Glenn-UK
Posts posted by Glenn-UK
  1. Stage 18 – Completion of Hull Construction Phase
    Hull Construction – Final Tasks
    Build Steps
    64-73
    A lot of work has been completed and the hull build phase is now complete and I am ready to move on to adding the deck fittings. The completed tasks are:
    a)      Cutting the gun port openings. After sanding the cut edges, I decided to add some gun port linings using some spare material. I painted the lining red.
    b)      The bow keel was glued in place and painted black.
    c)      The gunwale were painted black and then glued in place.
    d)      The swivel gun posts and timberheads were glued in place on top og the gunwales.
    e)      The stern side timers and top piece were added to the stern.
    f)       The stern transom rail and stern counter rails were painted black and then added.
    g)      The upper support rails were painted red and then glued in place.
    h)      The cleats were added to the inner bulwarks.
    i)         I test fitted eyebolts in all the holes on the inner bulwarks and deck. The eyebolts still need to be chemically blackened before they are glued in place.
    Time Taken
    180 mins
    Current Build Status Photos
    I have added some photos showing the current status of the build.
    001.thumb.JPG.7d99b7b43739e6aacd3145f92633874e.JPG002.thumb.JPG.5c8790e44de0bad71093d815e50b235b.JPG003.thumb.JPG.a418dd2b1cca80f0587e5446ad398f3d.JPG004.thumb.JPG.773bc1383ac3ddbadb4147ea14f79b40.JPG005.thumb.JPG.7270904dd2c01c42969148b67af645a3.JPG006.thumb.JPG.5e4297a424f019ebf1139d33c23d8bd2.JPG007.thumb.JPG.566201609e07dd4c2794388d610ca1b1.JPG008.thumb.JPG.c1a442092391049100f579b0bf804016.JPG
  2. Stage 15 – Laser Engraved Deck Installation
    Hull Construction – Laser Deck Installation
    Build Steps
    53-55
    The excess bulkhead tab material was removed, and the remnants were then sanded smooth. The laser engraved deck was then test fitted, after the laser char had been removed, from the outer edges. The deck was a good fit and I also checked the various deck items would locate in the various apertures.
    Plenty of wood glue was then brushed on to the deck base and the laser engraved deck was fitted. Plenty of clamps were then used to keep the deck in contact with the base while the glue cured.
    Time Taken
    20 mins
    001.thumb.JPG.3eaedf0fecb8f56c2ea5c20d5905790b.JPG002.thumb.JPG.1b3906f232cf85ebdf66a0f30e97de4e.JPG003.thumb.JPG.98068123c9d4b84149e26fb6abbbcadb.JPG
    Stage 16 – Fitting Inner Bulwark Patterns
    Hull Construction – Inner Bulwark Patterns Installation
    Build Steps
    56-61
    There are two inner bulwarks per side and the front patterns were soaked in warm water for a few minutes and then clamped to the hull. Once the patterns had fully dried out they were test fitted and did require a bit of sanding on the leading edges before I was happy with the alignment.
    Plenty of wood glue was then brushed on and the inner bulwark patterns were carefully aligned and clamped. As can be seen in the attached photos I did dry fit some eyebolts to ensure the patterns were correctly aligned.
    Time Taken
    30 mins
    004.thumb.JPG.2e331cffa3e130182d6174f6333ca66b.JPG005.thumb.JPG.ac6606f1e5c39e53a81da5b6c2e1326c.JPG
    Stage 17 – Fitting Spirketting Patterns
    Hull Construction – Spirketting Patterns
    Build Steps
    62-63
    There are two spirketting patterns per side. These patterns were test fitted, and they did require a bit of sanding on the leading edges before I was happy with the alignment.
    Plenty of wood glue was then brushed on the patterns and they were carefully aligned and clamped. As can be seen in the attached photos I did dry fit some eyebolts to ensure these patterns were correctly aligned.
    Next I sanded the top edges of the bulwarks flat and added a curved section on the left side of the front bulwarks for the bowsprit seat.
    Time Taken
    30 mins
    006.thumb.JPG.d464cd7ebfdec9c19a7323a8fceee12c.JPG007.thumb.JPG.e3d405502b3905df34bbc008d0cb5c13.JPG
    I have added some photos showing the current status of the build, noting I have dry fitted some of the deck items.
    008.thumb.JPG.63ee2f3d7c1f3429ef3cd499f05f2e05.JPG009.thumb.JPG.9511149145fd940ff6877303db61fb22.JPG010.thumb.JPG.32524c6f9dbd2c8e0731a3add8afdb81.JPG011.thumb.JPG.89974f2d9c39d5314bdebed6c3212454.JPG
  3. Stage 14 – Wales and Depth Markings
    Hull Construction – Hull PE Parts
    Build Steps
    51-52
    After bending the two wale patterns for a good fit around the bow area they were painted black. I did apply a WOP coat before painting the wales. The wales were they glued and clamped in place. Next I added the horseshoe and depth markings to the hull. Cut down pins were inserted in all of the horseshoe holes.
    I have now completed the basic hull assembly phase of this build.
    Time Taken
    120 mins
     001.thumb.JPG.a43d1dfa1ce438b4fad878196676a56b.JPG002.thumb.JPG.9744ce52856869a042fc4116eeaf2abb.JPG003.thumb.JPG.0b9cac1cfbede02dff46d846f6b2c4e4.JPG
    As can be seen in the photo below I need to tidy up the lower stern panel paint job.
  4. Stage 10 – Outer Bulwark Patterns
    Hull Construction – Fitting The Outer Bulwark Patterns
    Build Steps
    47 - 48
    After test fitting the previously shaped patterns the two outer bulwark patterns were added to the hull assembly. I brushed plenty of wood glue to the hull and the two patterns were then carefully positioned and clamped the hull, as can be seen in the following two photos.
    Time Taken
    10 mins
    001.thumb.JPG.ce9512b1d049243f25ac8d8b9debadcd.JPG002.thumb.JPG.b9de199b8c27e5d1ae1e1cc3ccab2fac.JPG Stage 11 – Shaping the Main Wales
    Hull Construction – Shaping The Wales
    Build Steps
    51
    After wetting the bow end of the two wale patterns they were clamped to the hull and a hair dryer was used help the wale retain the bend around the bow. This is shown in the next two photos. The wale patterns will be removed and painted black before they are glued in place.
    I have also sanded the excess material shown by blue arrow in second photo from the stern area.
    Time Taken
    10 mins
    003.thumb.JPG.5691539d7c337f555dd6ea8263c1ca9e.JPG004.thumb.JPG.245c354e9ac5b4f019557ed2c00a869c.JPG
    Stage 12 – Fitting Lower Stern Counter Pattern
    Hull Construction – Outer Lower Stern Counter Pattern
    Build Steps
    49
    After wetting the outer lower stern counter pattern it was clamped to the hull so it could follow the curve. Before gluing the pattern in place, I did a test fit of the transom rail pattern. Everything looks good so the lower stern counter pattern was glued in place.
    Time Taken
    20 mins
    005.thumb.JPG.81b51aacea4b888a51067ade7f09f840.JPG006.thumb.JPG.878463219ad737190cf0a5e973e9c086.JPG
    Stage 13 – Horseshoe Show and Fishplates
    Build Steps
    52
    A coating of photo etch primer paint was sprayed on the PE parts for the horseshoe, fishplates and depth markings. They were then painted copper. As can be seen in the the next two photo the two horseshoe patterns have been test fitted and the two fishplate patterns have been glued in place.
    Time Taken
    10 mins
    007.thumb.JPG.113694da872f76a74197f57ce3fbde12.JPG008.thumb.JPG.a090e9b0c488fb6070f671e5a891ac6f.JPG
  5. Stage 9 – Pianting The Hull
    Hull Construction – Painting The Hull – Stage 1
    Build Steps
    44-46
    Painting the hull white takes time to get a nice even finish. After brushing diluted wood filler in the visible gaps / depressions in the completed second planking the hull is sanded until it feels smooth to touch. A thin coat of white paint was then applied to the hull as this really shows up the defects as can be seen in the following four photos.
    Time Taken
    30 mins
    001.thumb.JPG.3205a51ebe3b2b34c044b4aabc0f82f2.JPG002.thumb.JPG.e2f88b1e867253464e0664fea5231cf5.JPG003.thumb.JPG.b43f34486d12fe7a9a2dcdff9e59e31d.JPG004.thumb.JPG.ed399e4621e6583db1d9534533f1347b.JPG
    Hull Construction – Painting The Hull – Stage 2
    Build Steps
    44-46
    A liberal amount of slightly diluted wood filler to the hull, as can be seen in the next two photos.
    Time Taken
    10 mins
    005.thumb.JPG.46fa87c70a9e92e84b3b58d0bc7bf608.JPG006.thumb.JPG.3c775662fa511e5d75ad064760f55546.JPG
    Hull Construction – Painting The Hull – Stage 3
    Build Steps
    44-46
    Once the wood filler has dried the hull is once again sanded smooth. As can be seen in the next three photos the hull is looking smoother, but more work is still required.
    Time Taken
    20 mins
    007.thumb.JPG.f09a742974b29824cbeb6e210fd7b667.JPG008.thumb.JPG.a14a1c4ae4cd7c575620d5c861d8f2db.JPG009.thumb.JPG.c5813d49e52412460795976b43a30b6c.JPG
    Hull Construction – Painting The Hull – Stage 4
    Build Steps
    44-46
    More diluted wood filler is then applied to the areas which need more attention and then the hull is once again sanded smooth and this process is repeated until I was happy the end result, as shown in the next three photos.
    Time Taken
    60 mins
    010.thumb.JPG.5832928a8602d0662e46bd45869e11ae.JPG011.thumb.JPG.72ad397a2f6a79716ea266002daf5ad5.JPG012.thumb.JPG.f31e532122d56879ff2d45efd4bc2fcf.JPG
    Hull Construction – Painting The Hull – Stage 5
    Build Steps
    44-46
    The rudder was also assembled and painted and then test fitted, as shown in the next photo. It will be added to the hull later in the build process.
    Time Taken
    10 mins
    Hull Construction – Painting The Hull – Stage 6
    Build Steps
    44-46
    The outer bulwark patterns were then test fitted against the painted hull and everything look good.
    Time Taken
    5 mins
    014.thumb.JPG.69e7b3c6915ebe33b6d177bff405d52b.JPG015.thumb.JPG.4eb8bc9970ca99be93a39f0bb1436880.JPG
  6. Stage 8 – Second Planking
    Hull Construction – Start of the Second Planking – Appling a lateral bend
    Build Steps
    33
    I have reverted to using Chuck’s lateral bending method as it is yielding much better results than the method used for the first couple of upper planks. After wetting the plank, I used clamps to apply a lateral bend. I then used a hairdryer to dry the plank so it hold’s its shape once the clamps are removed. Please refer to the first two photos below in respect to the above
    In the third photo below a laterally bent plank is being test fitted and this plank looks OK. Sometimes it is necessary to repeat the bending process to get the required lateral bend.
    Time Taken
    5 mins
    001.thumb.JPG.66adf4c3191f65bbf2f984128d3432a8.JPG002.thumb.JPG.8f19ca3bdc1550e95f2b022813ffba91.JPG003.thumb.JPG.cddf54ae91cc027168aae25937407e3c.JPG
    Hull Construction – Start of the Second Planking – Adding a plank
    Build Steps
    33
    Before fitting the plank, The area where the ca glue needs to be added is marked. This is shown in the first photo below.
    The plank is dampened, as this helps the adhesion with ca glue. Ca glue is then added to the hull along the marked area. Starting at the bow the plank is pushed into the rabbet and then is pressed down working back toward the stern, ensuring any excess ca glue is wiped away. The final three photos show the end result after 7 upper planks have been fitted to both sides.
    Time Taken
    10 mins
     004.thumb.JPG.647913baddde677c14d3add3b3908cb1.JPG005.thumb.JPG.120bea33146853a2bace77aa4d0bc84f.JPG006.thumb.JPG.da281e7d3fb4abcb7fbe4a6ca29541d4.JPG007.thumb.JPG.4d00785c8dcea8ae5b4ccd85b8b287e6.JPG
    Hull Construction – Completing Second Planking – Starboard Side
    Build Steps
    33
    A total of 15 off full planks were required for the second planking on the starboard side. I am really pleased with the end result. Although more work is required to improve my technique, this is without my best work with regards to adding the second planking.
    Time Taken
    60 mins
    008.thumb.JPG.cdb1598f3130c4ff0457939550d8e1dc.JPG009.thumb.JPG.e1f947d7f92346fcda2f19360b2232aa.JPG010.thumb.JPG.4489d0d0fc9beade28d6e343250dbb43.JPG
    Hull Construction – Completing Second Planking – Port Side
    Build Steps
    33
    I have added 11 planks to the port side, so there are 4 more planks to fit to complete this task. As can be seen on the second photo the gap to fill, at the midship section, requires exactly 4 planks.
    Time Taken
    60 mins
     011.thumb.JPG.eec027ebc2cd37a0ad7fd5cfb0414283.JPG012.thumb.JPG.50b7ae68f31873a90376653e3c3aa828.JPG
  7. Stage 7 – Fitting Outer Prow, Keel and Bulwark Patterns
    Hull Construction –Prow nd Keel Outer Patterns
    Build Steps
    33-36
    The two prow outer patterns were glued in place, using the locking keys to help with the correct alignment. I also used a pin to check the various holes in these patterns were aligned with each other. Once that was done, I repeated the process for the two outer keel patterns. I used plenty of clamps to hold these patterns in place whilst the glue cured.
    Time Taken
    10 mins
     001.thumb.JPG.ffa94164c2e3c7a3505fa1f7ca9a427f.JPG002.thumb.JPG.580926e76e0fd25d9cf76adb11c7d9bc.JPG003.thumb.JPG.ebe7fd1906f64ca533c71db370f3868b.JPG004.thumb.JPG.d78631cccd83ce85c247c219ac546bc2.JPG
    Hull Construction – Outer Bulwark Patterns
    Build Steps
    37-38
    I soaked the two outer bulwark patterns in warm water for a few minutes and then clamped them to the hull and left them overnight to fully dry out and to retain the required bend.
    Time Taken
    20 mins
    Stage 7 – Start Of Second Planking
    Build Steps
    33
    With the two outer bulwark patterns still clamped, but not glued to the hull, I started the second planking.
    I started with the upper most plank for both sides. I wetted each plank so I could manipulate the required bend at the bow and stern using my hands. Once I was happy with the dry fit I applied some ca glue to the hull and then fitted the slightly wetted planks. The outer bulwark patterns were then removed from the hull. I then added two further upper level planks per side.
    Next I added the garboard and it’s adjacent plank to both sides. It took a bit more time to fit these planks as I had to ensure I had the correct shaping to these planks when fitted to the bow.
    Time Taken
    60 mins
    005.thumb.JPG.e7c9cf44d9ea29673ece402e8dea9918.JPG006.thumb.JPG.ae55c27c98d3afc37ec3af3d81c6c964.JPG007.thumb.JPG.d3b30e7f2b6f24d96969e5c85bb735f3.JPG008.thumb.JPG.7a8c7fe7e8581d5110dbcf9dec1144da.JPG009.thumb.JPG.f7a3235866fb1d24e72e55d067bb81e5.JPG
  8. Stage 6 – Sanding First Planking Part 1 – Checking Rabbet
    Hull Construction –Checking Rabbet – Left-hand side
    Build Steps
    33
    Before I started the hull sanding process, I thought it would be beneficial to dry fit the outer prow and keel patterns. In the first two photos I have indicated where the rabbet needs to be opened up (yellow arrow) and where some filler will be required (blue arrow).
    Time Taken
    10 mins
     001.thumb.JPG.c1b3af08fc104ef2a21e3af8faf32463.JPG002.thumb.JPG.568cf7f0d7d1076f80bf5c0d1dc33458.JPG
    Hull Construction –Checking Rabbet – Right-hand side
    Build Steps
    33
    As can be seen in the next photo the outer bulwark pattern does fit in the rabbet. However, there is work required to open (yellow arrow) and fill (blue arrow) some of the rabbet along the prow and keel, where the second planking will terminate as shown in the second photo (yellow arrow).
    Time Taken
    5 mins
     003.thumb.JPG.51cbc0b77e7a172d527fb0ad257eab28.JPG004.thumb.JPG.29c9739a64d11a73fc0c02382aae7f66.JPG005.thumb.JPG.48fa457352585f6fe9e5e8632888b633.JPG
    Hull Construction – Modified Rabbets left and right
    Build Steps
    33
    In the following three photos the rectification work has been completed and I am now happy that the second planking will locate in the rabbet. In the final photo you can see a test plank has been successfully slotted in the keel rabbet. I have also started to work out the curved shape. As you will note my first shaping still requires more work. I find it is easier to test fit the garboard plank bow shaping on a test piece before the outer pattern have been glued in place.
    Time Taken
    30 mins
     006.thumb.JPG.068a8270f65302023839e61456a632e7.JPG007.thumb.JPG.b9bfec583a674c6fc32bd1bb53e18a3a.JPG008.thumb.JPG.3535df0d07ad46f7e41b9f6915adb9b7.JPG
    Hull Construction – Hull Sanding
    Build Steps
    33
    I have also completed sanding the hull smooth. I smothered the hull  with wood filler and once it had dried I used my mouse sanding and sandpaper to remove most of the wood filler, the remaining filler was left in the depressions. I also sanded the dead area (stern) to ensure the second planking, when fitted, will sit flues with the keel and stern post.
    Time Taken
    30 mins
    Sorry I  forget to take some photos of the sanded hull but I try to remember to add some in my next post.
  9. 50 minutes ago, Knocklouder said:
    I was determined to do better, please  go to @Glenn-UK log of the Duchess  his is fantastic. I take far to many short cuts but it looks good. But his is the proper way to go. He even doing a Sherbourne, got me thinking  I should buy one, but I have so much to rig.  :)
    Hello Rob
    Many thanks for the mention. I still have much to learn and improve with regards to the model ship building and the Sherbourne was really helped me improve my planking skills.
    You are doing a fantastic job.
    Glenn
  10. Stage 5 - First Planking Part 4 – Task Completed
    Hull Construction –First Planking Completed
    Build Steps
    31-32
    Today I added the final two planks per side followed by the steelers which means I have now completed the first planking.
    I have also trimmed the excess planks material around the stern area and the hull is now ready to be sanded smooth. I will  use my mouse sander initially before reverting to a sanding block, sandpaper and sanding sticks. The mouse sander will be a great help when reducing the plank depth around the stern area so the second planking, when fitted, will sit flush with the keel and stern post.
    This is the best first planking  I have managed in all of my boat builds, but there is still a lot of room for improvement.
    Time Taken
    120 mins
     001.thumb.JPG.301f66a1e31f1afcfbc5becfdc203d85.JPG002.thumb.JPG.ba1baefd5785266c4ad2b61cb282ed2f.JPG003.thumb.JPG.82b9fd932a9daa815d65014d98fe3cfb.JPG004.thumb.JPG.d9815498fb87cf107d733cd462598d5d.JPG
  11. Stage 5 - First Planking Part 3
    Hull Construction –First Planking Method
    Build Steps
    31-32
    I have continued with the first planking working down toward the keel. It takes me approx. 20 minutes to fit each plank. This can be split down to 5 minutes to test fit, taper and to add a bevel to the top edge of the plank. It then takes me 5 minutes to bend the plank using steam from a boiling kettle. The steam process sometimes requires 3 or 4 kettle boils to get the required bend (bow and stern). It then takes me around 10 minutes to glue and pin the plank to the hull and to then clean away any excess wood glue.
    Overall I am pleased with this new method of fitting the planks and although the planking is not perfect I am not suffering, as much, with a clinkered effect. One of the other positives is that I bought a new pin pusher which is so much easier to use than my other two pin pushers.
    The most beneficial aspect of the steam bending process, in my opinion, is the ability to add twists to some of the planks which ensures the planks sit flat across the bulkheads.
    You may also note a red tinge on one of the attached photos, as I did manage to cut my finger when trimming a plank and did not realise until I noticed the blood on the hull.
    In the final photo of this photo you will note that I require exactly two planks to complete the planking along with some stern stealers.
    Time Taken
    210 mins
     001.thumb.JPG.ecb37f627a7534cba1433ddda513c865.JPG002.thumb.JPG.e61d0b2789f1f5b9b652e64a0aa768aa.JPG003.thumb.JPG.dd6c568b29f282d683f44a11badcb3b8.JPG004.thumb.JPG.3d9d9ae82a7e38958e7f70f0857a7c5a.JPG
  12. Stage 5 - First Planking Part 2 (Garboard Plank)
    Hull Construction –First Planking Method – Adding Garboard Plank
    Build Steps
    31-32
    I have now fitted the garboard plank and its adjacent plank on both sides. I used the same method, as per my first three planks, when fitting these planks.
    Time Taken
    60 mins
    Photo 1 shows the first step where the centre bulkhead is aligned with the plank (Blue arrow). The bow shaping has also been started but still needs a little bit of sanding. The yellow arrow indicates where a slight twist will be added using steam from a boiling kettle.
    Photo 2 shows the stern area and the yellow arrow indicates where a twist will be added using steam from a boiling kettle.
    Photos 3 & 4 were taken after I had applied the twists and I am test fitting the bow and stern sections before gluing the plank in place.
    Photos 5 to 8 shows the current garboard plank build status and were taken after the second plank had been added. 5 planks have now been fitted per side which means another 7 planks per side are required to complete the 1st planking task. Adding the twists to planks has been an eye opener for me and has certainly made the planking task easier.
    001.thumb.JPG.2a75e7ba01e8bdf6067e8e7c7a53819d.JPG002.thumb.JPG.4105bf9c479189ca1e7f7792dbe207f2.JPG003.thumb.JPG.db085fdad9daec2b45d79584ade7b817.JPG004.thumb.JPG.5ea0104b35e6c6af3f9aad54f053e8a4.JPG005.thumb.JPG.afa842f84e6233a39e1bde2c9bb1dfe5.JPG006.thumb.JPG.414d030c502b399bc33979e8027fef79.JPG007.thumb.JPG.b4b9d02958e2923ad89588689f19cf3b.JPG008.thumb.JPG.f85bddea8845a59f2fecb7d241f92323.JPG
  13. Stage 5  First Planking Part 1
    Hull Construction –First Planking Method – First Three Planks
    Build Steps
    31-32
    I have now started the first planking task. The first two photos shows the first plank in place. When fitting the planks I start by positioning and marking the plank against one of the central bulkheads as a reference point. This is shown in the third photo below. I then mark the point at which the plank starts to overlap around the bow area. I also mark the point where a slight twist in the plank will help with the fit around the stern. I then draw the required bow taper so the plank width is approx 3mm wide when the plank meets the prow. The tapered plank is then test fitted and, when necessary the taper is tweaked for a better fit. I also add a chamfer to the top edge of the plank. Next using steam from a boiling kettle the bend is applied to the bow end and the twist to the stern end of the plank. Once I am happy with the shaping, I check the position of the plank with the pencil marking on the central bulkhead and adjust the markings as necessary so the plank is a good fit with the prow. Once that is done, I applied glue to all the bulkheads and the plank is positioned to the central bulkhead, using the pencil alignment.  The pins are then added, started from the centre and moving toward the stern and bow one pin at a time.  Once the planks has been pinned any excess wood glue wiped away. The final two photos shows the Sherbourne after three planks per side have been added. In total there will be approx. 12 planks per side required at the widest point with some stealers required at the stern.
    Parts
    Time Taken
    120 minutes
     001.thumb.JPG.e91e2b7bdce72b14ab6f5870b8514fb8.JPG002.thumb.JPG.446f734e68c88977f98baf44878700c6.JPG
    003.thumb.JPG.c279c46aa4cdadca6ea53298172c23f4.JPG006.thumb.JPG.91054b4c255be55627ee7ac40bba051e.JPG007.thumb.JPG.26cd8e87a720b537332f2c1bee866a7b.JPG
  14. Stage 3 Fitting the Outer Bulwark Patterns
    Hull Construction – Installing Bulwark Patterns
    Build Steps
    23-30
    The outer bulwark patterns were test fitted but I felt there was not enough give to bend these parts around the bow. After the bow ends were soaked in warm water for a few minutes it was then possible to test fit the parts and to clamp them in place to allow the patterns to fully dry out. As can be seen in the following photos I did make sure the patterns were aligned with the laser etched deck and bulkhead guidelines. I will do another couple of test fits to make sure I am totally happy with the fit. Before gluing these pattern in place I will also experiment with a new (for me) planking method.
    Parts
    30L, 30R
    Time Taken
    10 mins
    001.thumb.JPG.7215e6bc3e93164f6407b0ac7d90c112.JPG002.thumb.JPG.6072c1b07784d054f5c59f3f67f7ef09.JPG003.thumb.JPG.bee4230f9d64069f946eca436e7132bb.JPG
    Stage 4 First Planking Testing Method Bow
    Hull Construction – Testing First Planking Method - Bow
    Build Steps
    31-32
    One of the reasons I bought this kit was to try out a new method of planking which I had seen on Jason’s “Modelkit Stuff” YouTube channel. I am using some spare planking material for this task. With the plank held in place I added a pencil mark on the plank where it starts to overlap the bulwark, as shown in the first photo. I decided that I would trim the plank down to half its full width. After drawing a line I placed the plank in my strip clamp as shown in the second photo below. The excess material was then removed using my mini place and then a sanding stick. Once I had worked out the bending requirements the plank was held in pliers over a boiling kettle so the bend could be formed, as shown in the 3rd photo below. As can be seen in the forth photo I had made a slight error of judgement when tapering to half width as there is a small gap between the plank and the bulwark. As a minor adjustment the plank is an almost perfect fit as shown in the fifth photo. It is good to be able to practice this method with spare material. As the test plank was sitting slightly proud I added to chamfer to the top edge which solved the problem.
    Parts
    5 mins
    Time Taken
     004.thumb.JPG.8f30a4d86fa4deb468434ff78513f8ad.JPG005.thumb.JPG.5d0ddf008e7613b9acf5436f160796b3.JPG006.thumb.JPG.0678ef78f775529d84d8d11689f17cac.JPG007.thumb.JPG.497fc75b2eb92985e806d387a01e5141.JPG008.thumb.JPG.aec8e7d7768855e125242665518d19da.JPG
    Stage 5  First Planking Testing Method Stern
    Build Steps
    31-32
    The stern area requires a slightly different approach in order for the plank to sit flat on the last few bulkheads. A twist in the plank is required. After marking the point where the twist should occur I used the same steam method to create the required twist. The twisted plank is shown in the first photo below. The second photo shows the test fit and the plank does now sit flush on all the bulkheads without any undue force or stress. The more observant will also note that the chamfered top edge is now on the bottom as I did apply the twist the wrong way in my first test piece. Good job I am only practicing with spare material, although I could redo the twist on this plank with more steam!!
    Parts
    Time Taken
    009.thumb.JPG.5134ef723a473bf22712606c3cdca3f6.JPG010.thumb.JPG.22839d5e62fb951cade0f72deb8b781d.JPG
  15. Stage 2 - Fairing The Hull
    Hull Construction – Fairing The Hull
    Build Steps
    21-22
    This is an important task to get right and requires plenty of test fitting of planks during the fairing process. I used a mixture of a sanding block fitted with 220 grit sandpaper, a 400 grit sanding stick and 220 grit sandpaper. As can seen in the following photos the planking seems to be sitting fully on the various bulkheads.
    Parts
    Time Taken
    60 mins
     001.thumb.JPG.40817576b45804ec03ff66a1011a776c.JPG002.thumb.JPG.f3fe0f08b364e625a7d855f6c9bcf20a.JPG003.thumb.JPG.97464007e160d0cd14a945c5305a734d.JPG004.thumb.JPG.833003cf5052bc7288ac9a38c0af4cf2.JPG005.thumb.JPG.9cdfac745063ecd88c2206a17b762589.JPG
    Build Steps
    21-22
    When doing a test fit of the bulwarks there is still a little bit of fairing work required at the stern, as can be seen in the next photo. The bulwarks do line up perfectly with the deck however.
     006.thumb.JPG.ffd7fd4f6167bb129360aad20462abe0.JPG007.thumb.JPG.2e51e271809da969aafea1b8241b05c5.JPG
    Hull Construction – Adding Prow and Keel Bottom
    Build Steps
    23-27
    There are two prow supports to be glued to the prow, using a locking peg to help with the correct alignment. The leading edges of the prow supports were chamfered before they were fitted. The prow and keel were then glued and clamped to the hull assembly.
    Parts
    57, 65, 107, 108
    Time Taken
    10 mins
     008.thumb.JPG.2740a536cddb44780b4a9c4241ba467f.JPG009.thumb.JPG.ee8fcea88341546059c72c92f7c79930.JPG
  16.
    Stage 1 – Hull Construction Part 2
    Hull Construction – Stern Frames, Gluing Hull Frame and Sub Deck
    Build Steps
    13-19
    After a test fit of the inner and outer stern frames the laser char was removed from the visible edges as I felt this would be easier to do prior to their installation. Once I had cleaned and glued the stern frames in place a diluted wood glue solution was brushed to all the bulkhead / false keel and lower deck joints. The final task of this section of the build was to add the sub deck. Glue was applied to all the keel and bulkhead contact points and the sub deck was slotted into place, checking that the sub deck was clicking into the locating slots on each bulkhead. As an added precaution diluted wood glue was then bushed into all the sub deck joints.
    Parts
    109, 110, 29
    Time Taken
    30 minutes
    Hull Construction –Sub Deck Items Dry Fit
    Build Steps
    It is now a good time, before bulwarks and planking has been added, to check that the various deck items will pass the the sub deck openings and will then locate in slots provided in the lower deck. As can be seen in the next three photos everything aligned up perfectly and there is also a nice rake angel for the mast.
    Parts
    Time Taken
    10 minutes
     002.thumb.JPG.e72f25b5fa69285d4039a56b052bb8e4.JPG003.thumb.JPG.2a74f323d661776551ccf6b68d9e28a7.JPG004.thumb.JPG.ca8dbf3e827f0c0685c80f9fedc5a874.JPG
    Hull Construction – Transom and Stern Counter
    Build Steps
    20-21
    I decided it would be prudent to soak the inner stern counter in warm water for a few minutes before clamping it to the curved section of the stern frames. I used a hair dry to accelerate the drying process once the wetted pattern had been clamped in place. I also added a chamfer to the lower inside edge for a better fit. Once I was happy with the fit the stern counter it was glued and clamped to the stern frames, using the laser etched guides. After an initial  test fit of the inner transom pattern I added a chamfer to the bottom edge to ensure a nice tight fit with the stern counter. It was then glued and clamped in place.
    Parts
    62, 63
    Time Taken
     10 mins
     005.thumb.JPG.be20719c0981e2a8560c01a19e109de6.JPG006.thumb.JPG.cfb147d224ced76c1326f97ea4bd6b69.JPG007.thumb.JPG.fb51320d0b0b5905eb7fd6a754ad2d2c.JPG
    Basic Hull Construction Completed
    Build Steps
     The basic (stage 1) hull build is now complete and the Sherbourne is now ready for the next stage which is fairing and 1st planking. I am also expecting to take delivery of the Harpy tomorrow (6th December) but I will do my best to resist making a start on the Harpy until I have completed the first planking on the Sherbourne.
    Parts
    Time Taken
  17. Build Log Index
    Stage 1 – Hull Construction Part 1
    Hull Construction – Pre bevelling of Bulkheads
    Build Steps
    1-2
    Laser etched guidelines are provided on bulkheads 1-4 and 13-17 and chamfers were added to these bulkheads. Once the basic hull had been assembled all the bulkheads will be faired to the required shape, so the planks are in full contact.
    Parts
    1-17
    Time Taken
    30 mins
    Hull Construction – Keel Assembly and Lower Deck
    Build Steps
    3-9
    Bulkheads 1-16 were then slotted in place to the false keel but were not glued in place at this stage of the build process. Bulkhead 17 will be fitted at a later stage in the build process. Next the left and right keel doublers were slotted in place. I did add the chamfer using the laser etch guide lines before they were fitted. The locking pegs were then glued in place to ensure the keel doublers were correctly aligned with the false hull. After a test fit of the lower deck glue was applied to the top contact areas on the bulkheads and the deck then added using the laser etched “top” marking to ensure the correct orientation.
    Parts
    1-18, 19L, 19R, 22, 23
    Time Taken
    15 mins
     S001.thumb.JPG.8a6ae534e4f2b7412d8c58c3ebb1c6b1.JPGS002.thumb.JPG.3c3034cd239abb7f9b22d0b608e32141.JPGS003.thumb.JPG.d7d06d80f941e7eac470489bb46f07a6.JPGS004.thumb.JPG.2ac35e4b1838e3ac768d6cf021922a84.JPGS005.thumb.JPG.32a187ebf395b8976dbd04fa3611bf02.JPG
    Hull Construction – Bow Frames, Longitudinal Support and Deck Camber Beams
    Build Steps
    10-12
    The two bow frames, after a test fit were chamfered and then they were glued in place. Next the two longitudinal support patterns were chamfer and glued in place, after a test fit. With reference to the plan sheet the various deck camber beams were glued in place. All excess glue was removed from the top edges, where the deck will be placed.
    Parts
    20L, 20R, 21L, 21R, 24, 25
    Time Taken
     15 mins
    S006.thumb.JPG.fbbd2c2b8e425c911fa1a43379d1237b.JPGS007.thumb.JPG.41d211b76af375d0208908b1c33b4468.JPG
    Although I have not seen any reference to it I think the top edge of bulkhead 17 will require a chamfer so the deck, when fitted, will sit flush. I think can be seen in the following build manual photo.
    With bulkhead 17 in place I have marked the top edge that needs to be chamfered.
    S009.thumb.JPG.6dc81dda2ed1f2eaaa2fe4bdfdd33263.JPGS010.thumb.JPG.b62d0db42b91b493d7d74a38526c31e9.JPG
  18. There are a few different planking and rigging ideas I want to experiment and the HM Armed Cutter Sherbourne kit ticked all the boxes for this task. One of the methods I wish to try out is the use of steam to bend bend and twist the planks. The twisting of tapered planks around the bow region, I think, should produce the same result as Chuck's lateral planking method which I have tended to use, with limited success, on some of my last recent builds.
    I can also see the benefit with twisting some planks in the stern area, particularly those that fold under the stern counter and with the lower garboard plank(s) which twists toward the stern post area. There are some excellent YouTube videos, showing this method on Jason's Modelkit Stuff YouTube channel.
    The Sherbourne kit is scheduled for delivery tomorrow (4th December 2024) morning and the shipyard is ready and waiting for the new arrival.
    My next my major project will be the Harpy (Vanguard Models) which may arrive later in the week, but will probably arrive sometime next week, depending on when @chris watton receives the manual and plan sheets from the printers.
