druxey
Everything posted by druxey
  1. Ow! Painful. Glad it wasn't worse though, Greg. At least you had the presence of mind to hit the switch. These things can bite....
  2. Brilliant diagnosis, Dean and Allan! So that's why I mentate more slowly than thirty years ago. Thousands upon thousands of treenails....
  3. Welcome aboard, Andrew. Which side of the Niagara River are you on? There are two clubs not far from you: Marine Modellers of Niagara (Ontario side) and Model Shipwright Guild of Western New York (Rochester). Both can be found in the 'clubs' section on this site, so take a look.
  4. Typically these indicate a cross-section between the arrows. The arrows show from which direction the cross-section is viewed.
  5. After you've flexed your muscles with one of the above suggested kits, think about the literally thousands of plans still extant for ships of the 18th century. Nearly all have never had a model built from them. Choosing one of those would be more than 'vaguely unique'.
  6. Lovely neat work. The mouse is particularly nice.
  7. I'll be sad to see the last of your updates; it's been an inspirational ride. However, I'll be happy for you upon completion!
  8. Titebond glues are also heat-reversible. I coat both the veneer and substrate with this, allow it to dry, then heat-bond the layers using an iron. A lot simpler than the alchemy of glue pots - and the odour!
  9. Just catching up on your build. Very lovely so far.
  10. Welcome aboard, Charles, from another Ontarian. Also, welcome to fatherhood! I found model-making times few and far between for the first ten years or so of my daughter's life. Perhaps you will do better. Check out Marine Modellers of Niagara on the club listings on MSW.
  11. Welcome aboard, CCM. Nice start there, but keep the cats away from your rigging!
  12. Visually, a great leap forward, Steven. I only ever had to do martnets once, and even at a much larger size (1:48) they were tough enough. I'm amazed at how well you've managed them at such a small scale.
  13. Anvil and hammer for drawing treenails? That is a little alarming! Nice morning, though. As AON observed, weather up here is slowly improving.
  14. Impressive, even at this stage of construction!
  15. Another good composer to listen to while modeling is the prolific Musio Clementi. Hours and hours of early piano works.
  16. Nick: also read the planking articles posted on this site. They explain that one also needs to adjust the belts or bands by eye after mechanically dividing them for a better aesthetic result.
  17. Welcome back to the hobby! Nice beginning, Vaidas.
