druxey
Everything posted by druxey
  1. That is annoying! I hope that you can easily extract the 'keys' to replace them.
  2. Not Sim Comfort's error: the pages are facsimile from Steel himself!
  3. Yes, there are a few typographical errors in Steel's tables. I'm amazed that, in so many pages, there are so few! As with the above example, it's usually easy to figure out the correct values from the neighboring tables of scantlings.
  4. I love the point where the rails go on and the model starts to take on a finished look! Lovely work, as ever.
  5. Yes, one does not need aggressive clamps, as you've discovered. And wetting the wood to reshape it is a good fix. I like the fact that you are taking care building this model.
  6. Welcome aboard, Sam!
  7. That is the wing transom! That is the one where the upper surface comes to an angle. Below is s set of transoms for another ship. 'W' is the wing transom, viewed from above. The grey line is the lower outline of the transom. Note that conventional numbering of the other transoms is from above to below.
  8. It's more like an inverted cone: the top edge of the wing transom should come to a point or angle.
  9. Just catching up with your log. Well done for sticking with the limber boards until they were 'just so'.
  10. A slightly damp rather than wet brush is effective for removing glue. I suspect you flooded the joint with water, diluting the glue in the joint. Otherwise, a great beginning!
  11. You need to run additional waterlines and buttock lines here that fair with the rest of the aft hull.
  12. Oh, my. Doing all that amidst the rigging.... Good on you!
  13. We look forward to seeing your rendering of this vessel, Greg!
  14. Hearty congratulations for an excellent model that I'm glad has received the recognition it deserves! You've done a beautiful job on her. (Hard to call such an ugly duckling 'her'!) We look forward to your next building adventure.
  15. I'm sorry to read about your bad luck, Gary. I hope you will be back home in under the six months you figure it will take. Where is this list of books you mention? Best wishes as you get things back together again.
  16. Fascinating read. It is clear and well written. However, I noted some inaccuracies such as the reference to the three volumes by Adrian Caruana. While Caruana planned three volumes, only two were actually published. Unfortunately he died before the third volume was completed. Occasional spelling errors such as 'healing' for 'heeling' and 'van de Weld' for 'van de Velde' suggest that this thesis might have benefitted from closer study by Mr. Pascoe's advisors. Thanks for bringing this study to our attention, Steve.
  17. Thank you for the additional eye candy, Daniel.
  18. Oh dear, Ron! Withdrawal was as bad as that for you? It was simply that someone forgot to feed the meter.
  19. Excellent result with the curved cove molding! Particularly in small sizes, the method you've used is really the way to go on this.
  20. Hearty congrats, Steven. Three cheers for completing your model in what has to be a record time (for duration)! Please make sure she's cased and protected now.
