serious carving, you need a directional light, preferably point source. The headlamp type is not suitable as the light will be head-on (sorry!) to the carving and you won't see how the light and shadows interplay from the surfaces when it is installed.
  13. Shaping up nicely now, Ron. Those hawse timbers and cants are a big challenge to do. I can't image doing them at full size!
