druxey
Everything posted by druxey
  1. It will be next year, I understand. Well worth waiting for!
  2. Also: https://www.rmg.co.uk/collections/objects/rmgc-object-388866
  3. The Science Museum (London) once published a set of her lines at 1:48 scale: https://collection.maas.museum/object/149083 Perhaps you can run down a copy of this plan.
  4. Were there any means of elevating the piece? From your reconstruction, it appears not.
  5. Interesting to see the similarities and variations from other carriages of the era. Congratulations on completing one stage of your project, Waldemar.
  6. That red line measurement should run all the way along the post, up the transom bulkhead and to the 'corner' where the strip representing the topside comes; just like the other green measurements.
  7. Well done! Those 'planks' and the ekeing rails are the toughest timbers to form in a ship.
  8. Looks like a very good beginning, Chris. I was never up early enough when my daughter was young, and got no model-making done for ten years. Most enterprising of you!
  9. Some of the planking terminates before reaching the stem. The garboard (strake next to the keel) ends just where the stem begins to curve. Look at the planking tutorials on this site to get the idea. Nothing wrong with your 'fan' and the way you are using it.
  10. Without a rigid wire core, in a model it is difficult to avoid some deflection of the stays.
  11. Ah, the old faithful Unimat! Mine is still going since 1970. Had you considered using a center in the tailstock to provide more support? That would take care of the hole that you need to drill anyway.
  12. Stopping the rabbet on the keel forward of the post was standard in English ships. Not only (as mentioned by Ed) did this not weaken the narrowing keel, but the garboard strake which widens here can be got out of a slightly narrower plank as a result.
  13. And so work continues.... Good to see you back at it, Ben.
  14. Tonphil: If you can afford it, get the Byrnes saw. There is no comparison, particularly in power for cutting heavier stock.
  15. Congratulations, George, on a lovely model and for her display in the Maritime Museum. Well done!
  16. Slow and methodical does the trick.... That framing looks really nice so far.
