druxey
Everything posted by druxey
  1. Congratulations for successfully reaching the finishing lion - I mean line! One of these models is a significant investment of time and effort. Well done, Stuglo!
  2. Nice update article and video on this vessel: https://www.bbc.com/news/uk-wales-64151535
  3. Ah, the joys of discoveries and figuring out revisions. I had exactly the same issue with my first scratch model, a 64. I cut a small notch into the back of the knee to locate the central extension of the knee. then glued in a slightly over-sized piece. Once the hair brackets were carved and added, I filed the assembly down flush athwartships. Hope this might help you.
  4. Coming along very nicely! Your methodical approach is paying off well.
  5. I might be concerned about the pH value of bitumen and whether it would have a long term effect on materials. Conservators have a very difficult time with bituminous paints as they never fully polymerize and 'set'.
  6. Check out Bob's build log for additional helpful information:
  7. Allan; you are assuming that Bray's lovely illustration is of a boat belonging to Pallas. I interpret that as a boat ashore that he saw, not one of his ship's boats.
  8. Yes, the trim of masts could be altered. One method was by adjusting the wedges at the partners. Another method (in use in the 18th century, at least) was a moveable mast step that could slide a few inches fore and aft along the keelson. it was secured by pairs of wedges fore and aft of the step. The wedges rested between the step and bolts driven into the keelson..
  9. For planking information, check the pinned articles on this very site! Another source is the book on open boat construction: https://seawatchbooks.com/products/the-greenwich-hospital-barge-of-1832-and-methods-of-building-open-boats-by-david-antscherl?_pos=6&_fid=1cc675229&_ss=c
  10. Well, you have a wealth of information available, Rob! That makes for a good start.
  11. 'Turned up' it is! Thank you, Bruce.
  12. Interesting use of the word 'tuned', James.
  13. 0.4 mm? Tut, tut, Mark! Seriously, that is an impressive degree of accuracy that won't need much tweaking at all.
  14. Nice bit of kit to have. Your work so far looks very neatly done.
  15. I think Jaager is correct: turned rather than tuned. Sometimes transcribing period script is difficult.
  16. Sleepers are very tricky to get 'just so'; you've made a super job of them, Mark!
  17. The bumping would be even worse at the bottom end around that small diameter rowle! The 'in the air' tube would probably have been be supported within the well that surrounds all the pump mechanisms.
