Everything posted by md1400cs
Oseberg by Davemc - Billing Boats
md1400cs replied to Davemc's topic in - Kit subjects built Up to and including 1500 AD
Dave, Good luck - will follow along - my next build will be a Viking ship. Yes Jack P's is gorgeous indeed. Regards, -
Hi Mates, Thanks for the likes and nice comments. Finished up the lower gun deck inner wall timbers - added lights, then slid its deck into place. Need to add nails here and there along with hooks for carriage blocks/ropes to those inner wall planks, as well as to the wales on the port side. Used the kit provided knees – they are not "correct" but fit really well - and won't be too noticeable, I hope. Going to try to salvage, and fix that deck framing that did not work out earlier with this build– might be ok for mid-gun deck?.
- 371 replies
Mark, She's turning into a superb build. I don't remember if you mentioned this either way -- do you intend to add sails or just standing rigging? Regards,
- 331 replies
- nuestra senora del pilar
- occre
Oh Oh Mark - It is available in the US now. !! https://www.model-space.com/us/build-the-vasa-ship.html
- 91 replies
- deagostini
- vasa
Patrick: as always thanks... Starting on the lower gun deck outer hull planks along with, this time, proper looking gun port framing as well as second row of wales. My last build cannon wood framing was was so not ok -- last pic (I was still learning [still am]) As always mates thanks for dropping by...... Cheers,
- 371 replies
Martyn, NICE - will, of course, follow along as well. I also share your exact thoughts Cheers,
- 91 replies
- deagostini
- vasa
Finished up the coppering. Will use the kit provided gun port frames only as a guide to locate proper framings throughout. I also plan to build the hull gun port doors from scratch. Note – kit instructions suggest using black and then red paint for certain timbers, including carriages. I have shied away from this with my two previous builds, and will do the same with this one, just a very personal preference nothing more. So I will leave those triple oak wales as they are. Cheers,
- 371 replies
Hi mates Denis: Thanks for the comments. Before I even think about “patting myself on the back” I need to bow to all builders who actually copper entire hulls. My simple little cross section doesn’t hold a candle to those other builder's work and the complexities involved in properly setting 1000s of plates to the curves also involved. I am happy, however with how this first attempt is coming out. Frank: these pliers were part of a set I bought years ago when I was detailing model cars and engines. I think that I got them at Micromark. https://www.micromark.com/Metal-Forming-Pliers-Set-of-4 Regards,
- 371 replies
Hi Mates, Started copper plates installation. Decided to start at keel, because if I messed up -during first attempt at this - I could easily hide errors, and learn as I went up to the water lines. Yes some early alignment, and spacing issues -- hiding haha -- but once I got the hang of it all fell into a nice pattern, so far so good. Here are a few early start pics. Regards as always,
- 371 replies
Ulises, Nice to see you back as well. Your tops look excellent - nice work.
- 786 replies
- Royal Louis
- Finished
A couple of Very minor updates from today -- Added rope stays to the barrels Added shot framing to the lower gun deck (not as it should be) but done,
- 371 replies
Martyn: Thanks - ordered the Gorilla brand. Now straightening out and or slightly curving the copper plates. Glue comes Monday so looking forward to this section of the build. Patrick: Agreed the brass, non decorated barrels will look more appropriate for this build. After the coppering, will get back to getting those painted, mounted, and secured to the lower deck. Then I need to figure out the proper locations for the gun door framing, and how they connect to outer hull planking. My Vasa was all wrong (at the outer hull) -- I'm determined to get it right this time As always mates thanks for your advice, help, and just dropping by Cheers,
- 371 replies
Martyn, Super nice -- all of your extra details AND the lights make this one really special - Gongrats Regards,
- 16 replies
- santisima trinidad
- deagostini
HI Mates, Frank: thanks for the idea. I knew about this technique, but not quite comfortable enough trying to make the strips look realistic. Denis: tried your idea. The admiral has a wooden rolling pin, I don’t think that I could push hard enough to flatten the dimples. Also the wood absorbed some of the pressure points. I got poor results. So Plan B; No longer using the pliers, one at a time instead using double sided tape and our knife sharpening stone just taping on the dimples with a hobby hammer. Much better, and faster "factory production" -- Also, since I will reverse side -- attach of the plates –dimples really need to be very flat to properly lay upon hull planks once glue is added. Hammer taps on that stone block does the trick. Not sure what glue to use will try CA Gel on a practice piece. Cheers,
- 371 replies
Dave, Just discovered your superb project - went through your build log -- Awesome work indeed !! Cheers,
- 128 replies
- mordaunt
- battle station
Hi Mates, Thanks for the welcome back and you visits. So, carriages/guns put on hold - It occurred to me that I prob. should copper the hull before adding more bits and decks. This will be my first effort. I’ve seen and followed some great builds that added plates. Of course this small, easy cross section will be a “walk in the park, compared to coppering full hulls. That said, I read a very interesting letter in the Spring 2018 Vol. 63 issue of the Nautical Research Journal. Member, Ian Poole, was commenting about how copper plates added to models are sometimes rather inaccurate looking because of the “nails issue”. He stated that available copper plates have overly large simulated copper nail indentations. He went on to state that, of course, copper plates were attached using counter sunk copper nail heads; indeed barely visible. In any case copper nails should not stand out above the plates. All for obvious reasons – So It got me thinking about how to “improve” the look of the after-market plates that I intend to add to this build. My solution. 1) Use the Model Shipways plates that I had pre-purchased. 2) Using piers flatten all the nail dimples on each plate 3) Flip the plate over and attach those to the hull with the backside facing up. This look more accurately simulates the look of counter-sunk copper nails. Here are a few preliminary photos; The new plate faces certainly looks more “realistic”. PS: Yes – lots and lots of extra time will be needed having to re-work each of the 100s of needed plates. Could be overkill?? Regards,
- 371 replies
Frank, Just catching up - looking V. Good. Cheers
- 510 replies
- reale de france
- corel
Mark, Just catching up - as always a pleasure following your excellent work. PS: Your shot framing is so well done! Cheers,
- 331 replies
- occre
Hi Mates, Minor – catch up post – after taking some yard time off. When I started doing all of these block and carriage bits (again) – having spent five years on the Vasa – I found little motivation – almost shelved this one to bring up the Viking ship from under the table. Then – No – back into this project Still not sure about the cannons – sure like the ones with decorative markings, though not Spanish. That said the kit included ones are certainly more accurate and a bit longer as well. So would look better once installed with carriages fully forward. I think that the blocks are a bit big, though the next size down where way too small. Next bit air brushing the barrels. As always thank for still dropping by --- Cheers,
- 371 replies
Patrick, Just catching up. Indeed each of your postings supersedes the previous --- superb work. Your attention to period details are brilliantly executed as well. Cheers,
- 756 replies
- galleon
- golden hind
Ulises, Glad to read that your shipyard will be opened again!
- 786 replies
- Royal Louis
- Finished
E.J, Woa !! just as the above five members just said - Splendid. Your decision to take a risk with carving and sculpturing was indeed a good one. That is a big step forward in you skill set. Well done!! And that specific blue that you chose makes the gold really POP. Your attention to scaling that entire stern area looks brilliant as well. Cheers,
- 961 replies
