Everything posted by mtaylor
I hadn't seen it before either. Interesting that the camera moves with the swells even below deck. I'll watch the whole thing tomorrow.
Congratulations, Eric. Your model deserved that award.
- 599 replies
- sidewheeler
- arabia
(and 4 more)
I love the guns, but hate the news about the virus. Good on getting the vaccines but do take precautions since the variants are starting to appear.
- 1,082 replies
Welcome aboard, Grant. Nice work on the Bounty. When the next one arrives, do start a log so we can follow along.
Hello from sunny Southern California
mtaylor replied to boatsNbeers's topic in New member Introductions
Hi Dan, welcome to MSW. When you're ready, open a build log. We won't beat you up as logs are a great way to get help and advice. -
The question is though... to which model? I have a feeling they will show up in a most unexpected model.
Steamboats and other rivercraft - general discussion
mtaylor replied to Cathead's topic in Nautical/Naval History
Many years ago, the Arch in St. Louis had a good collection of riverboats in their museum. I don't know what else that had as at that point I was only into sight seeing. I also recall that they had like 10 other museums relating to history, transport, etc. Again, not sure what they might have but St. Louis used to be big on the historical river craft.- 281 replies
- Steamboats
- riverboats
(and 3 more)
Welcome to MSW, Markus. Looks like you're off to a good start. If I may suggest some things.... First, do a search on "Amati Class J" and check for other build logs. Often times, or maybe actually more often than not, someone's been through what you're doing and they way did it will help you. Second, start a build log in the kit area. It's probably the best way to meet other builders and also to get help on your build(s).
Jean-Pierre, you might have a look here: https://modelshipworld.com/forum/34-cad-and-3d-modellingdrafting-plans-with-software/ There's been a lot of conversation about CAD.
Welcome to MSW, Nehemiah. To answer your question, the basic rule of thumb for learning rigging is a) Use our logs as resource as many builders go into detail on the rigging. The bigger rule of thumb is start with no mast, then 1 mast, then 2 two before tackling 3 masts. Each one will build on the previous. As you build, you will get better in all areas. So, relax, have some fun building.
I think you got it. Also, many times, blocks get installed on the yards, etc. without being rigged (for example, not adding sails to the model) and thus, the blocks look more realistic with the two holes.
Welcome to MSW, ECK. Instead of the HEIC format you used, convert to jpg. HEIC seems to be little used outside of Windows 10.
