Everything posted by druxey
Looking good, SHJ! I use Saran wrap stretched with masking tape around the edges rather than waxed paper for a non-adhesive surface.
- 63 replies
- Finished
- Khufus Solar Boat
Cargo ship ( possibly a cog) found in Estonia
druxey replied to liteflight's topic in Nautical/Naval History
Thanks for the update! -
Bob: As you obviously have the interest, I suggest you are well on your way to scratch building and research. Fortunately there is a lot available online these days. Due to economic constraints, there is a limit to how accurate any kit can be. The more costly, the more you should expect, but that is not always the case. I applaud your efforts to get it right, or closer than the 'out of the box' kit can be.
- 146 replies
- Harriet Lane
- Model Shipways
Cheers! Well done, Kevin. Except that the box description should read 'its', not 'it's'.
- 1,134 replies
Mariner's Astrolabe, full scale, AON
druxey replied to AON's topic in CAD and 3D Modelling/Drafting Plans with Software
As long as you don't navigate yourself onto any rocks.... That is pretty good accuracy, Alan. Well done!- 36 replies
- Navigation
- Instrument
Ye gads, Kevin! Some really heavy duty silver soldering to come? Seem a pity to hide all that framing, but the planking job looks very good.
- 1,134 replies
Sorry about the travails of breakage and failed glue, Steven. Kudos for persisting and overcoming!
- 740 replies
- Tudor
- restoration
(and 4 more)
The standing rigging will do its job and keep the masts in place - just like the real ship. No glue required!
- 146 replies
- Harriet Lane
- Model Shipways
Question for full sail shape of spritsail
druxey replied to modeller_masa's topic in Masting, rigging and sails
Perhaps starch painted on and allowed to dry while the 'wind' blows? -
PIllars
druxey replied to allanyed's topic in Building, Framing, Planking and plating a ships hull and deck
Many instances of 'doubling up' would be to resist greater forces on the beams where there will be stress or weight. -
HMCSS Victoria 1855 by BANYAN - 1:72
druxey replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
I've had good success by drilling a hole in brass sheet of the thickness of the ring I need. The hole is the OD of the tube 'slice'. I insert the rough-sawed ring and file the surface flush to the sheet using a fine file. Your turned result using lathe and wood mandrel is very nice indeed.- 1,021 replies
- gun dispatch vessel
- victoria
The learning curve is well under way!
- 13 replies
- Lowell Grand Banks Dory
- Model Shipways
