druxey
Everything posted by druxey
  1. Thank you, Dafi, for confirming that the Implacable capstan with its drop pawls and rim is early 19th century, not 18th.
  2. The Implacable capstan is a little later than 1779, as it has a drop pawl rim as per the 1796 technical drawing. I believe that this feature was introduced in about 1790. It's curious that the upper drumhead is missing. However, one can see the square tenon at the upper end of the spindle. Dafi's model is a brilliant recreation of a capstan manned and in action.
  3. Steel 1805, or the Sim Comfort facsimile edition 1977.
  4. Steel gives all the dimensions of each part of a capstan on Folios XXXVIII to XL. Also, these are given Allan's own book, which he is too modest to mention! It Scantlings of Royal Navy Ships 1719-1805, Allan Yedlinsky, SeaWatchBooks,2014, pages 184-194.
  5. Nice analysis of the changing waterway shape. I imagine that you will nail it, given your track record!
  6. Welcome aboard, indeed!
  7. Welcome aboard, Eindride!
  8. Bienvenue ici, Alain!
  9. Sweet, Michael! So nice to see this coming together.
  10. It is the ensign staff. Certainly it should be tapered and have a small cap on top with a sheave cut through for the ensign halliard. Look at contemporary models and paintings to see examples of these.
  11. Nicely fitted, Siggi! These are awkward to cut, even at 1:48.
  12. Very nice, but I'd be concerned about the short grain on the futtocks, the way you have them oriented on the sheet. Placed on the diagonal would be better.
  13. Looks easily recoverable. Use a little scrap piece glued under the break, then glue the end piece on over the reinforcing piece and transom.
  14. Welcome aboard!
  15. Generally the largest panes at the time were no more than about 9" by 12" - often smaller. A molten ball of glass was spun into a disc. After cooling it was cut up into panes, so-called 'crown glass'. The central portion attached to the pontil yielded the cheapest piece, sometimes seen in old windows as the 'bullseye'.
  16. Too many entries to click 'like' on, so consider them all liked! One small point: the window frames would look much better if you squared up the corners. All the other carved work is lovely.
